20 Most Recent Samsung SGH-X820 Phone Questions & Answers
You can unlock your mobile using instruction..Get the following instruction here mobileunlockguide.com
Method 1:
1 - Switch ON your Samsung X820 with a NOT ACCEPTED SIM Card.
2 - Samsung X820 will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung X820 shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung X820.
3 - Compose : #0111*CODE#.
Samsung SGH-X820... • Answered on Jan 05, 2021
hi codes are the best method to unlock your samsung mobile .to get the codes visit theunlockarena here they ask the country and the network name to which your mobile then the imei number of your mobile .finally they send you the codes to unlock your mobile.
Samsung SGH-X820... • Answered on Jan 28, 2012
Hello
Thank you for using Fixya!!
The PUK code requested is an unique code to each phone. At the link below you will be directed to a tip i wrote on how to recover your PUK code.
Click HERE to navigate.
Kind regards
Lock123
Samsung SGH-X820... • Answered on Aug 17, 2011
Call your toll free service provider number from other number of the same service provider, they will provide your PUK code after inquiring about your mobile phone.
Samsung SGH-X820... • Answered on Aug 03, 2011
possible that the phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Samsung SGH-X820... • Answered on May 05, 2011
You can download software phone software to which will also have USB drivers for your phone.. Follow the link below to download:
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=UNI_UK&CttFileID=2653158&CDCttType=SW&ModelType=N&ModelName=SGH-I900&VPath=SW/200912/20091208185908968/Kies_1.1.5.9114.zip
and this
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=UNI_UK&CttFileID=2336126&CDCttType=SW&ModelType=N&ModelName=SGH-I900&VPath=SW/200906/20090625134600687/Phone_Software_Update-Windows_Mobile_IF1.exe
Samsung SGH-X820... • Answered on Apr 13, 2011
hi...
many mobile phone companies dont provide drivers for linux.
But there is a software i would personaly recommend to you. Actually its not a software, its a shell script.
Name of software is "Sakis3g". It can connect to mobile phones and other mobile devices which can be detected by linux kernel. You can use IR, Bluetooth, even USB cable to connect to your device.
You can use this software for the following
connect to mobile devices by IR, bluetooth, USB Cable
  1. Send and receive files between computer and device
  2. Access Internet from Device by Dial Up Networking
  3. Browse files on Mobile device
  4. Mount the mobile device on a user specified mount point or communication port.
    usually it mounts connected mobile device to /dev/rfcomm0. Through this port, you can communicate with the device .
Connect to USB Modem (Like Reliance DataConnect, TATA Photon, IDEA Netsetter etc.)
  1. ability to connect to any locked/unlocked USB internet Modems (Zero Devices)
  2. fully automated connection setup. No manual input is needed except to specify connection name.
You can find more details and download Sakis3g from this address
http://www.linuxconfig.org/mobile-broadband-connection-and-sakis3g
hope this will help you to solve your issue.
Samsung SGH-X820... • Answered on Mar 17, 2011
Call the service provider get the default master reset code and reset it....
Send it in for repair to Dr. Cell Phone. They provide service for all Samsung phone repairs.
Samsung SGH-X820... • Answered on Apr 05, 2010
save your files and contacts and do a hard reset by entering
*2767*3855#
but beware - all your data will be deleted so save everything you don't want to loose.
The car kit has to be with the latest bluetooth applications, therefore it is difficult to make an answer, then precise the technical specification of the kit to ensure that this one can read MP3 with bluetooth.
(in the phone itself, you can select MP3, but the kit and the phone should have A2DP profil to be able to work).
Samsung SGH-X820... • Answered on Mar 19, 2010
Hello. It is possible that your phone's memory is full. Take it into the phone store where they can check that for you. Regards, Joe
PS - kindly rate my answer as helpful. thank you
Samsung SGH-X820... • Answered on Feb 14, 2010
I suggest you test your charger with another similar phone like yours, if it charges with another phone, it means the charging port of your phone is bad and need to be replaced.
But if it did not charge the similar phone like yours, it means the charger is bad and need to be replaced.
I wish you best of luck.
Samsung SGH-X820... • Answered on Feb 06, 2010
This may not work on all Samsung phones!
THIS IS THE TEMP UNLOCK CODE FOR A SAMSUNG PHONE
Do this at your own risk:
Instructions
Press *#06# and write down your IMEI
Unlock Codes
Code 1: *2767*688 then your IMEI and then press #
For example *2767*688352708000828246# (Everything before the / for C225)
Code 2: *0141#
Code 3: 00000000 (8 zero's)
Entering the Codes
1. Switch your phone off. Remove the original SIM card 2. Insert another SIM card from an alternative network. Power up your phone. You should now see the "Wrong Card" message. 3. Type Code 1 into your phone, if this is entered correctly your
phone screen should now turn black and reboot itself. (C225 doesn't go
black but does reboot) 4. After the phone reboots the SIM card will be recognized and your
SIM will work. Be patient while your phone reboots and DO NOT press
any keys. At this point the phone is "Temporarily" unlocked.
5. Now at your idle screen type in Code 2 (*0141#) and hit the call button.
This should give you a message saying the phone is "Personalized". 6. Power off the phone and insert the original SIM, then power up. 7. At the SIM code prompt, it will ask you to enter a password. At
this stage enter Code 3. 8. After entering hit "OK" and your phone should complete initialization.
[/b]Instructions[/b]
Unlock Codes
Code 2: *0141#
Entering the Codes
any keys. At this point the phone is "Temporarily" unlocked. 5. Now at your idle screen type in Code 2 (*0141#) and hit the call button.
Your phone is now Permanently unlocked.
Another easy way is you put in a foreign sim put in the code *2767*2878# much easier and works just the same.
*2767*688 <your IMEI number>
Samsung SGH-X820... • Answered on Jan 09, 2010
you will need a data cable and the software cd that comes with the phone..theres an app mangaer there where you can sync the application to the phone
Samsung SGH-X820... • Answered on Dec 14, 2009
Samsung SGH-X820 Phone Logo
45 questions posted
Top Samsung Computers & Internet Experts
Jean Thiebaux
Jax Planet
Jax Planet
aliasger yq
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Computers & Internet
Most Popular Question
need unlock code samsung sgh x 820
  • Computers & Internet
