20 Most Recent Sony RMEZ4 Remote Control Questions & Answers
Hello
Telefunkent cannot be programmed with this remote control, either by direct code entry or by code search. OK.
Sony RMEZ4... | Answered on Sep 04, 2019
Here are some Funai codes
534,541,657,661,662,677,682,694
Hope this helps
Sony RMEZ4... | Answered on Jul 01, 2016
If the tv is a magnavox, you should have a magnavox remote or a universal to work it, unless I am not understanding your question. Dale
Sony RMEZ4... | Answered on Jul 08, 2013
Check with an other setup code. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Sony RMEZ4... | Answered on Mar 21, 2013
0128 0013 0002 0071 0380
Sony RMEZ4... | Answered on Apr 03, 2012
Try these codes.
0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
Click Sony Support link and find out related code for your tv.
Hope this will help.
Sony RMEZ4... | Answered on Aug 25, 2011
Hello
Try a code search method. Sometimes it may halp you.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Sony RMEZ4... | Answered on Jul 23, 2011
Sony RMEZ4 Remote Control Logo
53 questions posted
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
rm ez4 but dont codes
  • Televison & Video
