20 Most Recent Daewoo FR-064R Refrigerator With Ice Box Questions & Answers
Before you change the switch, check the bulb connection, but first unplug it.
Daewoo FR-064R... | Answered on Jun 18, 2015
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Daewoo FR-064R... | Answered on Jul 17, 2011
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Daewoo FR-064R... | Answered on Jun 05, 2010
can you try to clean all the surroundings including the grill and the motor, and do a completely defroze then turn it on, and we'll see the result. ok
Daewoo FR-064R... | Answered on Mar 12, 2010
very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Daewoo FR-064R... | Answered on Aug 30, 2009
There should be a drain pan directly below the icebox which needs to be emptied from time to time. Some units have a drainpipe connected at the back, if yours has one, it may have become blocked.
Daewoo FR-064R... | Answered on Mar 13, 2009
Freezer/fridgeleakingwater/icefrozenin fridgeand or freezer, or leaks on floor
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a softflexabletubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Fix any gaps in the door seal.Pack out the seal underneath the areas where the door seal has the gaps. This can be done with a small strip of weather stripping, as shown here, or a bit of tightly rolled up paper under the door seal. Alternatively, you can heat the door seal up with a hair dryer to fix the gaps. This softens the door seal and allows you to stretch it.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs,particles , debris etc,you will have to clear it to get back to a normal mode of operation. A toothpick,pipecleaner, straw or a cotton bud can often do the trick.Another trick one can use is to connect a copper tube wirewith one end going intothe drain hole thenattachthe other end to the heater wrap it around heater a few times. That will take care of the drain problemwhen it comes to ice build up but not food build up.
Even a frost free freezer will still ice up at times in the areas away from the heateddefrost area and the drain linecan freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced.( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
God is so good: so this is why I give free advice so please thank him not me.
OTHER THINGS TO CHECK ARE THE DEFROST TERMINATOR AND THE HEATER ELEMENT FOR COBNTINUITY.
http://www.appliancerepair.net/refrigerator-repair-1.html
https://www.youtube.com/watch?v=HHr7bCO_IiA unclog drain hole
https://www.youtube.com/watch?v=H_DKNtgd5vI
Daewoo... | Answered on Mar 12, 2020
CALL A LOCAL REPAIR SERVICE. IT PROBABLY NEEDS FREON ADDED AND ONLY TECH'S ARE ALLOWED TO DO IT
Daewoo... | Answered on Feb 25, 2020
This could be the fan or the switch that controls that defrost cycle. The only way to tell is to use a volt meter to see if there is electric current to the fan motor. IF there is current, replace the fan.
Daewoo... | Answered on Dec 20, 2019
Du givre s'est probablement accumul? sur le ventilateur de circulation d'air, effectuez un d?givrage complet en arr?tant le r?frig?rateur et en laissant la porte ouverte pendant 48 heures; vous pouvez aider en soufflant avec un s?che-cheveux.
Daewoo... | Answered on Oct 26, 2019
I feel you need a repair man to look at it. If you play with it yourself it could cost you a lot of money.
Daewoo... | Answered on Sep 28, 2019
Daewoo FR-064R Refrigerator With Ice Box Logo
19 questions posted
Top Daewoo Refrigerators Experts
jasbo
jasbo
john h
roeb
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Daewoo Refrigerators
Most Popular Question
some times water flowing from bottom
  • Refrigerators
