20 Most Recent
Dell Optiplex 755 Ultra Small Form Factor Intel Celeron Processor 430 1.8GHz, 512K, 800... PC Desktop Questions & Answers
DELL OPTIPLEX WONT BOOT PAST WINDOWS LOGO
If the loading fails with an error message, try hitting F8 before the windows logo appears and from there Select "Safe Mode". If it works like that, one you're logged in Windows, perform a System Restore to an earlier point in time (when the computer worked).
Dell latitude e6400 wont boot has black screen
Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.If you able to start in the safe mode then Scan your computer for viruses. Some viruses can cause a black Screen , especially ones that infect the master boot record (MBR) or boot sector.- Update drivers for your hardware. black Screens are hardware or driver related so updated drivers could fix the cause of the STOP error.- Check for registry issuesIf it didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of black screen screen
REAR FAN FAILURE DELL
This is the rear fanReplacing a Hard Drive Fan
- Follow the procedures in Before You Begin.
- Remove the computer cover (see Removing the Computer Cover).
- Remove the hard drive (see Removing a Hard Drive).
- Turn the hard drive upside down, so that the hard drive fan is visible in the bottom of the drive bracket.
- To remove the hard drive fan:
- Lift the release tab on the back panel of the fan.
- Rotate the fan in the opposite direction from that indicated by the arrow on the back panel of the fan.
- Lift to remove the fan and its back panel from the hard drive bracket.
- Follow the instructions in Before You Begin.
- Remove the hard drive (see Hard Drive).
- Remove the hard drive fan:
- Remove the screw that secures the fan release tab to the hard drive bracket.
- Press down on the fan release tab, and then slide the fan towards the front of the computer so that its side tabs are free of the corresponding slots in the hard drive bracket.
- Lift to remove the fan from the hard drive bracket.
- Unplug the fan.
Reset media disconnected
Try these, 1)Check if the light on the router is solid green 2) Connect an ethernet cable from the router (any of the wired ports)to the computerIf it says media disconnected, Try with a different cable, Different port in the routerIf still not working , Hard reset the router (Insert a paper clip into the Reset pin hole, Press and hold it for 5 seconds)Let me if this worked
My screen is upside down and my mouse right and
On my shuttle, there is a combination of button to turn the screen 90 degrees to the left or right.
Something Like CTRL + ALT + Up Arrow
or CTRL + SHIFT + arrow or ALT + SHIFT + Arrow , to rotate to different
angle , also there are Viewing options in your display drivers. In the
ATI control panel, there is a tab rotation to rotate the desktop 90
degrees to the right or left or 180 °
Try this.
How i have dell desktop optiplex 755, which
go to c drive and look for folder called documents and settings inside you will find all the old users from your old windows. in each user file there are more folders one for documents,favorites,music,videos. copy the contents to your new document folder or make a new folder and put all the stuff in it.
