20 Most Recent Vutec IR1CK Remote Control Questions & Answers
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Vutec Televison... | Answered on Mar 12, 2017
Make and model of VHS player will help you get an answer.
Televison &... | Answered 6 hours ago
Your tv sounds fairly normal to me - there is a difference between a tv being switched off and being on standby. It is usual for a tv to need to be switched on manually and from there the remote would be able to switch it between on and standby.
Sometimes the "power" button of the remote only switches the set to standby and selecting a channel would switch it from standby...
Televison &... | Answered 7 hours ago
Hi Nico,
Look behind the tv, there should be buttons for manual control, usually at the end of the tv (right or left corners). If not, look behind the tv for the buttons. Once found, there should be a control for up/down/left/right for you to select.
Hope this helps!
Kevin
Televison &... | Answered 14 hours ago
go into settings make sure blue tooth on and then audio settings and activate or enable then pair
Televison &... | Answered 22 hours ago
check batteries if recently changed check see if in correct
bad power board possible bad capacitors on it
My ELCOT TV ask password, TV screen showing Limit Set, Limit Lock ON ask Password.
Televison &... | Answered 23 hours ago
Please write questions in American English.
Televison &... | Answered Yesterday
Sigmia OR Insignia?
Here is a listing of the most common InsigniaTV codes for universal remote controls (for all InsigniaTVs manufactured after January 1, 2007): Universal remote control makes and models: Aconcagua 0179, 0236, 0463, 1463, 0180, 0178, 0150, 0156, 0054, 0171, 0030, 0017, 0092.
https://forums.bestbuy.com/t5/Televisions-Home-Theater/Insignia-TV-Remote-Control-Codes-Official-Thread/td-p/1238257
Vutec IR1CK Remote Control Logo
2 questions posted
Top Vutec Televison & Video Experts
Marvin
Marvin
Are you a Vutec Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Vutec Televison & Video
Most Popular Question
lost remote control dish net
  • Televison & Video
