20 Most Recent Frigidaire 13.7 cu. ft. / 388 liter Upright Freezer FFU14FK1CW Questions & Answers
For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Frigidaire 13.7... | Answered on Mar 12, 2009
sound like the condenser fan motor by the compressor has stopped and the not allowing the proper cooling check that also you should have waited at least 6 hr upright before starting the unit
Frigidaire... | Answered on Oct 23, 2019
Always at least and inch or two away from wall.
consult your installation instructions or use guide for info
Frigidaire... | Answered on Jun 24, 2019
The temperature control is located inside the freezer on upright models, and onthe left outside wall on chest models. The temperature is factory preset to providesatisfactory food storage temperatures.
However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. If acolder temperature is desired, turn the temperature control knob toward COLD-EST and allow several hours for temperatures to stabilize between adjustments
Frigidaire... | Answered on Jun 16, 2019
Freezers expel warm air. There should be no 'blowing' inside. If it is expelling warm air, then it is working fine, eventually the expelled air should get cooler and cooler.
Frigidaire... | Answered on Jun 06, 2019
That yellow light on sonne older modelks is just showingbtge power is on. I never heard of a chest freezer having a "quick freeze" feature. This feature would also require forced air cooling and auto defrost. If the walls get frost on ghr m t hen Im betting that is ju st a power light although it may say freeze or something else like that. Its just so when you see the yrllow light you know there is power.
Frigidaire... | Answered on May 20, 2019
Typically, error code "HI" (the customer may say "H1") on a Frigidaire refrigeratorunit indicates that the unit has detected high temperature in the freezer and/or therefrigerator https://kb3.s2g.net/index.php?/article/AA-00411/0/Frigidaire-Refrigerator-Unit-Flashing-HI.html
Frigidaire... | Answered on Mar 29, 2019
Many reasons why it may be loosing temperature. Such as Defrost problem, fan not running, sealed system problem, compressor problem
Frigidaire... | Answered on Jan 18, 2019
Frigidaire 13.7 cu. ft. / 388 liter Upright Freezer FFU14FK1CW Logo
Popular Tags
3 questions posted
Top Frigidaire Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Dennis Boxerman
Marvin
Marvin
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Freezers
  • Frigidaire Freezers
Most Popular Question
upright frigidaire freezer light
  • Freezers
