20 Most Recent Janome 6019QC Mechanical Sewing Machine Questions & Answers
sounds like switch faulty or dirty contact making stick
Janome 6019QC... | Answered on Oct 25, 2017
most likely by setting the machine to that function ..rereading the instruction manual would be my first option .
Janome 6019QC... | Answered on Nov 08, 2015
?????????????? need more information
Janome 6019QC... | Answered on Aug 29, 2014
This model is known to blow the fuse (3.0 amp) in the power board. A repair shop can replace it with a new style one (3.15 amp).
Janome 6019QC... | Answered on Apr 21, 2014
Please go to mechanic shop or check the timing. And adjust the stitch normal tenstion.
Janome 6019QC... | Answered on Dec 26, 2013
You may only be able to adjust this one or two spaces. When you have the straight stitch selected, try moving you stitch width slide wider. If you needle is in the correct position, you should see it move as you slide the lever.
Sewing Machine Tech
Janome 6019QC... | Answered on Oct 25, 2013
make sure that you have the machine correctly threaded up, sometimes you can miss a little hook that the thread must pass through. This done look at your machine and find the round knob nearest to the needle, that has numbers on it. Turn this to around the 5 mark and try to use the machine. If this provides some tension, then you need to keep moving it, by tiny increments and sewing to check to see if it is working better, until you find a tension where your stitches are even on both sides of the sewn fabric (ie you should not be able to feel anything different on either side and they should look that same) that will be the ideal tension - once set DO NOT TOUCH IT AGAIN. If nothing happens when you move this button then it is probably broken and needs to go to the shop
Janome 6019QC... | Answered on Feb 09, 2013
you can try cleaning them with thread or unwaxed dental floss
and maybe a can of computer air and if that doesn't help then it
would be a good idea to have the machine checked to see if the tension dial needs to be replaced.
Janome 6019QC Mechanical Sewing Machine Logo
130 questions posted
Top Janome Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Janome Sewing Machines
Most Popular Question
change position needle
  • Sewing Machines
