20 Most Recent
HP Pavilion tx1120us Tablet PC Questions & Answers
Hi good day my hp tx1120us is booting up with a
This happens when a memory chip is faulty.
Once thing that does tend to fix this problem is disconnect the power cord, remove the battery, press and hold the power button for 10 full seconds. Than wait 10 seconds, put battery back in and plug in and turn it on.
All lights come on but nothing else.
hi try this first, unplug the adapter/power cord, then remove the battery from the laptop, next press and hold the power button for about 10 seconds or so, install the battery back into the laptop and power up as normal, repeat this again if the laptop dose not boot up you should at least get the mainboard bios to come up.
let me know how it turns out.good luck
ken
The wireless functions dissapear without warning.
take the wireless card out and put it back in securely.
Make sure it is switched or toggled on
also what do you mean it doesn't work. No lights, indicator, or you have that and it just doesn't connect. could be virus related if the latter.
How do i fix my hp tablet stream7 that has a black screan
You can try a factory reset, try holding the power button and the volume down key on the side of the tablet then use the up and down voulum keys to select factory reset and push the power button. That should bring up a screen that says are you sure? Use the volume keys to select yes and it should reset. If this doesnt work, you have to get ahold of hp customer service.
