its ok just POST TO HP PC or HP Desktop, with tag data.
for sure fixya does not have all 10,000 HP PC's listed nor will it ever.
H3LL even HP dont. (shock)
a desktop PC, (easy to fix , them all) no magic and ATX spec.
standards in play.
why not do the tests in the correct order.?
and do not put other HDD os in to your box, or the reverse.
that will not work.
first off the screen is black.
so you go in to BIOS, does it work and stay working there.??
that is first no the HDD, we play with OS later.
make the screen work first
see that VGA jack on rear of PC
try a different screen see if you can get to BIOS and hold there for say 5minutes, or more?
if that fails ?
this is an Emachine, with no video card, (or was added later,did you look>)
all Emachines, if you add at Video card, you must turn off the on MOBO GPU chip 6150LE
or it will get very confused. (which to use)
only you know if rear side, has x2 ,15pin VGA ports on the rear
if only one there, then its lock box stock, ORIGIONAL.
it only has 1 PCI-express 16x slot for added VGAG card.
if present remove it, and use the normal JACK
the goal is to get one of the 2 VGA jacks to work
that take owning 2 monitors, lacking a second, barrow one.
BIOS work now?
http://support.hp.com/doc-images/234/c00910084.jpg
BIOS hot keys (F1, F9,f10, esc, delete key)
the book on your machine tells you which hot keys work on your PC. and must be known by you or diagnosis goes to hair pulling.
http://jeepdied.com/look/puters/dead-screen.html
not yours but will look same with your exact model
try to know there are many sub models on all HP systems.
