20 Most Recent
Frigidaire 24 in. FDB636GF Built-in Dishwasher Questions & Answers
My dishwasher won't drain the water
Check under your sink where the hose connects to the tail piece. I had this problem and the piece of the tail piece where the hose connects was stopped up.If the drain hose runs to an airlock mounted on your sink, then check it too.
What is width depth height specs
Good Morning Friend,
I see that you are looking for the width, depth, and height of the Frigidaire dishwasher, model# FDB636GF. The measurements are as follows:
Width: 23 7/8"
Depth: 24 1/4"
Height: 33 3/4"
Hope this is helpful.
-Best regards-
WP
Hey, i've got a Frigidaire 24 in. FDB636GF
I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher
SprayArms not Spinning
How to Buy
ApplianceParts OnlineA bad heating element causes many problems in dishwashers...
Dishwasher Problems The
HeatingElement not WorkingDishwasherMaintenance
DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
No water in spray arms
Since water is recirculated during the cycles, there is most likely a filter of some kind in the water path and that is probably clogged with debris.
Go to the Sears parts dept. and enter your make and model to see if they have your machine listed in their library.
If so, there will be a line drawing of the machine so you can locate where the filter is located and possibly reorder from that same page.
Sears carries or supplies parts for about every make and model.
Sears parts
Frigidaire Gallery dishwasher smoke coming out of
You need to replace the blower assembly, common prob after a few years of use.
Part number: 154226802 "Blower-Crossflow", suggested list at this time is around 30.00 us dollars.
To replace: TURN OFF BRAKER TO DISHWASHER
Open door, remove inside screws form panel and carefully remove panel up from door, blower is next to timer on control panel.
Frigidaire FGID2466QF7A dishwasher touchpad non-responsive
I called Frigidaire with these codes. They said it indicates a power failure happened (during a wash cycle, I suppose) and to do a hard reset. A hard reset is turning off the breaker for 30+ minutes and then flipping the breaker back on. This kind of worked, but simultaneous to the error codes, the push/pull latch on my dishwasher got set to the closed position while the door was open, so the door would not latch. I feel that this was the initial problem that caused these codes. So in my case, I had to manually rotate the latch open with bent piece of wire, to get it into the correct position first. Then the hard reset seemed fix the error codes. I was able to start a wash. It's running now.
I have a Fridgidaire Model Model # FFBD2406NW11B. The door latch will not spring back to the proper position.
Give it a good spray with this, or garage door lubricant and then work it well in. If you have any sliding windows, it is great for that as well.
Jig-A-Loo - invisible silicone-based lubricant and water ...
https://www.jigaloo.ca
Jig-A-Loo, an invisible silicone-based lubricant and water-repellent that doesnt stain or stink. It stops squeaks, lubricates, loosens and prevents rust and ...
Jig-A-Loo is unlike any other lubricant - it contains no oil ...
THE SUPER-PENETRATING ANTIFRICTION TREATMENT ...
More results from jigaloo.ca ยป
https://www.canadiantire.ca > pdp > jig-a-loo-lubricant-...
JIG-A-LOO Lubricant is a dry silicone-based lubricant that, unlike any other lubricant, contains no oil, grease, wax, petroleum distillates or detergent, so it ...
Rating: 4.4 ยท โ$7.39 ยท โIn stock
Hi temp/heat dry lights flashing on a frigidaire dishwasher
Please read!! This happened to us and we paid money to have repair men come look and they didn't solve the problem. Your door latch is being caught on the bottom of your counter top. Pull your dishwasher out a half an inch and try again. It fixed our problem when we had this happen!
How do I reset my Frigidaire dishwasher? eR light is flashing
Good Afternoon Sammy, thank you for your inquiry!
Based off the information you have provided you would like to reset your Frigidaire dishwasher because it is flashing "ER". The best way to reset your dishwasher is to flip the household circuit breaker off for roughly ten minutes. If you continue to receive the "ER" code it could be a possible problem with your main control board or keypad. I hope this is helpful information. -Matt
