20 Most Recent Planar PR3010 DLP Projector Questions & Answers
0answers
Planar PR3010 turns on (steady orange Ready LED & steady green Power LED), but there is no light coming from the bulb
most probably the lamp ballast is defective ,you need a new one
3/14/2014 12:11:41 AM • Planar PR3010... • Answered on Mar 14, 2014
I have black spot on
you may need to clean it with a soft cloth that should help it may be dust
6/4/2011 8:19:09 PM • Planar PR3010... • Answered on Jun 04, 2011
Won't turn on
if it does not power up, then it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Take care.
4/9/2011 5:23:19 PM • Planar PR3010... • Answered on Apr 09, 2011
How to replace the lamp in it
buy a new 1,then look in the menu for it.
5/8/2010 3:44:27 PM • Planar PR3010... • Answered on May 08, 2010
Projector shuts off
try reseting the lamp timer and then replace the lamp if it works
5/8/2010 3:40:43 PM • Planar PR3010... • Answered on May 08, 2010
4answers
How many ounces of body lotion is 200 ML ?
200 ml is about 6.76 US ounces or about 7.04 UK ounces.
4/24/2024 8:53:54 PM • Office Equipment... • Answered 18 hours ago
How do these points equate to money?
No money ever! There is no payment made for answers on Fixya, points don't mean prizes, they are just for fun. ADMIN Andrew
  • Answers: 65,820 and not a penny per Answer.
Head over to www.justanswer.com they pay lots of money because they charge for people to ask a question. ..
4/19/2024 9:45:02 PM • Office Equipment... • Answered on Apr 19, 2024
Error code e000350-0002
'Make model (what it is)' is needed in questions like this, and in fact ALL questions!! But we can just guess.
Error Code Ir 3300 e350-3000 and e350-00002
Copytechnet https://www.copytechnet.com > ... > Canon May 1, 2018 - Put ALL the original boards back in the machine. Go to service mode level 2 & perform E355 clear. If this fails your machine is scrap. CANON iR2200 Error code E000350-001 Jan 22, 2007 error code :E0003-0002 canon IR 2880i Feb 5, 2018 Canon IRA C5540I Code E000354-0002 Sep 23, 2021 E000350-3000 on IRC4580 Sep 25, 2017 More results from www.copytechnet.com
Canon iR Advance 4245 - E350-0002
PrintCopy .info https://printcopy.info > code=E350-0002 Canon iR Advance 4245 ; Code: E350-0002 ; Description: System error ; Remedy: Contact to the sales companies. ..
4/19/2024 5:37:38 PM • Office Equipment... • Answered on Apr 19, 2024
E6 on my ISMART 500 trojan. How do i fix it please
This link is the best I can come up with: How to fix E6 & E7 on Trojan treadmill solved!! (youtube.com)
4/19/2024 12:27:09 AM • Office Equipment... • Answered on Apr 19, 2024
2answers
Error code Z08-1090
I need help I have an error on my ComColor 7050 Z08-1090
4/18/2024 11:40:08 AM • Office Equipment... • Answered on Apr 18, 2024
2answers
How do I fix this error SEr on conlog prepaid meter
Call your supply company.
4/17/2024 1:47:07 PM • Office Equipment... • Answered on Apr 17, 2024
Setting tax rate on Ativa KC-421
How to set up tax rate on Ativan 12 digit calculator
4/16/2024 1:16:37 AM • Office Equipment... • Answered on Apr 16, 2024
2answers
Tech solutions mod# TS8000 lost power while shedding
You posted to the Category 'Cars and Trucks'? shedding? Help in the link https://www.google.com/search?q=Tech+solutions+mod%23+TS8000 All questions need 'make model (what is is)' as first 3 words. Thinking that this might be a 'shredder' gives better results, we also have a Shredder Category, so I moved it. Shredders have an overheat thermal cut out and also a thermal fuse. It may reset itself. https://www.google.com/search?q=Tech+Solutions+TS8000+shredding+no+power ..
4/14/2024 7:19:19 PM • Office Equipment... • Answered on Apr 14, 2024
2answers
Tech Solutions TS8000 Shredder. Suddenly no power on mod TS8000
Edited for clarity. Full 'make model (what is is )' please first 3 words. Thermal cut out, thermal fuse, or burned out motor. They all have a suggested time limit for running them and is generally 20 minutes unless it is a commercial model and cost $1,200 to $4,000. https://www.google.com/search?q=Tech+Solutions+TS8000+shredding+no+power It looks to be a capable machine, but no parts from 'Shredder Parts dot com'. https://www.google.com/search?q=Tech+Solutions+TS8000 ..
4/14/2024 7:17:27 PM • Office Equipment... • Answered on Apr 14, 2024
Can you help me with code for mega power tv
Try "supervisor" as the username (no password).
4/14/2024 7:07:36 PM • Office Equipment... • Answered on Apr 14, 2024
3answers
I'm looking for a permanent job what can I do?
You should write good resume and then to search vacancies on job boards.
4/10/2024 2:36:35 AM • Office Equipment... • Answered on Apr 10, 2024
Canon imageCLASS MF3010 Black & White Multifunction Printer. How do I fix Error E2 please?
Question edited for clarity.
Canon imageCLASS MF3010 - Error Codes
PrintCopy .info https://printcopy.info > model=imageCLASS+MF3010 Error Codes List page 1 · Code: E000 · Description: Startup failure · Remedy: (1) Check the connectors of the Fixing Assembly. (J101, J1011, J552 and J702) (2) ... ..
4/6/2024 1:10:35 AM • Office Equipment... • Answered on Apr 06, 2024
How can i reset my sc553?
how to remove error code sc553-00 from my uninet 800
4/1/2024 11:25:06 AM • Office Equipment... • Answered on Apr 01, 2024
Planar PR3010 DLP Projector Logo
Popular Tags
9 questions posted
Top Planar Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Planar Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Planar Office Equipment & Supplies
Most Popular Question
planar pr3010 turns steady orange ready
  • Office Equipment & Supplies
