20 Most Recent Google Samsung HM7000 Bluetooth Headset Questions & Answers
Samsung HM700 Bluetooth Headset's light keeps flashing red and blue and can't hear anything
Pairing is not the same thing as connecting. The LED will go solid when you complete the next step which is connecting. With headsets that is usually done via the audio source device.
3/8/2014 8:41:47 AM • Google Samsung... • Answered on Mar 08, 2014
2answers
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM • Radio... • Answered on Apr 04, 2024
The LED light display is not working on the face of detachable headset is there some button i can press to enable Firetail FT-8238D
I have the same problem. When o remove the interface the led is not flashing as per the instruction manual
3/27/2024 5:24:11 AM • Radio... • Answered on Mar 27, 2024
I need a manual for a TRONIC PLL 2023 radio. Can you help? Ray
http://www.manuals.group/results.php?search=TRONIC%20PLL%202023%20KURZ
3/26/2024 7:06:10 AM • Radio... • Answered on Mar 26, 2024
I have a Sonoff switch device which worked fine until I changed Broadband. Now the eWeLink cannot pair to the device??
Home - SONOFF OfficialSONOFF Official https://sonoff.tech Explore the innovative world of SONOFF, learn and chose about various smart home products, define your smart home,your smart choice!‎SONOFF Products · ‎Basicr2 · ‎ZigBee Bridge · ‎Home AUTOMATIONA Thorough Pairing Guide To SONOFF Smart Devices And ...SONOFF Official https://sonoff.tech > product-review > tutorial > how-to-p... How to quickly pair sonoff smart devices with ewelink app? This guide covers a complete and instuitive pairing instruction for all sonoff devices.Contact maker support. It is likely an issue with the new broadband router. The will know if there are compatibility issues..
3/24/2024 6:49:12 PM • Radio... • Answered on Mar 24, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please. Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity. https://www.google.com/search?q=KPG-790 ..
2/15/2024 3:06:45 AM • Radio... • Answered on Feb 15, 2024
Motorola KEM-P29923 2 Way Radio. It can transmit but cannot receive messages.
There are some ideas here, but also make sure Squelch isn't all the way up, that you aren't on some type of mute and that the Volume isn't at Zero. https://www.google.com/search?q=two-way+radio+transmits+but+does+not+receive https://www.google.com/search?q=KEM+P29923 ..
2/9/2024 1:12:05 AM • Radio... • Answered on Feb 09, 2024
New Motorola Mag One radio fully charged will transmit but will not receive. why?
This question edited for clarity. Contents of correction Question added here and Deleted. Did you read the Manual? It looks like it has Volume Buttons on the side and may be set to Zero volume? https://www.motorolasolutions.com/en_us/support.html https://www.motorolasolutions.com/en_us/products/two-way-radios/analog-business-radios/portable-radios/bpr40.html#tabproductinfo ..
1/18/2024 7:03:58 PM • Radio... • Answered on Jan 18, 2024
Pin for tzumi earpiece Bluetooth
i need a code for my ear piece
12/29/2023 7:49:36 AM • Radio... • Answered on Dec 29, 2023
I have an old Turner 253 mic & want to wire it to a road king 5640.Wires coming from microphone are shield ,white,green & black.?? 5 wires,4 pin?e
See following diagram. I think it is carbon type microphone and seems same as required by you. Wire color codes are Black and Red are switch to enable audio circuitry on remote device (Push to Talk Switch, Usually in transmitters), White and Green are audio signal and shield. Print 51.TIF (2 pages) (mypicsonline.net) Roadking 5640 require dynamic type microphone. Radio Code Definitions; Specifications - ROAD KING RK5640 Owner's Manual [Page 17] ' ManualsLib
12/15/2023 2:14:05 PM • Radio... • Answered on Dec 15, 2023
I have a Motorola MCS2000 Model 2 and I need to know how to factory reset this radio, and also where can I get the CPS.
Question edited for clarity, add maker and toss in some CAPS. The site does not do well on abbreviations 'CPS' - Customer Programming Software? https://www.google.com/search?q=mcs2000+UHF+2+CPS https://www.google.com/search?q=Motorola+mcs2000+UHF+2+reset+button ..
12/8/2023 3:36:13 AM • Radio... • Answered on Dec 08, 2023
What it the wiring for a D104 mic to president cb?
It depends on what model.
11/29/2023 11:20:13 PM • Radio... • Answered on Nov 29, 2023
I have a delta m2 desk mic need wiring code for my dx2517
White wire is RX or receive control. Red wire is TX or transmit control. Green wire is audio lead. Bare wire is audio shield or common.If for some reason your M2 has a different color code see the mic cable to M2 board connection.From the tab side it is audio(green), TX (red), shield, RX ( white). 20231128_083658-okr0t4vjl0t1arxzrnqfzwl2-d-0.jpg 20231127_164039-vllxa0swy2qm5gpzt2z0n3on-d-0.jpgscreenshot_20231129_165814_chrome-vllxa0swy2qm5gpzt2z0n3on-d-3.jpg
11/29/2023 9:52:46 PM • Radio... • Answered on Nov 29, 2023
My Pxa-h700 display not glowing properly
Return it to Alpine for service. The capacitor that feeds the display needs replacing. https://www.google.com/search?q=Pxa-h700+display+dim ..
11/3/2023 5:56:01 PM • Radio... • Answered on Nov 03, 2023
Google Samsung HM7000 Bluetooth Headset Logo
Popular Tags
5 questions posted
Top Google Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Google Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Google Radio Communications
Most Popular Question
samsung hm700 bluetooth headsets light
  • Radio Communications
