20 Most Recent PC Chips PCChips P17G Motherboard - V1.0, Intel 945GC, Socket 775, MicroATX, Audio, Video, PCI Express, 10/10 Questions & Answers
A canon P170-DH appears to be a printing calculator, not a computer motherboard. From the description you've given, it would appear a key is stuck in the down position or possibly a sticky liquid such as "pop" has infiltrated the keypad and caused a contact to be held "stuck" in the closed position as if one were continually pressing a key. Some moderate level of skill would be necessary to take the unit apart so that it can be inspected further. First the unit must be unplugged for safety. I suggest taking photos with a digital camera at different stages of the taking apart so as to show original key placement should they all just come out and get mixed up as the unit is taken apart. If the key contacts are comprised of a membrane type keypad, it may not be possible to repair the existing keypad and getting such parts as a keypad for a sub $100.00 calculator could become an issue. With shop repair rates in the range of 60$/hr, the demand for parts may preclude any availability as the issue of professional economical repair becomes unlikely.
PC Chips PCChips... | Answered on Sep 02, 2015
PC Chips PCChips... | Answered on Jan 20, 2013
You've installed the incorrect LAN card driver. Please verify if Lan card attached is correct to the driver youve installed. thanks
PC Chips PCChips... | Answered on Nov 07, 2012
If the PSU power supply units fan is not working the PSU is faulty
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have secure dust free connections and are not faulty or just replace them they could be faulty
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
make sure all leads that are attached to your drives dvd\cd floppy have secure dust free connections and are not faulty or just replace them they could be faulty a computer needs
power and data to travel through every working device and to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty power lead or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
make sure ram modules and cmos batteries have dust free secure seatings and cmos battery has charge some motherboards cmos batteries are soldered in
you might not have enough computer ram
not having enough computer ram will run your computer over its limits putting to much strain on the CPU central processing unit and can cause memory dumps
you might have to many programs trying to or accessing the internet at the same time
scroll to bottom toolbar (bottom of screen) right click select task manager
applications you will see whats running
if you see anything you dont need running select end now and you might uninstall that specific
program if you or computer does not require it to run and
some unnecessary programs that could be jamming up your computer
also under processes see what is ticking over in the background again if you see something you
dont need to be and users you will see who is using your computer
you might need to add more computer ram
if you're not sure if a module is right for your system use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line
from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
you should always ask for a guarantee on the compatibility of the ram before making any purchase
might be getting hot
check you CPU make sure its securely seated and has thermal grease
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
hope this helps
PC Chips PCChips... | Answered on Aug 08, 2012
hello gfmmon, maybe u not yet installed the motherboard driver.
the solution is install your motherboard driver to your computer: 1. insert motherboard CD to CD/DVD drive 2. open device manager (u can find it at control center or type devmgmt.msc on Run command) 3. in device manager window, you will see mark (it can be question mark or exclamation mark). 4. for every mark u need to update the driver. choose one of them, right click and choose update driver. follow the step then your driver will automatically installed. 5. use the step for every mark until all driver installed. if there is still some mark in device manager window then u need to install the driver manually. so u need to browse your motherboard CD (sometimes Audio driver and Chipset driver need to install manually)
NB: if your motherboard CD have autorun feature then it will more easy to install the driver. Click the autorun then follow the step..
hope this useful, regards.
PC Chips PCChips... | Answered on Sep 21, 2011
i dont know of this bios error but if a computer restarts all of the time for no apparent reason
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working hope this helps also it could be a dirty computer clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer
also check the Cmos battery and computer ram make sure they are securely seated
hope this helps
PC Chips PCChips... | Answered on Jul 19, 2011
http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?detailid=403&CategoryID=1&DetailName=Driver&MenuID=44&LanID=0
PC Chips PCChips... | Answered on Jan 27, 2011
Please find the mother board and processer correlation and once again try to install mother board cd drives..... to set your problem clear and try to install sound drives by searching via net
PC Chips PCChips... | Answered on Oct 22, 2010
andate a google y pone drivers para sonido p 17 y toda la informacion del chip y dale enter alli encontraras todos los drivers compatibles para lo que andas buscando
PC Chips PCChips... | Answered on Sep 22, 2010
the driver are not compartable with that chip
driver detective.com
PC Chips PCChips... | Answered on May 15, 2010
There is Problem with your Sound Card driver . 1st you check Your sound card driver and company name. If you want to install proper driver just follows these step.
  • Go to the Control Panel.
  • Double Click on Add Hardware
  • Add Hardware Wizard windows appear.
  • Click on Next
  • Then Check This Option (Yes, I have already connected the hardware) and click on next.
  • After this then select (Add a new Hardware device) from the list and click on next.
  • Then check the (Install the hardware that I manually select from the list(Advanced) and click on next.
  • After this select ( Sound, video and game controllers) from the list and click on next.
  • After this click on (Have Disk) and click on browse and select the driver location where you place your driver.
  • After this the driver is appears in the list you select the driver and click on next. Driver will be install.
  • Sound Card Drivers
PC Chips PCChips... | Answered on Mar 20, 2010
get a sound card or a new motherboard or download the drivers from the website(sound card and drivers are easy!)
PC Chips PCChips... | Answered on Nov 28, 2009
vcs tem o drve de audio da pchip Nome da Placa Mãe PCChips P17G
PC Chips PCChips... | Answered on Dec 25, 2008
Download the drivers from PCCHIPS website from following link:
http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?DetailID=399&CategoryID=1&DetailName=Feature&MenuID=44&LanID=0
Hope this solves the problem.
Best of luck ny friend..
PC Chips PCChips... | Answered on Dec 03, 2008
Yes it will support that processor. Good luck.
PC Chips PCChips... | Answered on Dec 02, 2008
sounds like sound card is bad ....
PC Chips PCChips... | Answered on Sep 28, 2008
PC Chips PCChips P17G Motherboard - V1.0, Intel 945GC, Socket 775, MicroATX, Audio, Video, PCI Express, 10/10 Logo
26 questions posted
Top PC Chips Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Muntejaya Ginting
Muntejaya Ginting
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • PC Chips Computers & Internet
Most Popular Question
suppotred gpu
  • Computers & Internet
