20 Most Recent Brother HL-4050CDN Printer Questions & Answers
Hello !
If you want to print on canvas you need to use a plotter which use ink. An example is Roland or Epson. Personal i use Epson T5200 plotter and the result is awesome.
Brother... | Answered on Apr 16, 2017
REPLACE MAINTENANCE UNIT.PROBLEM WILL BE SOLVED
Brother... | Answered on May 06, 2016
Maintenance unit replacement code
Brother... | Answered on Feb 23, 2016
After you replace your drum , switch on the power, open the front cover and press GO and + key together
Menu Reset Parts life will appear , choose okay for drum unit or + for next part.
once accepted close the machine and it will reset the count to zero and print will show 100% or 99%
I hope this helps!
Brother... | Answered on Feb 10, 2016
Follow the below instructions to reset the drum.
After replacing the drum unit, keep the front cover open (make sure the power is on). Press and hold the "GO" button until all four LED's are lit. Once the four LED's light up, close the front cover. Make sure the drum LED is off. The counter is reset!
The green tab slides from left to right.
This cleans the croner wire. These wire also have a tedancy to break every often.
The drum unit will need to be replaced
Brother... | Answered on Oct 20, 2013
www.ask.com/Trouble+Shooting
http://www.ehow.com/brother-printers/
try one of the web sites and see if they can help you or maybe they can get you to one that will help you
Brother... | Answered on Jan 14, 2012
check printer spooler
Click on Start, Then Run
Type CMD in the run window and hit OK
A black box will come up. In that black command window type this:
net start spooler
Brother... | Answered on Sep 02, 2011
The cartridge needs to be replaced.
repairs to the cartridge are possible.
If there are any cartridge remanufacturing shops in your area
they will be able to repair the fault
Brother... | Answered on Feb 15, 2011
You should be able to download a driver for your printer and operating system from here:
http://welcome.solutions.brother.com/bsc/public/as/au/en/dlf/download_top.html?reg=as&c=au&lang=en&prod=hl4050cdn_all
If you don't know whether your operating system is 32-bit or 64-bit ; Open Control Panel : click on System > Look under System type.
There is a relatively new Driver Deployment Wizard that you may also be interested in downloading.
Trust this is helpful.
Brother... | Answered on Jan 04, 2011
Change icc profile for that printer
Brother... | Answered on Nov 18, 2010
Ensure that under the printer preferences the paper type you actually have is the type selected.
Go to printers under control panel, right click the printer :
Select Printer properties. Look under preferences or settings for paper size settings
Also look when you are printing from your program wether under "page setup" you have the correct paper type selected.
Brother... | Answered on Oct 11, 2010
Brother HL-4050CDN Printer Logo
48 questions posted
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
View Most Popular
HL Brother
  • HL Brother
Most Popular Question
brother hl 4050 cdn suddenly
  • Office Equipment & Supplies
