20 Most Recent Casio PCR-T465 Electronic Cash Register Questions & Answers
I have a PCR-T465 Casio cash register. I am trying to print at the top of the receipt and can't figure it out even though I have the book. I need the book for dummies in Kindergarten language
To print at the top of the receipt on a PCR-T465 Casio cash register:1. Turn the machine on2. Press the "Menu" button3. Use the up/down arrows to select "Header"4. Press the "Enter" button5. Use the up/down arrows to select "On"6. Press the "Enter" button7. Enter the text you want to print at the top of the receipt using the keypad8. Press the "Enter" button9. Press the "Menu" button to exit the menu.Your header should now be set and will print at the top of each receipt.
1/30/2023 12:34:01 AM • Casio PCR-T465... • Answered on Jan 30, 2023
Thermal paper not printing
Probably paper is upside down. Only one side of roll is thermal sensitive.
12/17/2013 10:04:56 PM • Casio PCR-T465... • Answered on Dec 17, 2013
2answers
Casio pcr-t470 electronic cash register has eject full e206 on screen how do i clear this?
EJ stands for Electronic Journal. The ej is a record of all the sales made on the till since the last time the ej was cleared. If you dont clear it then it eventually fills up and stops the till from working until it is cleared. I dont have a manual for this model but there will be a report to print and clear the ej in your manual.
3/27/2013 3:02:13 AM • Casio PCR-T465... • Answered on Mar 27, 2013
Wie kann ich die Casio TK 2300 umschalten auf Einzelbon
Um die Casio TK-2300 auf den Einzelbon-Modus umzuschalten, befolgen Sie bitte die folgenden Schritte:
  1. Dr?cken Sie die Taste "Programmierung", um das Programmierungs-Men? aufzurufen.
  2. Geben Sie das Passwort ein. Standardm??ig ist das Passwort "0000", es sei denn, es wurde zuvor ge?ndert.
  3. Dr?cken Sie die Taste "1" f?r den Registrierungsmodus.
  4. Dr?cken Sie die Taste "3" f?r die Bon-Einstellungen.
  5. Dr?cken Sie die Taste "1" f?r die Einzelbon-Einstellungen.
  6. W?hlen Sie "Einzelbon" aus, indem Sie die Taste "1" dr?cken.
  7. Dr?cken Sie die Taste "CA/AT/NS" (Clear All/All Tender/No Sale), um das Programmierungs-Men? zu verlassen.
Ihre Casio TK-2300 ist nun auf den Einzelbon-Modus umgestellt. Wenn Sie einen Artikel auf den Bon legen, wird ein Bon ausgedruckt, der nur diesen einen Artikel enth?lt. Wenn Sie weitere Artikel hinzuf?gen m?chten, wiederholen Sie den Vorgang. Ich hoffe, das hilft Ihnen weiter!
3/5/2023 5:45:55 PM • Casio Computers... • Answered on Mar 05, 2023
Weird behaviour on my CASIO WK3500.
.This issue with your CASIO WK3500 keyboard could be caused by a few different things, including:
  1. Power supply issue: The issue could be with the power supply, and it may not be providing enough voltage to the keyboard when first plugged in.
  2. Circuit board problem: The issue could be with the circuit board within the keyboard, and it may not be able to start properly if there's a problem with the power supply.
  3. Firmware issue: There could be a firmware issue that is causing the keyboard to not start properly, which could be resolved by updating the firmware.
  4. Electrical interference: There could be electrical interference in the area that is causing the keyboard to behave erratically.
2/6/2023 12:29:41 AM • Casio Computers... • Answered on Feb 06, 2023
Casio C-801 replacment battery type
Cassio have an excellent inhouse repair service. https://www.casio.co.uk/
12/13/2022 1:03:23 PM • Casio Computers... • Answered on Dec 13, 2022
2answers
Used wrong adapter to power my Casio pt 100
more, lots of PT-100 users long long ago and for decades did MODS.and the power pack mode was 2 ways or both ways1; wired center pin on some CASIO IS WIRED PER PHOTO BELOW. IF USING WRONG PACK IT BLOWS UP THE MOBO.2: added series diode 1N4001 up , to make it never blow up again. (voltage to high still will)I have a mod for #3 , too much voltage using zener diode and a fuse. ask.I have endless ideas on mods for most things that (plug in)the AD1 PACK MISSING AND WRONG PACK USED BURNS THIS KBD UP, AS VAST FOLKS IN THE NET TESTIFY.WRONG PACK OR CLONES SOLD WRONG, I SEE MANY SOLD THAT SHOW AD1 COMPAT, BUT IS A LIE.THEY LIE. NOW.WRONG VOLTAGE SOLD . WRONG POLARITY SOLD AND USED.WIRED WRONG, PACKS.THE PACK IS CALLED CASIO, AD1 (TOLD IN THE USERS MANUAL()MINUS -7.5 VDC AT 2.2WATTS (WATTS BE HIGHER IF YOU WANT)AMPS IS 0.133 amp max or 130mA , I bet the electronics inside uses 100mA max or less..a5bf047f-faf6-47d6-a7fd-347141342a43.jpg
6/19/2022 5:43:42 PM • Casio Computers... • Answered on Jun 19, 2022
I need a manual to help me set up and play a KEYBOARD CASIO M/CTK720 S/AR46. I CAN'T GET THE DOWNLOAD TO WORK AND I DON'T KNOW WHAT AN URL IS. I'M 78 YRS OLD. NOT FAMILIAR WITH KEYBOARDS.
Hello Chwintersjr, I recommend you search the Internet, some site of users and lovers of this type of keyboards and join the group and surely they can guide you in a simple and safe way Hola Chwintersjr, le recomiendo buscar en Internet, algun sitio de usuarios y amantes de este tipo de teclados y se incorpora al grupo y seguramente lo podran guiar de una manera simple y segura https://support.casio.com/es/manual/008/CTK720_ES.pdf
6/15/2022 1:45:18 AM • Casio Computers... • Answered on Jun 15, 2022
How to reset casio wk 1800
I think to get the factory reset on that keyboard, you hold down the 'ENTER' button, while turning on the power. You then get a dialogue, to guide you thru a reset proceedure. This will clear the memory, also...so you will need to reload any custom sounds you may have created.Oct. 11, 2005
Casio WK 1800 Factory Reset? ' Casio Keyboards Discussion ...
http://www.synthzone.com > ubbthreads.php > topics > Ca... ..
6/15/2022 1:30:44 AM • Casio Computers... • Answered on Jun 15, 2022
Casio e-100 doesn't charge. Charger is new, green light goes on for 1 sec when connecting the charger
You may have a zombie battery.. try this: plug charger in at wall, then into device, then rapid-fire unplug and plug in device, try to be as quick as you can, 2 or more times per second, this can often bring back a battery from the dead.. reasoning: initial voltage to battery from charger is a "surge" and the rapid fire surge is what you're after.. like heart paddles. . Good luck be safe.
6/15/2022 12:56:28 AM • Casio Computers... • Answered on Jun 15, 2022
I have a casio wk-1630 keyboard. The light on the plug going into the wall lights up but the power won't turn on with the keyboard itself. I'm not tech savvy so no clue what the problem is
On the power pack there may be a label that says 12v dc or 18v Dc or some other voltage. There may be a input voltage on the keyboard and a current rating eg 12v DC 1A current or it might be AC voltage of 12V or some value. get a volt meter or a multimeter and measure the voltage on the plug. positive is the inside part and the outside part is negative. dc setting if dc volts expected or AC setting for if AC voltage expected Or get power pack tested at a music shop you may have a faulty power pack
6/15/2022 12:49:19 AM • Casio Computers... • Answered on Jun 15, 2022
Gift card button on a casio register
ask your boss or RTM ?
4/17/2022 8:28:05 PM • Casio Computers... • Answered on Apr 17, 2022
Any software version for Casio PV 400 plus. Where can i download it
http://www.bluesolpv.com/dnnsite/default.aspx?gclid=EAIaIQobChMI3sPvmv6r6AIVzLTtCh109AfmEAMYASAAEgJ37vD_BwE
3/21/2020 4:30:51 PM • Casio Computers... • Answered on Mar 21, 2020
I have forgot the password. secret Area has contacts. Want to Factory reset Casio SF-3600 I have already tried RESET button near the battery. Still shows 65111 used and 99959 Free.
a crude digital Diary RTM yet/? remove battery and push reset? or hold the reset as you put back batteries? 3300 to 3600 are same. way. here is the free book 3500 it is covered in the manual on page 46 btw 1st google hit. https://www.manualslib.com/manual/777267/Casio-Sf-3500.html
1/5/2020 9:19:40 PM • Casio Computers... • Answered on Jan 05, 2020
Casio pcr 308 Z key
ManiaQQ Situs Judi Poker Domino QQ Pkv Game Online TerpercayaWebsite https://maniaqq-pkv.me/
12/6/2019 8:44:04 AM • Casio Computers... • Answered on Dec 06, 2019
I have a Casio mk200 and I thought I saw somewhere that I could plug in audio out from a microphone on the Casio how can I plug the Casio mk200 into a portable Studio which has analog left and right line in
Play and win with https://finlandfreeslots.com/free-online-slots/ website. Here you will find more then 600 games. Test your skills, have fun and win from home. Play from your computer, mobile or tablet and discover exclusive game offers where you can play in a totally safe way.
11/19/2019 8:40:13 AM • Casio Computers... • Answered on Nov 19, 2019
How to reset a Casio ct-670 because it's acting strangely. It has a problem where you press a key and you press it again it won't do anything and you have to wait 1 second for it to make a note.
That does not sound like something that will be solved by resetting it. It sounds like a bad contact. If you know how to use contact cleaner, try that. If not, contact a service center and have them provide the maintenance that it is in need of.
8/19/2019 4:43:22 AM • Casio Computers... • Answered on Aug 19, 2019
Casio PCR-T465 Electronic Cash Register Logo
16 questions posted
Top Casio Computers & Internet Experts
Steve Nordquist
Steve Nordquist
Marvin
Marvin
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Casio Computers & Internet
Most Popular Question
casio pcr t470 electronic cash register
  • Computers & Internet
