20 Most Recent HP Pavilion TX1320US Tablet PC Questions & Answers
Blank screen
The problem is in te GPU. There is a known problem with all tx1000 series computer wihthe GPU overheating. Ifou want more info on the fix or need the fix performed please felfe to contact me.
2/24/2014 2:03:32 AM • HP Pavilion... • Answered on Feb 24, 2014
0answers
Wont turn on
Be the first to answer 12/6/2013 8:49:19 AM • HP Pavilion... • Posted on Dec 06, 2013Be the first to answer
0answers
Usb does not works
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
11/9/2011 6:51:43 PM • HP Pavilion... • Answered on Nov 09, 2011
0answers
No wireless adapter
Have you check the wireless card under the Device Manager?
Start->Control Panel->Device Manager
Under Device Manager look for Network Adapter there will be sub folders under network adapter look for the wireless device. If its not showing it means that the Device is not working. If you want to make sure try to reinstall the Operating System and after that check again the Device Manager.
4/18/2011 12:31:50 AM • HP Pavilion... • Answered on Apr 18, 2011
I need drivers for the
open a GOOGLE search and type in the name, and model of your camera along with the word DRIVER
You will see a page full of drivers you can download for free
12/25/2010 9:47:20 PM • HP Pavilion... • Answered on Dec 25, 2010
My mother board gets heated
your Healsink is not working properly....Overheating is a very common problem in HP. I myself have an HP machine and i have replaced my Heatsink three times...
hope this will help...cheers:)
9/25/2010 8:53:35 AM • HP Pavilion... • Answered on Sep 25, 2010
Hp pavilion pc tx1320 laptop
Check the RAM module/s.
The RAM may need reseating to make proper electrical connection.
If it still does not boot up, remove the RAM and take it to your friendly computer repair shop and get them to test the RAM for you.
9/14/2010 2:05:29 AM • HP Pavilion... • Answered on Sep 14, 2010
I can't get any display on the screen of my pc.
  1. please follow the following instructions i hope this helps
  2. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
  3. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds .
  4. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning
7/12/2010 1:43:33 PM • HP Pavilion... • Answered on Jul 12, 2010
2answers
My HP Pavilion tx1320us laptop
what is the name of the opearting system. or all you have to do is put a cd in the computer press F2 to enter setup depending on the system. then set it to boot from CD, you can either repair it or format it to install a new window
5/26/2010 10:57:03 AM • HP Pavilion... • Answered on May 26, 2010
My laptop tx1320us starts up really slow.. what
assuming your OS as vista.
check msconfig
start -search-msconfig- remove unnecessary programs.
start-search-%temp%.- delete all files.
this will speed ur laptop.
also you can delete- temp internet files as wel as delete history files and cookies.
this will spped up ur laptop.
5/16/2010 4:50:59 PM • HP Pavilion... • Answered on May 16, 2010
My wireless network card is physically installed
Do you have the correct driver installed?
4/9/2010 2:04:11 AM • HP Pavilion... • Answered on Apr 09, 2010
you can make your fast in many way. see the tips here http://soluzia.net/speedupurpc.php
3/23/2010 6:02:21 PM • HP Pavilion... • Answered on Mar 23, 2010
How to fix a black screen
yo GPU is failing ue to overheating. You have a e optionson the fix. Plaseemail me if your still looing for the repair and I will forward the fix instructions and some other options yo have. Thanks Bill
2/14/2010 7:50:42 PM • HP Pavilion... • Answered on Feb 14, 2010
When i open my pc the screen turn to colored
The probe in the GPU. These machines run very hoand the GPU connections on th motherboard fail. Feel free to contact me for more info on the fix and what your options are.
2/14/2010 7:47:17 PM • HP Pavilion... • Answered on Feb 14, 2010
HP Pavilion TX1320US Tablet PC Logo
Popular Tags
43 questions posted
Top HP Tablets & eReaders Experts
ADMIN Canada
ADMIN Canada
ray gallant
Tom Chichester
Are you a HP Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • HP Tablets & eReaders
Most Popular Question
  • Tablets & eReaders
