20 Most Recent Terk LeapFrog LF30S Questions & Answers
We would be happy to help you with that. The first thing wewant to check is if the issue is affecting multiple buttons on the remote. Ifyou are having the issue with specific buttons then the remote needs to bereplaced, give us a call at 1-800-333-DISH (3474). Check if you are using thecorrect remote for the correct room, there may be a number on the bottom of theremote that tells you which room the remote should be in. If UHF, check thatyour UHF remote antenna is securely connected to the "RemoteAntenna" port on the back of your receiver and that the antenna isupright. At this point we want to re-address your remote, if issue is with theTV2 remote, bring your TV2 remote with you to TV1. Access "SystemInfo" at TV1. Using the remote that is NOT functioning, pressand release the "SAT" button then press and release the RECORDbutton on remote control. If the batteries in the remote have not beenreplaced in the past 60 days, replace the batteries. Reset the receiver byunplugging it for 10 seconds then plug it back in then re-address the remoteagain. If the remote is still not working at this point then it may be aninterference issue. If you are having issues with an infrared remote, findinterference source (backlighting or power save mode on LCD TV's, fluorescentlighting in room, or direct sunlight), eliminate, or convert remote to UHF. Ifyou are having issues with an UHF remote, find interference source (component(VCR, DVD Player, etc.) near DISH receiver), adjust UHF antenna, or distanceUHF antenna from receiver using coax cable/barrel connector. If the remote isstill not working after all these steps we need to have your remote replaced.
We really hope all these steps resolve your remote issue. Thank you for being avalued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Terk LeapFrog... | Answered on Feb 23, 2011
Hello this is Dan Busa with DISH Network. I'm not quite sure if this is the answer you need, the way you need this set is you want the IR blaster pointing directly at the IR sensor on your receiver (the three holes by the power light) the actual extender just needs within close range of your remote.
Terk LeapFrog... | Answered on Jan 15, 2011
When you unplugged it, did you leave it unplugged for 10 full long seconds and press any button for that 10 full seconds as well, then wait a few more before plugging it back in? That is the correct procedure. If that still doesn't work, then either the firmware needs to be updated, or there is a faulty IC chip in the device that will need to be replaced.
Terk LeapFrog... | Answered on Oct 30, 2010
Yes,the unit have a LED power light indication wright?Chek ur power source?
Terk LeapFrog... | Answered on Oct 21, 2010
Yes you can, is the simple answer!
Terk LeapFrog... | Answered on Jan 24, 2010
Do you want to surf the pay channels in the other room?
Terk LeapFrog... | Answered on Aug 23, 2009
it might possibly be the signal strength, try moving the transmitter closer, if possible.
Hope this helps!
Terk LeapFrog... | Answered on Jul 13, 2009
to install the leap frog it has to be installed directly into the tv. cannot plug leap frog into directv satellite box, will not work. hope this helps! your question is a little unclear
Terk LeapFrog... | Answered on Apr 05, 2009
Not a stupid question. You should have received all the cables you need with the Leap Frog. To hook up your tv, take your transmitter and one set of a/v cables, usually red, white and yellow. Do one cable at a time. Your tv outputs should be color coded. You should have one set of three jacks completly open on the back or side of your tv, i.e. labeled component 1, component 2, aux 1, etc. First plug select one set of jacks. Plug a yellow plug into the yellow jack on your tv labeled video out. Plug the white plug into the white jack labeled audio L out. Plug the red plug into the red jack labeled audio R out. Now do the same on the transmitter but the jacks should say in. Yellow, white and red to video, audio L and audio R. Now take your receiver into the other room and do the same thing with the other tv. The cables go from the receiver out jacks to one set of jacks labeled Aux, component, etc like before. Pick a set that has all three open. Red to red, white to white, yellow to yellow. Make sure you then have the transmitter and receiver plugged in. Your remote is supposed to work from your other room. If this solved your problem please rate this as fixed. If you need more help with this just add a comment and I'll be glad to help you. Thanks.
Terk LeapFrog... | Answered on Sep 21, 2008
Their should be a coax cable attached to the antenna that screws on to the threaded coax tuner input on the back of the TV... It will probably be the only threaded cable attachment point. If another tip on the cable look for the antenna in jack on the back of the TV. The rest will be HDMI or RCA inputs. After connecting the cable you will need to run the tuner setup scan on the TV from the setup function to scan for usable TV programs...
Terk Televison &... | Answered on Jan 07, 2020
Your Terk antenna has a round F connector for 75 ohm coax cable. Unless your receiver is really old, it has an F connector for the antennaas well
Terk Televison &... | Answered on Feb 16, 2013
Yes, there is something you should do, take it to a television engineer! Brain surgery next? :>D
You aren't an engineer and you don't have the test equipment or the knowledge.
Check all your connections, if it is still not working, take to a professional. It is unlikely that both the main board and the power board were faulty, so you already bought one board too many. You can't diagnose television board issues on an online forum, you need the equipment to test.
Televison &... | Answered 15 hours ago
Terk LeapFrog LF30S Logo
Popular Tags
26 questions posted
Top Terk Televison & Video Experts
Tom Chichester
James Geiger
James Geiger
Level 1 Expert
Are you a Terk Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Terk Televison & Video
Most Popular Question
power light when plug terk
  • Televison & Video
