20 Most Recent Lexmark X646e Laser Printer Questions & Answers
Who ever thinks it is a software (as in computer driver) problem, you need to read what the problem was and the steps already taken to solve.
As you can see it is clearly to do with the cables and is a common problem with these copiers. We have three in shop right now with same issues!
The areas to look at are the cable connectors for damage, if you are technical you can open the adf plastic covers, and follow your scanner cables make sure no "pinching" has occured.
Other than that you can try factory reset, although this rarely works for this problem.
Refurbished units are retailing arond $350-400 all over google.
Lexmark X646e... | Answered on Jul 12, 2013
Check the following:
1. DC motor assembly.
Make sure all the motor plate mounting screws are tight.
2. Idler pulley - DC motor assembly.
Make sure the idler pulley is not binding on the pulley shaft. Check the pulley for wear. Check the idler pulley shaft on the motor mounting plate for damage or contamination.
3. Drive pulley.
Check the drive pulley for wear, binds or damage to the pulley or pulley shaft. Make sure the pulley turns freely on the pulley shaft.
4. Motor drive belt - tray drive belt.
Check the DC motor drive belt for damage. Make sure the belt is tracking correctly on the drive pulley, idler pulley, and motor pulley. Check the tray drive belt for damage. Make sure the belt is tracking correctly on
Lexmark X646e... | Answered on Dec 12, 2012
There are two flags on the back of the fuser, make sure the are moving properly and that the sensor itself has not been knocked off.
Lexmark X646e... | Answered on May 21, 2011
Usually you need to access the embedded web server on the printer by typing the IP address of the printer into your web browser address bar. This will open a window that will have all the settings available.
Lexmark X Office... | Answered on Oct 04, 2018
Please make sure the print head is seating properly as it should.
Another reason could be the contacts of the print head are not connecting properly with the main printer due to dirt. Remove the print head, clean the contacts of the print head and where it seats at the printer. hope this will help
Lexmark X Office... | Answered on Jul 17, 2016
Download from here Valerie
http://www.siliconguide.com/drivers/device/130/
Lexmark X Office... | Answered on May 08, 2016
Here is a manual for the same. In case you are unable to do it, please call on 1-877-805-1027 for further assistance.
http://www.lexmark.com/publications/pdfs/lexmarkj110/eng/clean.pdf
Lexmark X Office... | Answered on Jan 12, 2016
Yes it is true machine will print because its maybe need some type of repairing or the machine is not a printer of a photocopy
Lexmark X Office... | Answered on Dec 19, 2015
Lexmark X646e Laser Printer Logo
Popular Tags
9 questions posted
Top Lexmark Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
X Lexmark
  • X Lexmark
Most Popular Question
knocking noise when printing
  • Office Equipment & Supplies
