20 Most Recent Eiki LC-X50M Projector Questions & Answers
Normally replacing the individual panels is not possible, they are factory alligned. But you can have a try, but takes a lot of patience to achieve a good convergence/ focus again. PLEASE check first the in and out polarized glasses for optical discoulerd areas or leaks.
Eiki LC-X50M... | Answered on Jun 07, 2014
in menu choosesetting option CEILING and set to ON.
Eiki LC-X50M... | Answered on Apr 17, 2014
is this after auto shut down ? check menu setting if this is set to READY, then it will wait until signal appears again at the input. You can set this better to "shut down", PJ will go to standby after cooling period and fans will stop.
several reasons : 1.check cables, if too long and poor quality you get echoes in signal and shadows in the projected picture.
2.feed the right solution to the projector and adjust in menu pc adjustment the item FINE Sync. native resolution is 1024 x 768.
did you clean the (blocked) air filters, is the bulb non- original, both can cause extreme heat build up, with shutdown.
one of the sub-powerlines have been shortcircuited by defective smd capacitors. this results in powerfail mode with leds blinking
green discolouring in white means lack of red.
probably wrong input setting or signal interruption on input- or mainboard. Check mainboard for smd capicitors with losses in value.
check the menu for proper video input signal type.
or system , like AUTO, PAL or NTSC
It does have a lamp timer but it is only accessible at start up if you hold down several buttons when you power the projector on. Eiki only supplies the info to dealers. I will see if I can post it later from my service notes.
Eiki LC-X50M... | Answered on Jul 24, 2012
Hello alaird2308,
Try to use a wider white board or screen to display the slides. If it does not still show the slide, try to move the projector closer a bit so you can get the full frame of the slides display. If that does not still help and it seems like the right hand side seems to be lost on display completely and is not showing on a wider board either, then it means the problem is from the convergence board of the projector.
There is a way to adjust the lens of the projector. Try turning the rim around the lens if that will adjust the display for you. But if that does not do it, then changing the convergence board will do the job for you.
Hope this information was helpful to you. All the best Elect_Comp
Eiki LC-X50M... | Answered on Sep 06, 2011
likely to be trouble. before it becomes a serious problem, better check first, or at service
Eiki LC-X50M... | Answered on Aug 14, 2011
there must be something loose inside. maybe the button panel.
Eiki LC-X50M... | Answered on Nov 18, 2009
i think is 76500 it works on mine
are you looking for a new internal ps, or a cord?
Eiki LC-X50M... | Answered on Nov 17, 2009
one of the internal fans might be broken, if even one of them stops, this problem will occure!
there are 6 fans in this projector.
check also if the metal handle is folded towards the lamp housing, if not it can stop the large exhaust fan
mounted on the lamp door on the rear side of the Pj.
Eiki LC-X50M... | Answered on Sep 25, 2008
HI there
Is there any on scren messaes before shutting down and when shutting down - which of the LED's on the unit is flashing and what colour ?
Eiki LC-X50M... | Answered on Apr 21, 2008
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
WhatsApp ID:+8613178867858
Skype:[email protected]
Wechat ID:+8613178867858
Email:[email protected]
Mobile:+86 13178867858
http://www.lampdeng.com
Eiki Office... | Answered on Jun 11, 2019
The Blue LCD has been damaged or the lens is discoloured with excess heat from an old lamp.
Eiki Office... | Answered on Oct 07, 2018
Eiki LC-X50M Projector Logo
27 questions posted
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
paul vail
Level 1 Expert
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Eiki Office Equipment & Supplies
Most Popular Question
green uhe white
  • Office Equipment & Supplies
