20 Most Recent
D-Link DES-3052P 48-Port 10/100 Managed Network Switch with PoE and 4 Gigabit Ports + 2 Combo SFP Questions & Answers
Static routing between two routers
You need to go to router B and configure a route to the 192.168.1.0 network with a mask of 255.255.255.0 and a gateway of 192.168.0.1.
Cheers!
I am not able creat
connect your wireless router with swithch with straight cabvle of lan. bt first connect your wifi router with any computerr so u can configure it as dhcp enabled.
Want D-Link Modem Driver for Vista Home Premium OS
it looks like your having a problem with sound and not in modem, you can download driver from internet just specify the manufacturer of you sound device in search or if your using a built-in sound device use your manufacture computer cd for drivers or download also if you the device maker.
I want to set up a server and 10 computer LAN without an internet connetin involved
just hook it up, you have no router involved so it will have no internet connection.Just connect all the PC's to the switch using straight through patch leads and assign the IP address manually as DHCP will not run on the switch.you don't need a default gateway address as there will be no routing. Just set the IP addresses to;192.168.0.1192.168.0.2192.168.0.3 and so on for each host on the LAN. Use the subnet mask 255.255.255.0 this will give you the address range 192.168.0.1-254hope this helps.
9815813107 tell me name and adrress
You can find the details of the operator and the state they belong to .the operators wont reveal the address and name of any mobile numbers only higher officials can only get those information.
In order to trace the operator name and state you can try this link
http://www.indiatrace.com/trace-mobile-number-location/trace-mobile-number.php
I hope this will help you if it does do rate the answer
Thank you
regards
lalith
I have a D-link DP-300U device that I can not access
Ethernet/USB Print Server it is for even windows 98 (OMG )
page 7 is setup.
NO OS stated by you, at all. why:?
page 3 is OS compat.
after reset the default address is
192.168.0.10
5volt power pack is NOT OPTIONAL.
1998
what did you read the free manual yet.
the last page shows printer compatibility list, does your match?
where would you find a printer that old working now.
crickets...???
my guess is 2003 year made. XP first release is that.
one manual for it stamped 2003 so is 17 years old
relic fodder for sure, recycle it is best.
first hit
https://eu.dlink.com/-/media/consumer_products/dp/dp-300u/datasheet/dp_300u_datasheet_en.pdf
RTM ! no 17 year old printer works today, not really.
How to change password D-Link router DIR-655
the manual is free , at dlink dot com
you push the reset button for long time per manual 15sec (iirc)
the release it and now all defaults are set.
per the manual, google dir-655 manual.
easy as pie if you just read the manual.
How can i reset a router
There's a reset button on the back of the router, it's a small button that you can press using a paper clip. Press it for 15 seconds to reset it.
Reset 1:
Press the reset button for 15 seconds at the back of the router while the router is on.
Reset 2:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and release the reset button. Then plug the power cord back in.
Reset 3:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and plug the power cord back in while the reset button is plugged in and count another 15 seconds release the reset button.
Hope this helps.
