20 Most Recent
Nextar P3 GPS Navigation System Questions & Answers
Need up date on maps
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Need manual for the x11-15302
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=654e30a291cfc737252332732815f4a0&modelid=23204612&q=Nextar+P3
Why does my gps nextar show a red light and not turn on
The GPS unit will not charge. I have plugged it
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturers website. Make sure that you back your files up first because when you do this you are setting it back to factory settings.
My X11 won't go into navigator anymore
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturers website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Cant get navigator to connect to computer
Try resetting the device it?s usually a small pinhole on the back or side of the device try holding that in for about 10 seconds OR Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Nextar X-11-15302 or P3
A generic 12 volt adapter should work. I replaced mine recently. They usually come with multiple sizes of round ends and can adjust the output voltage. The side of the device will tell you the polarity and the voltage required. If it says something like 5 V but the adapter only has 4.5 V or 6 V, select the closer choice. If they're about equal, select the lower one. It is better to have an under volt than an over volt.
My nextar p3 freezes up
Sounds like the sensitivity is whacked...can you hear the type sound. Mine does this sometimes and I solve it by using 2 thumbs and constantly push the settings icon, on each side. It will bring up the x for sensitivity...using the stylus tap gently and then twice to set. Hope this is what you were looking for.
Need to purchase an adapter for charging inside the house.
For an immediate and quick solution, your best bet is to go to Radio Shack, or hop on eBay, and purchase a car power outlet adapter plug.
Or, alternatively, you can go here on Amazon, and get one for $1.99 (pretty cheap solution if you ask me): http://www.amazon.com/dp/B001MK90HQ/ref=asc_df_B001MK90HQ762845?tag=the004-20&creative=380337&creativeASIN=B001MK90HQ&linkCode=asn
When I arive at my destination.
When you go to the screen to input the address it should have a recent locations option, if not you need to re-enter the adress.
