20 Most Recent Kenmore 56983 Side by Side Refrigerator Questions & Answers
Door not closing
Usually that is an indication that your unit is not level. Unless one of you hinges got bent (someone riding the door).which would require the replacement of that hinge plate.
1/10/2012 4:28:03 PM • Kenmore 56983... • Answered on Jan 10, 2012
Fridge side not working, freezer side is
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
10/23/2011 11:48:08 PM • Kenmore 56983... • Answered on Oct 23, 2011
What should I do to shut down a kenmore side by
Basically their is not that much ya would need to do to it,just if it has icemaker be sure to turn off the water supply to it and that pretty much it.
GENE
10/18/2011 12:17:26 AM • Kenmore 56983... • Answered on Oct 18, 2011
The reifrigerator is running but not cooling
If both freezer and fridge section are not getting properly cool. The problem can be temperature not set properly or any of fridge or freezer door not closed properly and cool air is getting leaked out. This are basic possibilities which first needs to be checked. But if this possibilities are checked ok and still the problem is same, then its weak compressor issue. Click the link below for more details:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
This will help.Keep updated in more help required. Thanks.Helpmech.
10/10/2011 6:56:27 PM • Kenmore 56983... • Answered on Oct 10, 2011
Kenmore ice maker quit making ice. No signal to
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
9/24/2011 2:43:46 PM • Kenmore 56983... • Answered on Sep 24, 2011
My kenmore model 25353614300 ice make will not
NOTE: This
Leo Ponder
imufo2
9/16/2011 10:17:48 PM • Kenmore 56983... • Answered on Sep 16, 2011
Losing freezer and refrig cooling capability but
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
9/10/2011 4:15:34 PM • Kenmore 56983... • Answered on Sep 10, 2011
7 year old refridgerator not getting cold enough.
The condersor coil will be very warm to hot..not so much so it will burn you, yet very warm..the things that will make it very overly warm is if its clogged with dust or the condenser fan motor isnt running all the time the compressor is on. But it will normally be warm all the time the compressor is running..that heat is whats being removed from inside (the way refrigs. work is they remove the heat so when the heat is gone only cold is left)
GENE
9/4/2011 6:11:15 PM • Kenmore 56983... • Answered on Sep 04, 2011
2answers
Fridge is slightly cool but
NOTE: This
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
But is probably a common defrost problem The ice build up
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
8/20/2011 5:59:44 PM • Kenmore 56983... • Answered on Aug 20, 2011
Plugged in my fridge lights
NOTE: This
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
8/20/2011 8:20:54 AM • Kenmore 56983... • Answered on Aug 20, 2011
How does the ice maker work. I see a bin on the
Hello
No ,please don't do that. That tray collects ice cubes. System fill is automatic. Look for a wire arm of some kind and make sure it is in down or "make ice" position .Then give it plenty of time to cycle.
8/16/2011 6:41:49 PM • Kenmore 56983... • Answered on Aug 16, 2011
Water not dispensing from water dispenser on
NOTE: This
First I would check the fan in the freezer. Listen to see if it is running
Leo Ponder
imufo2
8/8/2011 7:52:19 PM • Kenmore 56983... • Answered on Aug 08, 2011
My frign is warm. It is making a noise that last
You should have replaced the relay. The clicking was the overload working doing what it should.
Before replacing the compressor relay, unplug the refrigerator to avoid an electrical shock hazard. Also, if the compressor uses a capacitor, it must be discharged.
The compressor relay can be accessed by removing the terminal cover box. The cover is held on by tension or with a retaining clip.
8/2/2011 9:30:52 PM • Kenmore 56983... • Answered on Aug 02, 2011
No cold air motor running
I'm Leo
This is a common defrost problem, The ice
is not being melted by the defrost system. he fan can't blow into ref.
Also check evaporator fan in freezer
If this was helpful please rate me
Leo Ponder
imufo2
Leo Ponder
Please VOTE FOR ME IF THIS WAS HELPFUL.
Please click for article
7/24/2011 9:10:45 PM • Kenmore 56983... • Answered on Jul 24, 2011
My Kenmore side by side refriderator has an issue
heatman101
7/18/2011 2:46:57 AM • Kenmore 56983... • Answered on Jul 18, 2011
I have a kenmore elite
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
7/8/2011 11:41:39 PM • Kenmore 56983... • Answered on Jul 08, 2011
My fridge has been having trouble maintaining the
Check your condenser grill to make sure that air can circulate around it.
If you are getting an ice build up on the inside of the freezer, it is more likely the defrost assembly. Suggest you turn off the refrigerator and then completely defrost it. When it is defrosted, then plug it back in. If everything starts to function again and freezes, then it is most likely your defrost circuit, which is an assembly. Not that hard to replace and not that expensive to do yourself. Just take your time and make sure the unit is unplugged from electricity.
6/1/2011 1:27:58 PM • Kenmore 56983... • Answered on Jun 01, 2011
My Kenmore Elite side-by-side has
You have a drain for the defrost water that is plugged. Once you have it defrosted you will see a drain trough and drain hole way in the back of the freezer. You can try blowing it out or maybe take a soft wire and try to clean it out. I have found that a piece of tubing from a fish tank works great. Of course I am asuming that you don't have water leaking from the ice maker. I'm sure you would have noticed that.Hope this helps.
4/29/2011 8:14:09 PM • Kenmore 56983... • Answered on Apr 29, 2011
Kenmore 56983 Side by Side Refrigerator Logo
35 questions posted
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Refrigerators
Most Popular Question
shut down kenmore side
  • Refrigerators
