20 Most Recent Samsung SCX-4521F Laser Printer Questions & Answers
Scan does not work
uninstall the printer on the computer and reinstall it. the drivers more than likely got corrupted. this means you will need the disk to reinstall.
3/11/2015 9:16:34 AM • Samsung... • Answered on Mar 11, 2015
Samsung SCX-4521f Document Jam with no paper jammed
u can clean sensor in your printer, i mean all sensors.
7/11/2014 7:49:21 AM • Samsung... • Answered on Jul 11, 2014
Paper jam, paper jam
YOUR PRINTER PAPPER SOLINOIDE COMPLAINT REPLACE SOLINOID
5/9/2014 5:01:02 PM • Samsung... • Answered on May 09, 2014
Paper jam
clean the pickup roller, or replace it
2/13/2014 9:57:20 AM • Samsung... • Answered on Feb 13, 2014
When I open the back door and shut issue is resolved
It may be a problem with the fuser exit sensor. Put it back in position.
2/13/2014 9:07:16 AM • Samsung... • Answered on Feb 13, 2014
Error toner empty
When you want to solve the error Reffiling the cartridge then change the Chips of the cartridge
8/27/2013 7:19:01 AM • Samsung... • Answered on Aug 27, 2013
0answers
Samsung SmarThru 4
Be the first to answer 5/16/2013 9:15:55 AM • Samsung... • Posted on May 16, 2013Be the first to answer
I have a samsung scx 4521f printer and wen i print thru it black dots on the paper appears..
This is likely to be either residual toner left from a previous leaking toner or that your toner has leaked in the printer. I would recommend running off 30 or so pages and seeing if the dots begin to disappear. Failing this either replace the toner and request a replacement from your retailer.
11/21/2012 3:39:54 PM • Samsung... • Answered on Nov 21, 2012
Printing blank pages
Reinstall the correct printer driver. Download current driver from printer web site.
10/17/2012 9:50:46 AM • Samsung... • Answered on Oct 17, 2012
Samsung toner empty
When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
7/28/2011 10:39:36 AM • Samsung... • Answered on Jul 28, 2011
2answers
Samsung SCX-5421F Laster Printer crashes my pc
Have you tried uninstalling and re-installing the software. Perhaps there is an updated driver for your system since you first installed it, or maybe yours is simply corrupted. I would suggest removing and reinstalling will solve the problem - if, in fact, that is your problem -I've not heard of this happening before.
Drivers are here if you need them:
http://www.samsung.com/ca/support/download/supportDown.do?group=printermultifunction&type=printermultifunction&subtype=monochromemultifunction&model_nm=SCX-4521F&disp_nm=SCX-4521F&language=&cate_type=all&dType=D&mType=DR&vType=&prd_ia_cd=06010300&model_cd=&menu=download
5/14/2011 2:08:00 PM • Samsung... • Answered on May 14, 2011
Samsung 4521f lsu error
The Laser Scanner Unit or LSU is what writes to the surface of the drum. The glass above the cartridge inside the machine could be dirty. The mirror motor in the LSU could be bad or needing cleaned so it spins better. Laser diode could be bad.
12/13/2010 11:39:44 AM • Samsung... • Answered on Dec 13, 2010
2answers
False paper jam
sounds like the rollers have gone bad. there are rubber rollers that pull the paper down the paper path. if they are worn, it may grab the paper but will not have a good enough grip on it to send it all the way through. you can see there are replacement rollers for this unit, but usually reconditioning them with some fedron on a q-tip in a well ventilated area does the trick.
10/12/2010 5:35:59 AM • Samsung... • Answered on Oct 12, 2010
How to set scx-4521f as default printer for tally
set the printer as default printer in windows. then load tally. tall automatically takes it as ur default printer
7/28/2009 4:39:57 PM • Samsung... • Answered on Jul 28, 2009
Fix firmware for scx4623f v2.01.01.01
Dear As the firmware locked and can not update without the serial no. Therefore you may try on line firmware generators, who are selling for money. http://www.firmwaregenerator.com/ Firmware fix Thanks.
9/27/2022 12:42:54 AM • Samsung SCX... • Answered on Sep 27, 2022
2answers
Samsung scx 3200 prints dark but xerox copies are so light that they cant be read
HI PLEASE CLEAN THE CCDUNIT .YOUR PRINTER CCD UNIT IS VERY LOTS OF DEST.AFTER CLEANING CCD THEY PRINT SAMSE SO REPLACE CCD UNIT WITH CABLE
12/2/2019 11:51:31 AM • Samsung SCX... • Answered on Dec 02, 2019
Samsung SCX-4828FN network printer wont install.
go directly to Samsung to download driverhttp://www.samsung.com/levant/support/model/SCX-4828FN/XSG-downloads
4/2/2019 1:09:33 AM • Samsung SCX... • Answered on Apr 02, 2019
Samsung SCX-4521F Laser Printer Logo
Popular Tags
20 questions posted
Top Samsung Office Equipment & Supplies Experts
Gary
Gary
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
SCX Samsung
  • SCX Samsung
Most Popular Question
scan not work
  • Office Equipment & Supplies
