20 Most Recent Behringer C-1 Microphone Questions & Answers
C1 not working
Sounds like your Phantom power supply may be defective. To be safe, 1st try moving AC plug for Phantom supply to another outlet as sometimes "sharing grounds" can be a problem. If this doesn't help, try using another phantom power source ...many PA mixers have built-in phantom power. If the buzz disappears with a new one, it will be a filtering issue (capacitors) with the old phantom supply.
5/27/2014 3:42:27 PM • Behringer C-1... • Answered on May 27, 2014
2answers
Wire Colour coding for Behringer C1 Microphone
It is likely that the brown goes to pin 1 (ground/shield phantom -) as well as the black.
Red is likely to go to pin 2 (across from 1)(signal +)
and the orange to pin 3 (signal -)
12/30/2013 11:20:29 AM • Behringer C-1... • Answered on Dec 30, 2013
Hello so i got a new c-1 and about 2 weeks ago i
The C-1 is a condenser microphone, which means that it requires phantom power in order to function. Most M-Audio products will provide phantom power, so it would just be a matter of pressing the button or switch (it might be marked +48 or +48v). If your M-Audio device doesn't have such a button or switch, you'll need to upgrade to a preamp that does in order to use that mic. If you do turn it on and it still doesn't work, there's something wrong with either the cable or the microphone itself.
12/22/2013 5:23:28 AM • Behringer C-1... • Answered on Dec 22, 2013
Can a Behringer C-1microphone connect directly into a computer and record? What other equipment will I need? Thanks
you could get away with getting a small behringer mixer that has +48V of power for the mic. Put your mic cable into there and then run straight out using 6.5 (guitar) cable to your computer. you may need some connectors to convert your jack.
2/5/2013 12:15:00 AM • Behringer C-1... • Answered on Feb 05, 2013
2answers
How can i stop my
The wire that is not connected is probably the ground wire. Reconnect it and your humming should stop.
1/14/2013 5:44:16 PM • Behringer C-1... • Answered on Jan 14, 2013
How to i test to see if a mic element is still working
The easiest way is to plug it into a mixing desk or microphone input on a sound card. However, whichever you do you will need phantom power as this microphone requires it.
8/28/2012 11:45:23 AM • Behringer C-1... • Answered on Aug 28, 2012
Hi I bought a Behringer
That's a condenser microphone. Make sure you have on your phantom power. Should be a button or switch somewhere on the mixer ( individual channel or switch by power switch or in master section for +48v). All condenser mics require this.
8/26/2011 3:33:07 AM • Behringer C-1... • Answered on Aug 26, 2011
0answers
The c-1 mic is not
With the C-1 it does require phantom power to work. On the board your using make sure the +48(phantom power) button is pressed in and it should be golden.
If it's the C-1U, the drivers must be installed first. http://www.behringer.com/EN/Products/C-1U.aspx
Good Luck, Cody J.
12/17/2010 8:50:46 PM • Behringer C-1... • Answered on Dec 17, 2010
I tried to play my behringer microphone through an
I don't know what you mean by "audio box".
This microphone REQUIRES "phantom power" and if your "audio box" does not provide that or the switch on it is set to phantom off, the light will not come on.
8/4/2010 3:24:54 PM • Behringer C-1... • Answered on Aug 04, 2010
I have problem with c-1 cause it produce high
Go to this site:http://www.behringer.com/EN/Products/MIC800.aspx#documentation Scroll down the left side to manuals. You can get one in whatever language you are most comfortable with.Here is the place for your microphone:http://www.behringer.com/EN/Products/C-1.aspx Your microphone needs phantom power which is a feature on the mic800. Just remember to use a good XLR balanced microphone cable or the phantom power won't work and you could damage something. Hope this helps.
11/29/2009 6:49:48 PM • Behringer C-1... • Answered on Nov 29, 2009
Behringer ha 8000 transformer replacement help.
Toroid Transformer is used in power supply not with headphones out. Headphones out are directly connected with headphone amplifier IC. (Note that the difference in 4700 and 8000 is number of channels. Rest of the circuit diagram is same). Behringer HA 4700 PowerPlay Pro-XL ' SynthXL - FREE Service Manual
12/19/2023 2:37:58 PM • Behringer Audio... • Answered on Dec 19, 2023
Behringer C-1 Microphone Logo
24 questions posted
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Behringer Audio Players & Recorders
Most Popular Question
c 1 mic not
  • Audio Players & Recorders
