20 Most Recent
Xerox Phaser 3200MFP/N Laser Printer Questions & Answers
LSU error message
That is the Laser unit. Not good. There may be a service reset process but you'll have to send or call it in.
Install toner and continuously beeping
If you have recently replaced your toner drum then probably the replacment drum is not matching the printer`s criteria or may be the repalcement drum is not the right to be intalled in. Check with service manual if you have got the right replacment or not.
Dark strip down center of page when coping from tray
There is a small strip of glass on the left side directly under the edge of the scanner, About a half an inch wide. It has something on it.
May be very hard to see, use a strong glass cleaner or some alcohol and a regular piece of paper to clean it with.
How to refill ink in hp 950?
Take your empty cartridge to any Costco or Fry's electronics and they will fill it for you at a great price
www.costcoinkjetrefill.com
Lsu error,before that not this problem on my
I would highly suspect a defective toner. What happens if you put the old toner back in - - do you get the same error? If you don't, then replace the toner. If you continue to get a lsu error, then your Laser Unit has a toner spill on the glass, or has gone bad and will need replaced.
Open heat error
Open heat error is caused by a bad fuser. Replace the fuser assembly.
Install to pc
go to xerox.com driver, put in your operating system type and download the proper driver
