20 Most Recent ASUS K51AC Series Keyboard Questions & Answers
Enrique Javier... wants answers to this question
nice hyjack the other post means nothing, not clear at all
so you piggyback this lame post, why not start your own posts with your own facts,
what PC, is it exactly
and why do you need to disable something
you do know that the OS does all that the keyboard has no brain in any laptop K51. ever.
the keyboard is only a matrix of switches, the OS in the PC
translates key switch closers to any thing thing it wants..
in fact there are 50 keyboards for 50 countries.
next time just tell what you don't like a windows short cut>
you never told what short cut you don't like.
it seems the keyboard is bad, that is what I think.
and very common on laptops for sure THIS OLD.
one simple way to prove that is remove the matrix keyboard from the laptops and connect any USB keyboard to the USB port and now the keyboard works perfectly, see? it does.
proving cause or the cure.
the cable too in side the laptop can fail, be loose or the jack the ribbon cable plugs in to is cracked, also common. (bad service)
ASUS K51AC... | Answered on Sep 18, 2019
I just had a similar problem with the same Asus model. It drained the battery yesterday and today wouldn't start even after charging for 15min (the middle light was on so it was charging). The light bulb light was on though even when it wasn't charging. Tried pressing the button several times. Didn't help. Tried holding it for several seconds. Didn't help. But when I hold the button for around 30sec the light bulb turned off. And then another press and it turned on as normal. So the laptop must have been hibernated/sleeping. But it did give me a heart attack, especially when I realised that I will have to take it to Currys for repair where their very unknowledgable KnowHow don't know how to fix anything (send a laptop three times and still didn't fix the problem, they only know how to install software updates).
ASUS Computers &... | Answered on Sep 24, 2020
Watch this YouTube video which explains how to replace the screen.
ASUS Computers &... | Answered on Sep 15, 2020
Via a cable, with an SD card, you could also email a copy to yourself if you set up email on your android tablet. There are many ways to do it.
ASUS Computers &... | Answered on Sep 02, 2020
check the power management options, UNDER settings and or control panel - you will be able to see the time like minutes and secs of the options to sleep and wake up
ASUS Computers &... | Answered on Aug 30, 2020
I think it is running a test mode. Some kind of button pressing combination might free it from this.
It might go away if you can plug it into a vga source (pc, laptop) and hopefully change it from there.
Good luck.
ASUS Computers &... | Answered on Jul 08, 2020
need to reboot the system with a disc or backup mode
ASUS Computers &... | Answered on Jun 09, 2020
Getting video and no sound or sound and no video is more common thanyou might realize. This problem is almost always caused by one of twoproblems. Either you don't have the required codec installed on yoursystem to decode the audio portion of the file you downloaded. Or windows media player isn't properly associating the correct codec on your system in a way that makes playback possible.
The first step in correcting playback is finding out what codecs arerequired. AVI files typically require one codec to display the videoand a different codec for displaying audio. A usefull tool forchecking AVI required codecs is GSpot.
http://www.topdrawerdownloads.com/download/103437
f you find that you are missing a codec, you need to locate that codeconline and download it. Some compatible codecs are listed at theMicrosoft run WMPlugins.com.Others must be tracked down from one of the various onlinerepositories. It's very common for codecs related to DivX (includingXviD and 3ivX) to have issues, particularly because of the way audioand video are paired during the encoding process.
ASUS Computers &... | Answered on May 07, 2020
Try reseatting the DVD/CD drive also reinstall the DVD/CD driver.
If this does not fix the problem then most likely the DVD/CD drive is faulty and then needs to be replaced.
ASUS Computers &... | Answered on Apr 17, 2020
I use VLC Media Player. It works great and it is free! Go ahead and Google VLC and it will lead you to this site:
http://www.videolan.org/vlc/index.html
Hope this solves your problem. I assume you have Windows 10 at this point.
Kind Regards;
Craig in San Diego, CA
ASUS Computers &... | Answered on Mar 24, 2020
The Asus bios won't show SATA devices.
However if you are using Windows XP with Service Pack 2 (or newer operating system then the devices should be detected. If this is not happening then enter the bios -- Storage Configuration -- Configuration Enhanced and set the IDE devices to compatible. This allows all drives to be "seen" and you should then be able to load an OS.
ASUS Computers &... | Answered on Mar 14, 2020
There are several possible reasons for the DVI port not to provide a signal to the monitor. First, is this a desktop or laptop?
For a desktop, do you have a video graphics card installed? If so, make sure that the DVI port to which you connected the cable is on the VGA card. Video ports on the motherboard will be disabled when the VGA card is active. Next check if the monitor is set to the correct source. Then turn off the computer and monitor. Turn on the monitor first and then the computer. This is the best way for the computer to find a new monitor. If this still fails, try a different DVI cable. If you are using an adapter, check that you have it in the direction. Not all adapters support two-way video signals. (This applies to most Display Port to DVI cables. It may happen with some HDMI to DVI cables.) If you are adding a second monitor, check the Display settings. (For most versions of Windows, right click on the desktop (no icons/programs) and look for a Display Settings button. For Windows 10, Start button > Settings > System > Display.) Use the Detect button to see if the computer has recognized the monitor. Then set up how you want the output to go to that monitor (duplicate screen or independent). If you have more than two monitors, check your hardware. Many computers will not support 3+ monitors unless Active Display Port adapters are used for the third and subsequent monitors.
For a laptop, you may need to enable the external video adapter. Often this is disabled to save power. Enabling the adapter usually requires accessing the BIOS and that depends on the motherboard. You might need to press F1, Del or F2 repeatedly after turning on the computer. (There will be a splash screen that shows the appropriate key.) With Windows 10, the fast boot may make this impossible to see. From Windows, press Start and then power. Right-click on Restart to see the Advanced Restart menu and access your BIOS information. If the port is active, then see the above section on the Display Settings to have Windows send data to the monitor.
I hope this helps.
ASUS Computers &... | Answered on Mar 10, 2020
ok , what OS came on this new?
for sure dont use w8, as the wifi engine it it is JUNK totally junk from MS.com
i see Asus offered a free w10 upgrade, google searched 1st hit.
says clear as day, not all features work, if done
why not just leave it at w7 ?
1st and always,
connect the PC directly from PC ethernet jack cable to router
now the web works, and now the magic PNP works
microsoft plug and play works, so does that cure the dead wifi chip?
i can not know what chip is inside your PC for wifi, as the makers uses like 5 kinds even on one model. (what's on sale i guess.?)
but they do.
so only drivers for that unknown chip work
in a real shop we run app called PCI-z, or the like.
and see what chip it is then if the chip is dead, we get the driver from
ASUS direct or from the chip maker, like say broadcom.
here are the correct paths in order
1:MS PnP autoloaded driver,
2: Asus driver off their set
3: chip makers driver
only those work and only those are virus free, ok? 1,2,3. only
there is 1 exception but lets skip that, for now.
if the ethernet cable fails, that is very bad, and very rare.
for sure w10, plug and play on modern PCs supports all ethernent
your support site is here
https://www.asus.com/us/Laptops/X551CA/HelpDesk_Download/
the ATK fixes, w10 compat. issues.
asus does not disclose what chips are on the mobo , in there lame spec,page, (par)
but we have tools do that , in all cases. so.... spec be damned.
look at that page, you see all drivers are missing there
this is like marketing ploy, (goons) that can communicate facts.
it should say at the top, this.
"ALL drivers for this product not seen below are at ms.com"
did you install w10 64bit fresh (not 32 !!!)
and did the ethernet cable run from PC to router
if not OOP that was wrong, that 1st step.
let the installer reach the MS servers,
here that server is if curious.
http://www.catalog.update.microsoft.com/Search.aspx?q=PCI%5cVEN_10DE%26DEV_11C6
connect ethernet to PC RJ45 to router, cat 5 cable is ok,
then boot the DVD< w10 or ISO built uSB stick.
now fresh load w10-64bit, and all chips in the PC should hit the deck running. ok?
ASUS Computers &... | Answered on Mar 01, 2020
Solved] Fix Windows 8 Boot Error 0xc000000f go here for instructions http://www.smartpctricks.com/2013/09/solved-error-code-0xc000000f-windows-8-a-required-device-isnt-connected-or-cant-be-accessed.html
ASUS Computers &... | Answered on Feb 19, 2020
Click here to download the latest version or gom player from here.
Please let me know if you have any further questions or concerns.
Thanks.
ASUS Computers &... | Answered on Feb 16, 2020
It means super multi DVD rw. It's defining your optical drive's capabilities.
ASUS Computers &... | Answered on Jan 10, 2020
the question is not clear at all,
tell what works and not , first.
RTM yet, read the manual;
that be first out of the gate.
https://www.asus.com/2-in-1-PCs/ASUS_Transformer_Book_Flip_TP550LA/HelpDesk/
ASUS Computers &... | Answered on Jan 09, 2020
ASUS K51AC Series Keyboard Logo
1 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Roy May
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
disable keyboard shortcut
  • Computers & Internet
