20 Most Recent Gateway GT5464 Refurbished Intel Desktop PC - Intel Pentium Dual Core E2140 1.6GHz, 1GB DDR2, 320GB Questions & Answers
How do i wipe it out and start it over to factory settings
factory defaults
Restart your computer now as soon as you hit the power button keep on holding Alt key & keep on tapping F10 key Alt+F10 it will open the recovery console select full factory restore and follow on screen instruction
(Note:this will erase all datas on the computer)
hope this helps you
2/27/2012 5:54:01 AM • Gateway GT5464... • Answered on Feb 27, 2012
Whenever i plug-in a device
Which OS are your running?
It is recommended to install first iTunes in your system before connecting your iPod to your computer.
2/28/2011 4:03:21 AM • Gateway GT5464... • Answered on Feb 28, 2011
2answers
My computer was not shut down correctly, the next
It says when you start the install that you are formating the hard drive and that all data will be lost. You can buy software that can recover some of the files if the sector they used to reside in hasn't been overwritten with another file. SpinRite is my software of choice for recovery. There are quite a few of them and some are way better than others. You can also send your hard drive to data recovery specialists but they will charge anywhere from $300.00 to $1800.00 usually.
12/16/2009 2:32:01 AM • Gateway GT5464... • Answered on Dec 16, 2009
Hooking up replacement mobo 946 GZT-AM V:1.0. Need
try here http://support.acer-euro.com/drivers/index.html
9/13/2009 5:00:59 PM • Gateway GT5464... • Answered on Sep 13, 2009
Gateway pc keyboard
yes you can buy a part for keyboard stand.what you are going to do is buy a new one, or still use the old one.
9/2/2008 8:43:02 AM • Gateway GT5464... • Answered on Sep 02, 2008
2answers
My cursor is gone. Gateway (not touchscreen)
Re boot usually fixes that issue.
5/1/2021 12:35:07 PM • Gateway... • Answered on May 01, 2021
Can't locate the battery in gateway zx6900-01e
why not ask at gateway (ACER is maker now)login and is best, tell them what you own.https://community.acer.com/en/search?adv=1&search=bios+password&title=&author=&cat=all&subcats=1&archived=1&tags=&discussion_d=1&discussion_question=1&discussion_poll=1&comment_c=1&comment_answer=1&within=1+day&date=the battery is deep inside, and must be replaced.only dismantling laps find it.what will be , will be on laptops.RTC 101 class:1:remove all bottom hatches find RTC Coin bingo.not found on AIO.2: remove keyboard see RTC bingo.(laptops only)3: if fail above,split the cases bingo RTC. coinbingo AIO PC.gateway and acer both are sux company. same. actually. NO SERVICE manuals offered.next time buy Dell.there are 4 kinds of RTC.1: none seen on note pads with main battery does same role.2: rtc coin obvious.3: RTC rechargeable even nasty NiMh, kind soldered down4: RTC with pigtails and wire plug.what you find is what you find. that is the rules.here. Gateway has no books worth squat.wow has 3 fans in this lil beast AIO.watching you tube russian take it apart now.All videos devoid of try full dissemble.the 6961 is here the COIN clearly seen,
3/24/2021 12:52:14 PM • Gateway... • Answered on Mar 24, 2021
How to add three missing drivers in a gateway DX4831 pc?
01-E or 07-C? there seems to be variations on that model. Our computer guru Larry, will probably know if there are MANY more. Do you need drivers for the computer itself or a device that you have added to the computer? https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk02vGYLXxrETayYXoTQq1L-c0eZ6tA%3A1614106243341&ei=g041YJeYFNiHwbkP6OKp8Ag&q=gateway+DX4831+drivers ..
2/23/2021 6:54:48 PM • Gateway... • Answered on Feb 23, 2021
On the Gateway kav60 laptop the screen still remains black even though everything else turns on and boots up. I hooked it up to an external monitor, and it shows the windows logo but then the monitor says no signal and turns off but the laptop stays running. I've tried all the solutions in this forum and my screen still won't come on. What do I do
Hello My Friend, I advised you to install Windows again through a bootable pendrive. You can search on youtube that how can you install windows through pendrive. If it not work then check motherboard. Thanks...
2/23/2021 9:40:54 AM • Gateway... • Answered on Feb 23, 2021
How does a payment Gateway work?
A Payment Gateway is a middle-man that securely takes money from your customers and sends it to your bank account. ... Merchant securely transfers order information to the payment gateway. The transaction is then routed to the issuing bank or the 3D secure page to request transaction authentication. https://www.quora.com/How-do-payment-gateways-work-technically
5/10/2020 10:37:47 AM • Gateway... • Answered on May 10, 2020
2answers
What is a 504 gateway error?
A 504 Gateway Timeout Error indicates that a web server attempting to load a page for you did not get a timely response from another server from which it requested information. It's called a 504 error because that's the HTTP status code that the web server uses to define that kind of error. https://www.howtogeek.com/367129/what-is-a-504-gateway-timeout-error-and-how-can-i-fix-it/
4/15/2020 10:07:29 AM • Gateway... • Answered on Apr 15, 2020
2answers
How to download music
it's easy to burn music into a cd
first make sure that your computer has a cd-r or cd-rw drive
second insert a blank cd-r or cd-rw into the drive
third find the music files you want to burn onto the cd
forth open my computer and start dragging the files onto the cd icon on my computer
once you have finished dragging your files open the cd on my computer and click on write files to cd,
3/31/2020 2:20:45 AM • Gateway... • Answered on Mar 31, 2020
2answers
MY NV59 BLU-RAY PLAYER PLAYS DVDS BUT NOT BLU-RAYS
You need to use blu ray software to play blu rays, i.e. PowerDVD 8 or later, as well you may need additional software such as AnyDVD to watch it.
3/12/2020 5:58:27 AM • Gateway... • Answered on Mar 12, 2020
2answers
DVD will not play, windows
Uninstall the media player,goto windows Market place and install windows media 11. its free and has all the new updates. Providing you have the correct system requirements. If not you can reinstall your old version at the same site and will probably have the required updates anyway.
2/14/2020 2:59:20 AM • Gateway... • Answered on Feb 14, 2020
2answers
How do I make Google my homepage?
On Internet Explorer to set home page as google.com, do the following steps:
  1. Press windows key + R
  2. Type "inetcpl.cpl" press enter
  3. In the homepage area of this window that appears.Replace it with "google.com"
  4. Click "apply" now close it.
  5. Internet Explorer should now open with google.com as long as you do not have malware on the computer.
How to set homepage as google.com on Google Chromehttp://www.google.com/intl/en_us/homepage/hp-chrome.html#instructionsHow to set homepage as google.com on FireFox
  1. Launch Firefox
  2. Click the top left "Firefox" button
  3. Click "options"
  4. Locate "homepage" area
  5. Highlight and replace current home page with "google.com"
1/31/2020 9:29:01 AM • Gateway... • Answered on Jan 31, 2020
Gateway GT5464 Refurbished Intel Desktop PC - Intel Pentium Dual Core E2140 1.6GHz, 1GB DDR2, 320GB Logo
Popular Tags
9 questions posted
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Michael Thomas
Michael Thomas
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Gateway Computers & Internet
Most Popular Question
wipe out start over factory settings
  • Computers & Internet
