20 Most Recent Frigidaire 15 cu. ft. / 425 liter Chest Freezer FFC15C3A Questions & Answers
The green wire is a safety ground and will attach to the body of your freezer somewhere not far from the thermostat. It really does not matter where it attaches as long as it is a clean piece of metal. Here is a link to a wiring diagram but it is not showing the green wire. HERE
If you have questions please let me know, Thanks Sea Breeze
Frigidaire 15... | Answered on Mar 14, 2013
possibly thermal overload located @ compressor wiring... this is normally due lack of refrigerant back to the compressor from low refrigerant or restricted metering device.
Frigidaire 15... | Answered on Aug 27, 2011
522ltr, its a big one.
Frigidaire 15... | Answered on Mar 07, 2011
defrost fully once a year or more if you notice it frosting up.it should run at minus 18c to 20 c for best results. 0f is fine.gurgling noise is normal (liquid turning to gas before compressor turns it back to liquid).make sure door seals all round and the kids close the door asap after use......also if you portion up food prior to freezing and vacpack it it will last longer.and be easier to store/rotate.
Frigidaire 15... | Answered on Feb 02, 2011
these units should have a self defrost cycle.
or they can be defrosted by turning the off and remove the plugs in the bottom of the unit so the water can be let out.open the lid you can also use a blow dryer to speed up the process.
Frigidaire 15... | Answered on Oct 21, 2010
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Frigidaire 15... | Answered on Apr 21, 2010
home refrigeration units are not designed to work in low temperature areas. where temps will drop below 45f so that is your problem. this is listed in your owners manual if you want to verify. thx peyton
Frigidaire 15... | Answered on Jan 31, 2009
Hi!!!you have a seal system problem..
Frigidaire 15... | Answered on Jan 06, 2009
Still waiting for an answer.
Frigidaire 15... | Answered on Dec 16, 2008
sound like the condenser fan motor by the compressor has stopped and the not allowing the proper cooling check that also you should have waited at least 6 hr upright before starting the unit
Frigidaire... | Answered on Oct 23, 2019
Always at least and inch or two away from wall.
consult your installation instructions or use guide for info
Frigidaire... | Answered on Jun 24, 2019
The temperature control is located inside the freezer on upright models, and onthe left outside wall on chest models. The temperature is factory preset to providesatisfactory food storage temperatures.
However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. If acolder temperature is desired, turn the temperature control knob toward COLD-EST and allow several hours for temperatures to stabilize between adjustments
Frigidaire... | Answered on Jun 16, 2019
Frigidaire 15 cu. ft. / 425 liter Chest Freezer FFC15C3A Logo
Popular Tags
17 questions posted
Top Frigidaire Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Dennis Boxerman
Marvin
Marvin
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Freezers
  • Frigidaire Freezers
Most Popular Question
unit runs continually gurgling sounds
  • Freezers
