20 Most Recent Acer X241Wsd Monitor Questions & Answers
No signal message on screen while working
what type of connection to the monitor are u using
1/2/2018 6:19:56 AM • Acer X241Wsd... • Answered on Jan 02, 2018
My X241w until recently required about 10 or more
It may have a lot of dying caps as shown in my pictures here: http://s807.photobucket.com/albums/yy352/budm/ACER%20X241W/
More damage will be done if the caps get real bad.
The size of this monitor is big but I find the picture quality is not too good.
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
3/19/2011 3:29:10 AM • Acer X241Wsd... • Answered on Mar 19, 2011
X241W Acer monitor: getting blank screen. When
If you are going to DIY and have proper tools and know safety precaution then please read on: Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
10/16/2010 12:47:28 AM • Acer X241Wsd... • Answered on Oct 16, 2010
My monitor X241W flashes the ON/OFF LED, and
It may be in the safety shutdown mode if it sensing too much current draw. No short circuits in the inverter board. Plug it ino the wall out let and do not activate the power switch so the power supply will be running without having to power up the inverter board, if the 24vd is OK in the power supply then you may jave problem in the inverter board. How does the DC voltage on the secondary power supply side? Bad caps can look normal but it can have high ESR (Equivalent Series Resistance) which is a no no for switching power supply. Post back with more info. So far I cannot locate free service manual download for this model.
8/30/2010 9:24:25 PM • Acer X241Wsd... • Answered on Aug 30, 2010
My acer monitor
I have answered this in other threads but to reiterate....
The Gray rectangle "No Signal" I use a Power Strip and Turn off as soon as it cycles back to Normal screen. It is so much easier then to unplug and Plug back in when it does happen.
As for the Newer Problem(s) and I too have had mine for only couple of years... Copied from Previous post
This is not a Fix to the Problem, If you read some of the other "fixes" that relate to this you will see that it is a more serious problem and one that Acer should Do the Honorable Thing and have a Recall.
I actually went in side on three of the Same Monitors and one that was a 21 inch and found the problem is "HEAT"
You can see where a Board actually shows Browning on the Circuitry I am Going to try to order a new board P/N:AS08B360411.
I will update as soon as work is completed.
3/18/2010 10:58:38 AM • Acer X241Wsd... • Answered on Mar 18, 2010
Monitor ACER 24" stop display after few seconds
3/18/2010 10:50:01 AM • Acer X241Wsd... • Answered on Mar 18, 2010
Monitor comes up shows "acer" then says no signal and goes black
This Problem is Acer(s) Monitors. Though it is a nuisance one fix That has work for many is the Unplugging after it goes back to Good (viewable) screen.
I have hooked mine up to an inexpensive Power strip to make it easier for me and just turn off at time indicated above and Viola Simple is as Simple does :)
3/18/2010 10:48:31 AM • Acer X241Wsd... • Answered on Mar 18, 2010
2answers
On startup monitor begins warm up for a second and
3/18/2010 10:41:28 AM • Acer X241Wsd... • Answered on Mar 18, 2010
When turn on it flashes for about 1 second, then
this is probably a data problem...
try to access to monitors on-board menu (usually a small button beneath the screen)
if the menu comes up i would try in this order
a new vga cable
connected monitor to a different pc/laptop
wiggle your video card
try friends monitor on your pc
good luck, rate if useful
10/27/2009 9:47:14 PM • Acer X241Wsd... • Answered on Oct 27, 2009
My monitor went dim and goes black after a few
I don't know what OS you have but there is a power management setting you might want to check. Most likely the monitor is set to go quickly into sleep mode at inactivity. Alternately I don't know what monitor you have but it might be a backlight Issue as well
1/7/2018 6:14:08 PM • Acer X Computers... • Answered on Jan 07, 2018
3answers
Blu ray wont play
That machne does not have a bluray drive & that is the simple reason why you can not play a blu ray disc. This is what your drive supports.
Plays Standard or multiregion DVD's & Audio CD's. Records DVDs 8x & CDs 24x & Dual Layer Super Multi. No Bluray or HD DVD,
If you were sold the machine as a bluray laptop then take it back & demand your refund.
11/29/2022 3:56:47 AM • Acer Computers &... • Answered on Nov 29, 2022
4answers
The Presentation .pptx is incomplete
The MS Office PowerPoint repair tool reads and extracts presentation data from corrupted .ppt and *.pptx files. https://powerpoint.recoverytoolbox.com/
11/16/2022 4:29:19 PM • Acer Computers &... • Answered on Nov 16, 2022
Acer aspire m5-581t 6405 won't boot up
The BIOS is reading that you have no start up data in the systeam. You will need a set of windows with the code when you put the disk in then power up computer it should start asking questions Good Luck Mike L.
11/2/2022 9:17:05 AM • Acer Computers &... • Answered on Nov 02, 2022
2answers
How much are the laptops
Laptops range in price from about $200-$300, up to about $5000. You can get a netbook or a tablet from about $100. Students can sometimes get discounts through their school or through the manufacturer.
10/14/2022 12:22:47 PM • Acer Computers &... • Answered on Oct 14, 2022
I have an Acer S240HL Abid monitor with the back light going out. Is it the LEDs or the inverter board?
I have the exact same problem with S240HL, caps look good, sometimes lower left corner, or lower right corner or both. Did you ever find a fix for the problem?
10/14/2022 12:16:54 AM • Acer Computers &... • Answered on Oct 14, 2022
Acer X241Wsd Monitor Logo
12 questions posted
Popular Products
Steve Sweetleaf
Steve Sweetleaf
shadow
View Most Popular
X Acer
  • X Acer
Most Popular Question
startup monitor begins warm up second
  • Computers & Internet
