20 Most Recent Daewoo FR-094R Refrigerator With Ice Box Questions & Answers
0answers
My daewoo mini fridge is
I have a problem with my daewoo fridge and freezer cannot get the right settings it is digital
1/17/2014 11:25:49 AM • Daewoo FR-094R... • Answered on Jan 17, 2014
0answers
0answers
2answers
I lost manual book for my fridge,(daewoo) How can
Go to this site and after open the page, click on down "Download Page"
http://www.pdf-manual.com/user-guide-instruction-owner-manual-daewoo-fr-094r%28ss%29-23349.html
Hope, you got it.
2/3/2012 8:41:50 PM • Daewoo FR-094R... • Answered on Feb 03, 2012
Ive got a brand new
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm
including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
9/5/2011 8:32:16 PM • Daewoo FR-094R... • Answered on Sep 05, 2011
Refrigerator is running but not
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
5/18/2011 3:05:41 AM • Daewoo FR-094R... • Answered on May 18, 2011
I have just replaced the
PRESS RESET WATER FILTER
3/8/2011 1:45:12 PM • Daewoo FR-094R... • Answered on Mar 08, 2011
THE FRIDGE DOES NOT START.THERE IS TICKLING NOISE
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
12/22/2010 12:59:00 AM • Daewoo FR-094R... • Answered on Dec 22, 2010
Freezer not freezing
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
5/27/2010 3:06:13 AM • Daewoo FR-094R... • Answered on May 27, 2010
My Daewoo FR 094R 2.7 cu freezer compartment is
if it cant make ice its junk
8/25/2009 6:19:49 AM • Daewoo FR-094R... • Answered on Aug 25, 2009
I need a freezer gasket for Daewoo FRG1830BRS. Searched, but can't find. Can you help? Thanks
notify manufacturer for a distributor or parts location near you --online search --an appliance repair shop
10/13/2023 12:00:52 PM • Daewoo... • Answered on Oct 13, 2023
Daewoo model FRS-U201ICS temperature selection lights aren't working. Fridge also seems to not be as cold. Any ideas?
You need a service call for that. All you can do is try a reset by unplugging for 5 minutes. It is likely to be low on gas or the control board has failed. Control boards are expensive so you need proper diagnosis and warranty.
3/11/2023 12:47:03 AM • Daewoo... • Answered on Mar 11, 2023
My Daewoo side by side refrigerator ice tray is not spinning over to release the ice how can this be remided
First thing I would do is to try a reset. Here's a YouTube video showing how to do this: Daewoo How to Reset the Ice Maker American Style Fridge Freezer and here's a generic "how to" guide on troubleshooting and repairing most types of refrigerator ice makers. Ice Maker Troubleshooting Guide
1/13/2023 2:44:15 PM • Daewoo... • Answered on Jan 13, 2023
Daewoo FR-094R Refrigerator With Ice Box Logo
27 questions posted
Top Daewoo Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Daewoo Refrigerators
Most Popular Question
daewoo mini fridge
  • Refrigerators
