20 Most Recent Frigidaire FDB949GF Dishwasher Questions & Answers
My dishwasher is not cleaning the dishes on the
There is a pipe/tube that runs up the back of the inside of your dishwasher. This provides water for the top spray arm. The spray arm has a feeder tube that covers the pipe in the back. If for some reason the feeder tube has come dislodged, the water just drips back down into the dishwasher, never touching your upper shelf. My kids used to jam cutting boards and other large items into the lower shelf and in so doing, would dislodge the upper spray arm feeder tube. Just pull out the upper shelf and check to see that the tube is in the correct position. This should solve the problem.
If not, then the spray arm may have debris in it that keeps the water from being forced through the jets. You'll need to flush the arm with the spray attachment on your kitchen sink. I sometimes use tweezers or a toothpick to dislodge bits of peelings, paper, or bone that manage to get into the sprayer arm.
I hope one of these tips helps. If it does,please come back to fixya and rate my answer.
7/4/2011 6:11:41 PM • Frigidaire... • Answered on Jul 04, 2011
How do you fix the door latch?? will not latch so
You must take the screws out that hold the front panel on. Lean the inner panel away from the front and you will see the latch system .
11/25/2010 4:22:13 PM • Frigidaire... • Answered on Nov 25, 2010
I have a fridgidaire Gallery
Most likely the wash sump is blocked. Refer this diagram. You will have to open the sump (item 14) and look for the golf ball type device (item 58). This must be stuck in the drain position. This dishwasher uses common sump for wash and drain and the ball acts like a valve to direct water in the proper direction.
Not sure if you replaced the motor assembly because the motor was not working or because you felt it was linked to the water not circulating.
Hope this helps fix the problem. Please rate the solution to help fixya serve you better in future.
10/14/2010 12:14:00 AM • Frigidaire... • Answered on Oct 14, 2010
Water collects in bottom of tub after cleaning
does unit have a vent? if not open door after cycle
7/1/2010 5:43:35 AM • Frigidaire... • Answered on Jul 01, 2010
Dishwasher
its most likely a open/close solenoid to allow fresh water hot and cold in. the suction pump sounds like its working
4/18/2010 6:11:53 AM • Frigidaire... • Answered on Apr 18, 2010
Replacing detergent dispenser
take the door apart, the dispenser will pop out and you can rehok the new. make sure the seal is good
2/17/2009 9:08:26 PM • Frigidaire... • Answered on Feb 17, 2009
Frigidaire dishwasher sanitize cycle
A High Limit Thermostat is what it says. If the temperature goes over limit, it cuts power to the element. The temperature itself is controlled by an electronic sensor called a thermistor, or a standard 'thermostat'. Try a reset control board first. https://www.google.com/search?q=Frigidaire+dishwasher+Model+FDB1500LFC0+reset How to enter Diagnostics Mode https://www.google.com/search?q=Frigidaire+dishwasher+Model+FDB1500LFC0+run+diagnostics ..
6/15/2022 4:02:38 PM • Frigidaire... • Answered on Jun 15, 2022
Frigidaire FGID2466QF7A dishwasher touchpad non-responsive
I called Frigidaire with these codes. They said it indicates a power failure happened (during a wash cycle, I suppose) and to do a hard reset. A hard reset is turning off the breaker for 30+ minutes and then flipping the breaker back on. This kind of worked, but simultaneous to the error codes, the push/pull latch on my dishwasher got set to the closed position while the door was open, so the door would not latch. I feel that this was the initial problem that caused these codes. So in my case, I had to manually rotate the latch open with bent piece of wire, to get it into the correct position first. Then the hard reset seemed fix the error codes. I was able to start a wash. It's running now.
5/9/2022 11:12:02 PM • Frigidaire... • Answered on May 09, 2022
Frigidaire gallery dishwasher where is the circut board and what is the cost of a new one?
CALL A PLUMBER CONTROL BOARDS COST QUITE A LOT AND A NEW MACHINE WOULD BE THE WAY I WOULD ATTACK THE PROBLEM
7/18/2021 12:54:07 PM • Frigidaire... • Answered on Jul 18, 2021
Hi temp/heat dry lights flashing on a frigidaire dishwasher
Please read!! This happened to us and we paid money to have repair men come look and they didn't solve the problem. Your door latch is being caught on the bottom of your counter top. Pull your dishwasher out a half an inch and try again. It fixed our problem when we had this happen!
7/15/2021 2:57:50 AM • Frigidaire... • Answered on Jul 15, 2021
Frigidaire professional series some buttons don't work AND door won't open - how to troubleshoot?
sadly have not had that problem to know about a fix
6/22/2021 10:01:27 AM • Frigidaire... • Answered on Jun 22, 2021
2answers
How do I reset my Frigidaire dishwasher? eR light is flashing
Good Afternoon Sammy, thank you for your inquiry!
Based off the information you have provided you would like to reset your Frigidaire dishwasher because it is flashing "ER". The best way to reset your dishwasher is to flip the household circuit breaker off for roughly ten minutes. If you continue to receive the "ER" code it could be a possible problem with your main control board or keypad. I hope this is helpful information. -Matt
6/15/2021 2:14:12 AM • Frigidaire... • Answered on Jun 15, 2021
What does CL code mean?
The Frigidaire Appliances company designed most of its dishwashers to visually alert and display to users that the door is ajar, via the "CL" code. The dishwasher won't start pumping in hot water or rotating the spray arms until the door is secure.
How to Fix a Frigidaire Dishwasher Showing a "CL" Code ...
5/5/2021 2:28:18 AM • Frigidaire... • Answered on May 05, 2021
Dishwasher has to be reset each time I want to run it.
see the wiring diagram: you have a small short circuit. you must call to service tech or electrician for to eliminate problem.Otherwise you will another problem, and so on.5_9_2012_12_27_08_pm.gif
4/1/2021 10:43:29 PM • Frigidaire... • Answered on Apr 01, 2021
Frigidaire FDB949GF Dishwasher Logo
Popular Tags
17 questions posted
Top Frigidaire Dishwashers Experts
Mike
David Shaub
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Dishwashers
Most Popular Question
dishwasher
  • Dishwashers
