20 Most Recent Samsung BN59-00455A Remote Control Questions & Answers
3answers
The remote will not work- put new batteries in-
Buy a local remote from the market & try if still doesn't work problem lies with the TV that would cost
>100.
6/2/2016 9:47:07 PM • Samsung... • Answered on Jun 02, 2016
I need help with syncing my controller!
This remote control have no set-up codes to LG Blu-ray.
7/16/2013 4:41:24 PM • Samsung... • Answered on Jul 16, 2013
0answers
CORRECT PART?
Be the first to answer 5/7/2013 4:17:34 AM • Samsung... • Posted on May 07, 2013Be the first to answer
Can i use my samsung remote to tune in a becko tv
read your instr manual or download from www.fitness.manualsonline.com and proceed according if they suggest that can be use it.
11/29/2012 5:50:35 PM • Samsung... • Answered on Nov 29, 2012
TRYING TO PROGRAM WITH MY MOTOROLA CABLE BOX
If I understand correctly you are trying to program your Samsung remote to your cable receiver. Well, I will first give a few troubleshooting steps to do on the remote that are important before you do anything else, if you have yet to do these steps.
1. Has the remote worked on this cable box before and/or does it function the any other devices?
2. Try "New" batteries
3. Does the remote supplied with the cable box work?
4. Perform a IR (infrared) test on the remote, here is a link to show a IR that is transmitting properly.
If there is no light from the IR, then you have a bad remote, replace it.
5. Call your cable/satellite provider for the codes and steps to program it, they may have this information posted on their website so check there before you call them.
I hope this helps
3/11/2011 9:48:20 AM • Samsung... • Answered on Mar 11, 2011
Some of the keys are not working
you must have dropped the remote control. Get a replacement remote control
2/28/2011 1:31:52 PM • Samsung... • Answered on Feb 28, 2011
0answers
I cant find a code
Be the first to answer 2/21/2011 1:34:16 PM • Samsung... • Posted on Feb 21, 2011Be the first to answer
NO OTHER KEYS ARE WORKING
I suggust you troubleshoot it at www.samsung.com. Many problems are resolved using their step-by-step troubleshooting guide. I'm confident that after completing the required tasks, your remote will be working like new again. Good luck and enjoy your day!
1/28/2011 4:02:29 PM • Samsung... • Answered on Jan 28, 2011
Its is not fonctionning
first I would recommend to replace the batteries. Or simply put them out and back in, then test if it works. If not, replace for new ones.
Did it stop to work suddenly? Or did you drop it on the floor? If it is not damaged mechanically, then it should work with another Samsung TV, VCR, DVD or other Samsung devices...
1/13/2011 7:41:08 PM • Samsung... • Answered on Jan 13, 2011
0answers
BN59-00455A Remote Control only the volume buttons
make sure its on tv or vcr whatever u are trying to control
5/30/2010 2:38:05 PM • Samsung... • Answered on May 30, 2010
I am using cable, no box, I want to program in the
The TV might have an auto programing function, which should tune in all available channels that are being delivered thru the cable/from the cable company.
4/15/2010 6:14:51 PM • Samsung... • Answered on Apr 15, 2010
How do i tune my AA59-00310 remote into my TV
HI you will need the code for the model tv you have here is a link to the codes just reference the list by the tv you have and it will give you the code.
http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view_us.jsp?PG_ID=-1&AT_ID=5716&PROD_SUB_ID=0&PROD_ID=41
2/4/2010 4:49:18 PM • Samsung... • Answered on Feb 04, 2010
Why is my Samsung plasma tv screen becoming dark suddenly meanwhile it's on and still functioning
Hello. You can check HDMI cable in this case. If you're using an HDMI port that's not working well or has been damaged, it could result in a darker-than-usual screen. If you switch the cable or change devices and the TV is at a regular brightness, this is the case.
4/16/2024 4:37:19 PM • Samsung... • Answered 3 hours ago
2answers
Samsung 55 TV White vertical patches?
It sounds like you might be dealing with backlight bleeding or an issue with the LED backlighting in your TV. This can sometimes occur over time due to normal wear and tear or manufacturing defects. If it started as a faint single brighter section and has now expanded to four, it's likely a hardware issue. While it may not be an easy fix, contacting the manufacturer's customer support or a professional technician would be a good next step to diagnose and possibly repair the problem. If you'd like, you can share the pictures for a more accurate assessment.
4/14/2024 7:29:30 PM • Samsung... • Answered 2 days ago
Samsung BN59-00455A Remote Control Logo
Popular Tags
22 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
  • Samsung Televison & Video
Most Popular Question
trying program motorola cable box
  • Televison & Video
