20 Most Recent Seagate 3TB Expansion External Desktop USB 3.0 Hard Drive Questions & Answers
doesn't seem to work in Windows 7
Seagate 3TB... | Answered on Jun 05, 2019
sorry but anything I tried with windows 10 failed and I went back to old OS thru the control panel and did a recovery .
Seagate 3TB... | Answered on Oct 27, 2015
http://www.seagate.com/files/staticfiles/support/seagate_external/Seagate_External_Desktop_Drv_QSG.pdf
Seagate 3TB... | Answered on Feb 21, 2015
Is the drive greater than 2TB and you are using a 32-bit operating system? If the drive is greater than 2TB, you need a 64-bit operating system to be able to access it as a single drive. Right click on My Computer. If it doesn't say, it is probably a 32-bit operating system.
Seagate 3TB... | Answered on Dec 17, 2014
Usually indicates the HDD has died
Seagate 3TB... | Answered on Nov 27, 2013
Stick it in the freezer for a few hours then try. It may only work for 5-10 minutes at a time so get as much off of it as you can. Also, contact Seagate and check if it's still under warranty. If so, ask them to RMA it.
Seagate 3TB... | Answered on Jul 13, 2013
Windows has a 2 TB MBR limit. So, I expect the TV does as well. What that is?
You need to ready new hard drives by formatting prior to use, and in your case partition as well.
Seagate 3TB... | Answered on Apr 16, 2013
Type diskmgmt.msc in search. There you will see all the drive, but may be already partitioned and or unallocated. A wizard may auto load if truly clean, but you can erase, create, delete, format, and partition just by right clicking.
2TB limit with 4 partitions on a single drive! Make then basic.
Seagate 3TB... | Answered on Jan 30, 2013
A single MBR physical drive is limited to 2TB in Windows. This is a common setup. You will need to break down and partition the drive in order to use it.
Seagate 3TB... | Answered on Jan 29, 2013
To help you out there I have found this easy setup guide for using an external hard drive on MXQ Pro 4K. This will help you for sure. Watch movie on MXQ with external hard drive. Hook Up External Storage to MXQ PRO 4K Android TV Box
Seagate... | Answered on Feb 21, 2020
Can you please provide more detail on the program you are downloading, the model of drive, and model of computer?
On the face of it, the program seems to be saying it is not compatible with the model of drive you have plugged in, or that the drive has been reformatted in a way that is not compatible.
Does the drive show up in the File Explorer / Finder of the machine?
after comment : ok, if you can drag and drop files onto it, then That means it is operational, and recognized by the system. The next question is why you can’t install the Seagate Desktop software. Where did you get the software from? Try going to Seagate Support and looking up your drive model, and doing a fresh download of the software they have for that model. Alternatively, there are other backup software packages available, Acronis, Aoemi, EaseUS, and others. You can find reliable downloads of utility software at downloads.com (CNET) or look for reviews from PcWorld or PCMagazine for their recommendations of the best paid and free backup software
Seagate... | Answered on Oct 20, 2019
SADLY MANY OLD DEVICES WILL NOT BE FOUND OR WORK WITH NEW EQUIPMENT ESP WINDOWS 10
Seagate... | Answered on Apr 17, 2019
I need controller for (English please)
in a computer,. or DVR or what, where does this HDD go?
Medalist 4310 (ST34310A) built in 1999 (20 years old ) why use any drive this old.
why? it's useless.
my wild guess, is this
you have a PC and ustated PC has SATA only ports (modern)
and this old old HDD is PATA drive, with ribbon cable wide.
and you think it can run on modern PC.
well they do sell cards (PCI-e) that fit and work.
4.31GB is the size , holds about 1 top movie .
are you going to boot from this drive, if yes, very complex answer I will skip here. (ask maker of card , if it can)
newegg.com has them all, any thing you can dream of , is there.
if you look.
https://www.newegg.com/Product/Product.aspx?Item=9SIA4UB8ZU9127&Description=pci-e%2c%20pata%20IDE%20card&cm_re=pci-e%2c_pata_IDE_card-_-17Z-0007-00AF2-_-Product
again, no PC stated, no OS stated.
nor of booting is needed to the PATA relic drive. from 1999.
Seagate... | Answered on Apr 08, 2019
unfortunately it appears that the internals are shot
if the funny noise is a clicking sound or squeal then the repair is a new hd unit as they are generally not repairable.
Seagate... | Answered on Mar 27, 2019
Tutorial to recover data from dead Seagate external hard drive
Step 1: Download & install iBoysoft Data Recovery on your computer.
Step 2: Connect the dead Seagate external hard drive to your computer.
Step 3: Launch iBoysoft Data Recovery and choose the dead Seagate external hard drive.
Step 4: Click "Next" to search for lost files on the dead Seagate external hard drive.
Step 5: Preview the searching results. After that, select the lost data and click the "Recover" button to get them back.
Step 6: Have a check to ensure all lost data have been recovered.
Should be careful with the data file deposited on the Seagate external hard drive. your Seagate external hard drive might be dead or corrupted. In this situation, you might need to rely on data recovery software to get back data and files on the dead Seagate external hard drive.
So you can rely on data recovery software to get back lost data and files when the Seagate external hard drive is dead and inaccessible.
Data recovery hong kong technician provide the Ontrack EasyRecovery data recovery services are able to recover data and files from accidentally formatting, corruption, virus attack, dead, system crash under different situations Seagate external hard drive on Windows Computer.
This data recovery software allows you to deep scan the dead Seagate external hard drive so as to find out almost all lost files with original quality in a short time. You can also rely on this software to recover files from dead/damaged Seagate external hard drive.
The software supports to get more recover: Seagate External hard drive, data file, documents, PDF, Excel, photos, music, and videos any HFS, HFS, FAT, ExFAT, and NTFS format based data and file and more.
It will recover data and file from all external storage devices that can be recognized by your Windows PC Computer/Laptop.
Hope this helps you get to recover all your lost data and files from your dead Seagate External hard drive.
Seagate... | Answered on Mar 26, 2019
Seagate 3TB Expansion External Desktop USB 3.0 Hard Drive Logo
22 questions posted
Top Seagate Computers & Internet Experts
Ekse
ChinthakaJ
ChinthakaJ
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Seagate Computers & Internet
Most Popular Question
get windows 10 recognize seagate 3tb
  • Computers & Internet
