20 Most Recent Intel Server Board S5000PSL - Motherboard - SSI EEB 3.6 - 5000P - LGA771 Socket - UDMA100, Serial AT... Questions & Answers
to get ur motherboard just go to the website of that ,,u can find it bt surfing
Intel Server... | Answered on Dec 06, 2008
OK you will need to enable the CPU serial number feature in the bios (if your bios supports it)
or
You can download the Intel Processor Serial Number Control Utility from Intel here: http://downloadcenter.intel.com/Detail_Desc.aspx?strState=LIVE&ProductID=24&DwnldID=823&agr=Y&lang=eng&PrdMap=24
let me know if this info helps
thanks
Note: Check bios first for option because the utility above may not work if the option is disabled in your bios. (if your bios does not have that option then utility should work fine by itself)
Intel Server... | Answered on Nov 20, 2008
Intel stopped supporting the technology after Microsoft began to support in in Windows 10 in native mode. You may be encountering legacy issues. Mirasoft is a way of broadcasting via WI FI without going through a router. You well may have to resort to an HDMI connection between the devices if compatibility issues persist. Or acquring a Mirasoft transmitter dongle.
https://answers.microsoft.com/en-us/windows/forum/windows_10-win_continuum-winpc/your-pc-does-not-support-miracast-despite-driver/57c49ed9-4bed-4ae1-a793-c008cecb30f8
Intel Computers... | Answered on Apr 11, 2020
It is patched, no hacks for it and pattern is random now the chance of getting 1 is like 80%, so that isn't really a pattern... I mean, i could type 1111112111311 as a pattern and you could try... of course, some of the 1s and 2s and 3s will be in different place as i placed them... In other words, there is no pattern, there is not point of the thread.
The probability of the lower numbers are higher, especially the 1s. But the rare numbers do offer higher reward rates.
If you got enough money, my strategy goes like this:
Bet 1 - 100(min bet) -> success -> continue
-> fail -> Bet 1 - 200 -> success -> reset bet
-> fail -> Bet 1 - 600 -> success -> reset bet
-> fail -> Bet 1 - 1800
So you get the idea?
Bet 100 on 1 first, if fail bet 200 on 1 again. If you win, you will win 100 which cover your earlier loss.
Basically just go 100, if fail go 200, if fail go 600, if fail go 1800. Always reset your bet to min 100 when you win a round.
Intel Computers... | Answered on Feb 07, 2020
Do you have a pair of matched RAM modules installed? Dual channel only really works with a pair.
Intel Computers... | Answered on Jan 09, 2020
you can either get a movie downlaoder to help you with this or you can findmovie on free movie sites.
here is the best for you: http://free-download-films.com/
Intel Computers... | Answered on Dec 20, 2019
no PC stated no reason for reset, "symptoms"
hd 530 is a very old,. CPU + IGPU.
no PC stated nor OS stated, is this windows 10 PC? y/n?
on w10, we go to device manager, click the 530 and right click it and update driver.
or remove it same way and be internet CONNECTED and reboot
and PnP runs and updates the 530 driver automatically.
or load the driver by hand here.
https://www.intel.com/content/www/us/en/support/products/88345/graphics-drivers/graphics-for-6th-generation-intel-processors/intel-hd-graphics-530.html
if there is PCI GPU card in the PC, then the 530 is not allowed to run. if you remove any PCI-e GPU card the 530 is ready to run.
Intel Computers... | Answered on Nov 28, 2019
Your message does not qualify as a question or query for a problem, try somewhere else
DO NOT MAKE THIS SITE WITH YOUR GARBAGE
Take your GARBAGE to another Side
Your message qualifies as SPAM
Intel Computers... | Answered on Oct 27, 2019
CEVEFAA, Your message does not qualify as a question or query for a problem, try somewhere else
  1. Shut down your computer, and then remove all the Peripheral Component Interconnect (PCI) devices.Restart your computer.If Windows starts successfully, shut down your computer, and then reinstall the PCI devices one at a time. Start Windows after the installation of each device. When you install a device that causes the issue that is described in the "Symptoms" section, remove that device, and then continue to install the other PCI devices.
  2. If Windows does not start successfully, remove one or more of the memory modules(RAM) that are installed in your computer. Leave sufficient RAM for your computer to start and run Windows XP.
Intel Computers... | Answered on Sep 11, 2019
google the intel site and put the driver details in the search bar
Intel Computers... | Answered on Sep 02, 2019
what does that mean.
posting out of context will get you in big danger to any PC.
try telling why first, so the help can be on the same page and not lie to you or cause DAMAge>
FIRST OFF ASK INTEL THIS.
The number is on the block and not raise its stamped,
means depressed stamps, like used on guns , ever seen a gun stamp s/n., same deal, very permanent too.
no like dates on coin raised, they are the reverse of raised
and never raised casting marks in the iron.
Intel Computers... | Answered on Aug 18, 2019
Your machine is rebooting itself while you watch a movie on it? Could be a couple of things. First, is this a laptop or desktop? When is the last time you updated your video drivers? If this is a laptop, does it get very hot just before rebooting?
Theories work like so:
1. older video drivers can be causing a cpu panic condition due to a bug. This is more common with PC games vs. watching movies, but still possible. Updating your video drivers may help fix the problem if that's the cause.
2. heat: if the computer overheats, it will reboot to protect itself. As for why it's getting hot--could be that your video hardware or cpu is getting too hot playing the movie. Could be that your cooling fans are bad. This is why I asked about the machine getting hot.
Another possibility is the need to update either your BIOS or hardware drivers.
Please post more info if you require additional help.
Intel Computers... | Answered on Aug 06, 2019
dell has a good deal on a studio desktop pc Core 2 duo quad core but even without the monitor its 550, then you have to add a good video card, integrated cards are garbage and so is intel, so the good ones are anout $100-300 intel and amd
to keep cost down you could also go with a core 2 duo (dual core) but stay away from celerons they **** for gaming
check staples/office max/best buy/circuit city or dell dot com for good deals
some dell studio's are slim desktops and unless you get a video card from dell they can be hard to find(near impossible)
Intel Computers... | Answered on Jul 11, 2019
NO PC stated
no OS stated
just a driver . from unknown company,
it is from chip maker ESS, from year 2006 , XP OS.
the maker has no sound drivers.
majorgeek has this, old set.
https://www.majorgeeks.com/files/details/ess_sound_card_es1938es1946_(es1969).html
its no good on todays new w10 windows.
best is buy a new card for $4 and end the legacy dogs.
Intel Computers... | Answered on Jun 30, 2019
Intel Server Board S5000PSL - Motherboard - SSI EEB 3.6 - 5000P - LGA771 Socket - UDMA100, Serial AT... Logo
4 questions posted
Top Intel Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Michael Thomas
Michael Thomas
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Intel Computers & Internet
Most Popular Question
ineed motherboard software intel
  • Computers & Internet
