20 Most Recent
Elektra Microcasa S1 Coffee Maker, Espresso Machine Questions & Answers
Replacing orings on glass level indicator
Not hard to do. Unplug and drain the water. unscrew the frothing wand and tip the machine gently over a sink to drain the water in the system. Then using a box wrench (don't use an adjustable wrench or poorly fitting tool) remove the water reservoir. THen you can unscrew the pressure gauge easily. At that point, the glass is exposed. Gently twist until it's free and pull the glass up and out. When you are replacing the white Orings, a small bit of olive oil on the inside will help you insert the glass back into the orings. Then replace all the components.
10/31/2009 12:26:58 PM •
Elektra...
Answered
on Oct 31, 2009
I'm looking for Elektra S1 Owner.s manual
if you have 2 gauges, one shows from 0 up to 3 bar second from 0 up to 16 bar.
- the gauge o - 3 shows steam pressure and it should be from 1.1 up to 1.5 bar
- if you have second gauge you look it during brewing coffee, it should be from 7 up to 9 bar(it shows the pressure of pump.
anyway becouse it is old machine you should compare the gauge with new one(ehamle for the steam attach to steam pipe one gauge and live valve open) than you will know if it is showing true values.
3/31/2009 9:06:32 AM •
Elektra...
Answered
on Mar 31, 2009
Elektra Microcasa a leva
You will need a 120/220V transformer for starters. That will make the Italian coffeemaker compatible with American outlets. The good news is that you can't do harm by plugging a 220 into an American outlet - it will just not give you enough power to run the machine.
I doubt that you can still get parts - I've seen used ones that still work on sale for anywhere from $1,000 to $3,000 - not cheap.
Here is all the contact info for Elektra - they are definitely still in business:
Elektra s.r.l. - Italian Espresso Coffee Machines
Via A. Volta 18, 31030 Dosson di Casier (Treviso) Italy - Tel +39 0422 490405 - Fax +39 0422 490620
Url: www.elektrasrl.com - Contact: [email protected] -
3/11/2009 3:07:44 AM •
Elektra...
Answered
on Mar 11, 2009
Schaerer SCP is not rinsing correctly
Check the Operating Temperature:
Ensure that the machine has reached the correct operating temperature. If it hasn't, the indicator light will be on. Wait until the machine is fully heated before proceeding.
Check for Ongoing Programs:
If a rinse or cleaning program is currently in progress, the cleaning button may be flashing. Wait for any ongoing programs to complete before trying to brew coffee.
Inspect the Brewing Unit:
Make sure the brewing unit is properly seated and not obstructed. The brew group should be in the correct position.
If the brew group overflows, it could be due to a blockage or misalignment. Remove the brew group, clean it thoroughly, and reinsert it properly.
Inspect the Coffee Spout and Drainage Area:
Check the coffee spout for any clogs or blockages. Clean it if necessary.
Examine the drainage area at the bottom of the machine. If water is running away onto the floor, there may be a leak. Inspect the drip tray and other components for leaks or damage.
Refer to the Operating Manual:
Consult the operating instructions manual for your Schaerer Coffee Club machine. If the above do not resolve your issues, you may have to contact Schaerer Services.
