20 Most Recent MTX Thunder 6152 Car Audio Amplifier Questions & Answers
http://www.mtx.com/caraudio/archive/NDM185.pdf .... go to this link for more help, it is the owners manual
MTX Thunder 6152... | Answered on Jan 30, 2011
its capable of a minimum of 2 ohms; the sticker on the bottom should say
MTX Thunder 6152... | Answered on Jan 23, 2011
first thing to do is smell it, second thing to do is to take the bottom covor off to visually check for damage, third is to bench test it with a car batter, a regualar 4 ohm speaker that you know works, and a cd player with rcas going into the amplifer, this is the best way, then if it works on the bench, it must be something with your wiring, bad ground, loose battery clamp, etc.
MTX Thunder 6152... | Answered on Aug 09, 2010
okay, first thing i would do is turn down your gain. Sounds like you are over working the amp thats wire your amp gets hot and shut off, it's going into protection mode. Is your amp enough for your subs. Some times not getting enough power to your amp might do this too. But if your subs wattage is way over your amp watts, you need to upgrade your amp. Also check your subs and see how the are wired up with the ohms, And see if your amp can take a 1 ohm stable load or how ever it's wired up at. hope this was helpfull.
MTX Thunder 6152... | Answered on May 13, 2010
If you have to ask, take it to a repair shop.
MTX Car Audio &... | Answered on Dec 28, 2020
power to-battery plus
ground;;
remote''
MTX Car Audio &... | Answered on Nov 05, 2019
THE GREEN LIGHT SHOULD SHOW WHEN AMP IS POWER UP AN RED WHEN IN PROTECTION MODE
MTX Car Audio &... | Answered on Sep 12, 2019
Try eBay Often available there from private sellers
MTX Car Audio &... | Answered on Aug 25, 2019
I was having a similar issue. I checked every wire from the battery to stereo to amp, checked the ground, pulled the stereo to double check the wiring was all correct. Everything seemed good so I thought it had to be my battery not putting out enough power. Tested it and it was good. What it turned out to be was the connection from the power cord to the battery. It had a tiny bit of built up corrosion that was making the amp go into protect mode. Cleaned it up and hooked it back up and has been golden since.
The link attached is pretty straight up on what you need to check for different circumstances. I'm guessing it's a low voltage issue. Good luck
MTX Car Audio &... | Answered on Aug 23, 2019
Check the wiring 1st then go down the line...Check speaker connections..Look at your power,ground and remote wire hook up
MTX Car Audio &... | Answered on Oct 18, 2018
Since this is a vintage item, the cost is whatever the market will bear, wherever you're trying to sell it. I would suggest checking current prices on sites such as eBay, where one is currently being offered to sell at $200, while another is being offered for $90. The perceived value is what determines the selling price at this point, because the MSRP is long irrelevant by now, being that it's a discontinued item.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
MTX Car Audio &... | Answered on Jul 08, 2017
MTX Thunder 6152 Car Audio Amplifier Logo
5 questions posted
Top MTX Car Audio & Video Experts
Marvin
Marvin
Tom Chichester
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • MTX Car Audio & Video
Most Popular Question
mtx thunder 6152 r capable 1ohm
  • Car Audio & Video
