20 Most Recent
HD DVR Hd Portable Dvr With 2.5 Tft Lcd Screen Car Recorder Questions & Answers
I can not get power to come on?
Please be very careful not to lose these small screws................Had same problem...... really upset me because Manuel said there is a reset button. Start by taking out the battery. With the bottom of the unit facing you find the four very small screws holding the case together. You will need a Philips (cross) screw driver of size #0 ... small Jewelers (eyeglass) may do. The case opens very easy no tabs to deal with.... Ok on the right side of the battery case area you will find two dark round post with circles around them.... The larger one on the right is where the lower right screw came out of. The smaller circle is the reset button. Press gently to reset ... Plug in and turn on ..... If i have further trouble with this I will drill a hole in the case. Reassemble...
11/9/2021 9:18:48 PM •
HD DVR Hd...
Answered
on Nov 09, 2021
Need a manual I can print out
Sorry, but it would seem one would need first to know the brand and model. If this is a standard option in a car, then the make and model of the car would also do.
1/11/2016 3:40:27 AM •
HD DVR Hd...
Answered
on Jan 11, 2016
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
