20 Most Recent Frigidaire Freezer 20.3 Cu. Ft. Frost Free Upright Freezer, AFFU2066D Questions & Answers
Is it freezing properly to zero degrees F? Noise could be bearing in evaporator fan motor, or compressor itself.
Frigidaire... | Answered on Sep 14, 2017
Had the same problem, I unplugged freezer for two days, pluged back up, has worked fine since.
Frigidaire... | Answered on Mar 26, 2013
You have a bad t'stat. Can you turn it it upborcdown.
Frigidaire... | Answered on Mar 01, 2013
Turn the unit off by the circuit breaker for about 10 minutes and retry the unit again.
Frigidaire... | Answered on Jul 24, 2012
Your defrost timer has stuck to on position, replace timer and all good or locate timer and spray lubricant into the dial and turn it several times with unit off, then try it after several hours, quick fix only but may last several years...good luck...Russ
Frigidaire... | Answered on Aug 23, 2011
The unit is not at correct temp, ""unsafe to keep food"". Needs service.
Hope that helps. Russ.
If you remove all the items from the unit and defrost it for 2 days with door open, on restart, should work fine..
Frigidaire... | Answered on Jun 12, 2011
I have had the same problem with my frigidaire/electrolux upright freezer... I am researching to see if there is a pattern. Once or twice a year for the past few years, the freezer defrosted itself. I found the outside of the unit to be VERY hot to the touch around the time that this occurred.
We typically unplug it for a chunk of time when this happens and then replug it. It has always begun working again.
Sadly, we have lost many groceries and have had to clean many bloody meat messes as a result of this. ANYONE buying this freezer should save their receipt... That way, they can return it or have it repaired when it fails. I hate to think of sending all of these failing monstrosities to the landfill... =(
Frigidaire... | Answered on Aug 18, 2010
Without any additional info, there are a lot of possibilities:
1. Condenser coil (underneath unit) is dirty and clogged.
2. Compressor is failing. (need A/C tech)
3. Metering device is clogged. (need A/C tech)
4. Refrigerant charge is low. (need A/C tech)
5. Door seal is broken (frost will form around door).
6. Defrost heaters are stuck on (replace defrost timer located underneath unit at front).
7. Condenser fan has failed (underneath freezer on back).
8. Evaporator fan (inside fan) has failed (ice will form on cooling coil).
This should get you started...
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Frigidaire... | Answered on Oct 13, 2009
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Frigidaire... | Answered on Sep 08, 2009
sound like the condenser fan motor by the compressor has stopped and the not allowing the proper cooling check that also you should have waited at least 6 hr upright before starting the unit
Frigidaire... | Answered on Oct 23, 2019
it is actually 'Sb', you are in Jewish Sabbath mode which prevents anything being turned on or off on a Saturday.
The display shows "Sb" or "5b" while in Sabbath mode.
SB Sabbath Mode
The Sabbath Mode is a feature that disables portions of the fridge and its controls in accordance with observance of the Sabbath and religious holidays within the Orthodox Jewish community. Sabbath Mode is turned ON and OFF by pressing and holding "?" on freezer temp and "?" on refrigerator temp for five seconds.
In the Sabbath Mode, the High Temp alarm is active for health reasons. If a high temperature alarm is activated during this time, due to a door left ajar, the alarm will sound for about 10 minutes. The alarm will then silence on its own and a red high temperature icon will display. The high temp icon will continue to display, even if the door is closed, until the Sabbath mode is exited and the icon reset. The refrigerator will function normally once the door is closed, without any violation of the Sabbath/Holidays.
https://www.google.com/search?q=Error+code+56+on+Frigidaire+upright+freezer
Here is a list of all the error codes.
Frigidaire Refrigerator Error Codes Fault Codes
Frigidaire... | Answered on Aug 01, 2019
Frigidaire Freezer 20.3 Cu. Ft. Frost Free Upright Freezer, AFFU2066D Logo
20 questions posted
Top Frigidaire Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Dennis Boxerman
Marvin
Marvin
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Freezers
  • Frigidaire Freezers
Most Popular Question
frigidaire freezer upright
  • Freezers
