20 Most Recent Canon PIXMA MP610 InkJet Printer Questions & Answers
Good Day Paula!
You can reset the waste ink tank counter by a reset procedure. Bu this doesn't actually empty the waste ink tank itself and will allow you to continue printing.
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice, then release all buttons
5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
6: Press Power to set data
Canon PIXMA... | Answered on Oct 09, 2018
You've eliminated all other options, so obviously your printer is defective.
Call canon if it is under warranty, otherwise you will have to replace it.
Canon PIXMA... | Answered on Sep 04, 2018
Try removing all ink cartridges and printhead from the printer. Then, look inside the printer with a flashlight. Look into the right side of the printer and see if there is lots of ink gunk. Remove if any and try not to leave ink gunk on other printer parts. Turn printer off when removing ink gunk. Then after you are done cleaning, turn printer on and wait for it to command you to insert printhead. Do that and close cover. Then, insert cartridges when printer asks for them. Hope that helps. -Alex
303Electronics eBay Stores
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
Canon PIXMA... | Answered on Jun 07, 2017
Well, on a Canon printer, it means there is something wrong with the print cartrage.
Canon PIXMA... | Answered on May 29, 2016
If the cable got jammed it's jammed, you should disassemble the printer to remove it so not to do more damage. Quite probably you can't do it yourself, so take your printer to an authorized repair service
Canon PIXMA... | Answered on Sep 28, 2015
AC Power Adapter k30290 for Canon MP520, mp610, mx700, ip3500, ip4500:
http://forum.allaboutcircuits.com/threads/ac-adapter-k30290.93968
Canon PIXMA... | Answered on Sep 26, 2015
having no ink should not affect the running of a scanner
make sure the scanner usb and power leads are securely seated
the drivers for the scanner might have been corrupted
you might have to uninstall the scanner restart your computer then reinstall your scanner
if your printer/scanner came with an installation disc the drivers could be on it
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow Question/exclamation ? ! mark or a red X this will mean you need to install a new driver for this device right click to update driver
select properties again you will have the similiar options also have option to troubleshoot
hope this helps you
Canon PIXMA... | Answered on Feb 10, 2015
Hi
Follow this link and you can solve the problem quickly
http://tricks-collections.com/reset-printer-canon-mp140-mp160-mp180-mp210-mp220-mp460-mp470-mp500-mp510-mp530-mp600-mp610-mp800-mp820-mp810-mp830-mp960-mp970/
Canon PIXMA... | Answered on Jan 07, 2015
whenever you print greyscale what actually happen is that the printer mixes the red, blue and yellow to give the output in gray scale. See if you mix red, blue and yellow ink in the right proportion it gives you very close to black. just try to print your greyscale with your black ink finished you will still get the same print quality as when the black has ink in it. Or find a way seal the nuzzle of the black in and print your greyscale. check what results.
Canon PIXMA... | Answered on Dec 04, 2014
Hello friend, you can find the canon mp610 service manual in below link:
Canon mp610 service manual:
http://goo.gl/yB52u6
thanks
Canon PIXMA... | Answered on Dec 02, 2014
Take out cartridge put in a sandwich baggie and shake it; then re-install
Canon PIXMA... | Answered on Sep 26, 2014
Take the print head on and gently tap the nozzles on a paper towel.If you see all the colors and black then unplug the printer after the printhead is out and the carriage travels to the end (capped0
Wait 30 minutes and re-install the head.
This hopefully will make the printer believe it is a fresh unit
Canon PIXMA... | Answered on Aug 28, 2014
Canon PIXMA MP610 InkJet Printer Logo
206 questions posted
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
View Most Popular
PIXMA Canon
  • PIXMA Canon
Most Popular Question
usb cable jammed in paper feed mp610 way
  • Office Equipment & Supplies
