20 Most Recent MTX Thunder 81000D Car Audio Amplifier Questions & Answers
Solicito diagrama amplificador thunder 81000d
hola tengo una potencia mtx 81000d necesito ayuda escribanmen fachaaguiararrobahotmailpuntocom
3/6/2014 4:20:55 AM • MTX Thunder... • Answered on Mar 06, 2014
My amp cuts out after
There could be two things wrong. make shore ur ground is same size an ur power or ur amp isnt pushing the right watts for ur speakers
6/14/2011 7:02:54 PM • MTX Thunder... • Answered on Jun 14, 2011
MTX Thunder series 7402 Amp cutting out at Hard pound.
Most likely the ohm load is too low, if you have the subs wired in parallel rewire them in series and see if that resolves the problem. if not then you do not have enough battery power to support the draw that the amplifier pulls. if the vehicles voltage drops below 11.5 volts the amplifier will momentarily shut off, similar to how the lights in your house dim when the a/c cuts on due to the sudden power draw. hope this helps. p.s. if you cant afford another battery right away, lowering the crossover frequency to around 65hz will greatly reduce the amount of current necessary to keep the amp pumping. (in my opinion it sound better that way anyhow.)
9/6/2010 3:29:18 PM • MTX Thunder... • Answered on Sep 06, 2010
MTX 81000D amp doesnt work
Have you checked to make sure your sub is wired correctly to the amplifier?
5/31/2010 11:26:08 PM • MTX Thunder... • Answered on May 31, 2010
I have a thunder 1000d it was intermintent coming
if you are in the tallahassee,fl area call 850-339-1130 Capital Audio & Electronics Repair we repair all namebrands & all models
3/20/2010 8:19:17 PM • MTX Thunder... • Answered on Mar 20, 2010
2answers
I have an mtx thunder 81000 d the inline fuse
When installing an amplifier of this size and current draw - the fuse is NOT ON THE AMPLIFIER.
This particular amplifier has a built in thermal shutdown protection only.
If the INLINE fuse is failing... only 2 things that would cause it....
1. Fuse rating too low - The current draw + wire resistance is greater than the fuse allows.
2. There is an immediate ground situation. There may be a screw though the power wire - the wire may be worn where it enters the firewall - or there may be a strand or 2 of wire jumpering from the Power terminal of the amplifier to the chassis (of the amplifier)
The recommended external fuse rating is 150A for this amplifier. Please be sure you are using the proper fuse for the amount of current draw this amplifier requires.
If there is an additional amplifier drawing from this feed - add the fuse rating of that amplifier to the INLINE fuse.
ALSO - be sure your wiring is of the proper gauge. I/0 wire is necessary in this instance - (or 2 runs of 4GA) as it has less resistance to the current. Utilizing an insufficient power wire will also lead to the INLINE fuse blowing.
If you have additional questions or concerns - feel free to ask.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
3/20/2010 7:21:29 PM • MTX Thunder... • Answered on Mar 20, 2010
1000d wont always come on
did u check the fuse in ur amp
3/19/2010 6:33:19 PM • MTX Thunder... • Answered on Mar 19, 2010
Power issue
blown fuse?speakers on their way out? check the amp fuses, then the inline power fuse.
2/8/2010 2:00:53 AM • MTX Thunder... • Answered on Feb 08, 2010
2answers
I have two four ohm
wire each speaker like this and go to the amp.
Wiring Option #1
1/30/2010 3:09:57 AM • MTX Thunder... • Answered on Jan 30, 2010
Wiring details
thunder 81000D not bridgeable,i have two daul voice coils kicker cvr how would i wire them up?
1/29/2010 1:33:11 AM • MTX Thunder... • Answered on Jan 29, 2010
MTX Thunder 81001 wont push subs
first of all you should check the minimal impedance your amp handles , if is class d it should handle between 1-2 ohms total impedance in a mono conection , meaning whatever quantity of subs you have hooked to your amplifier,their total impedance should the minimum the amp handles that way all the power from your amplifier will be used.
1/23/2010 7:07:51 AM • MTX Thunder... • Answered on Jan 23, 2010
I LIKE TO HAVE SOME ONE TO FIX MY AMP.
you have to send it to mtx. Most repair shops wont touch it. You can call mtx i had the same amp. It cost about 85 bucks plus shipping. the 85 bucks covered return shipping also.go to there web site it has the info for tech support and repair issue there. hope this helps
9/17/2009 1:42:49 PM • MTX Thunder... • Answered on Sep 17, 2009
Light
The red light indicates that your amplifier is in protect mode. Amps go into this mode if there is something wrong with the setup of the system to prevent fatal damage to the amplifier circuitry. This is bad thing since the amplifier will not function until the problem is solve and it can remove itself from protection mode.
Amplifiers can go into protect mode for many reasons but one of the most common is incorrect mounting. Is your amp sitting on the metal of your vehicle? Is it bolted down and screwed into the metal of the vehicle or your seat? The amp should never be touching any sort of metal. Only the ground should touching the metal of your vehicle.
Speaking of grounds, many people often neglect proper grounding which can cause an amp to go into protect mode. Do you have a solid ground? Is the wire less than 3 feet long and directly connected to a non-painted metal part of your vehicle? Is the ground wire the same gauge as your power wire?
These are just a few reasons why an amp can go into protect mode. You can find more information here. Or simply google for why your amp is in protect mode.
8/6/2009 11:55:23 PM • MTX Thunder... • Answered on Aug 06, 2009
Need a replacement ground terminal
when you do find a replacement use Kapton tape to reduce the heat on the parts use around component and around surrounding area except the place to be soldered
7/5/2009 2:18:11 PM • MTX Thunder... • Answered on Jul 05, 2009
Hi, I have a MTX Thunder 81000D and there's
D198 is a diode. It burns when the amp loses the chassis ground connection and the amp tries to ground through the RCA shield. If the amp is still working, it's better to leave that diode out of the circuit. That's what MTX did on later models.
6/5/2009 7:14:19 PM • MTX Thunder... • Answered on Jun 05, 2009
My mtx 81000d amp is burned in a few different places.
Depending on whats wrong with it, bench fees to check it usually start at $45 and then they will tell you parts and labor. without knowing what burned up its hard to quote.
6/4/2009 5:18:36 AM • MTX Thunder... • Answered on Jun 04, 2009
MTX Thunder 81000D Car Audio Amplifier Logo
30 questions posted
Top MTX Car Audio & Video Experts
Jose Ramirez
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • MTX Car Audio & Video
Most Popular Question
mtx thunder 81000 d inline fuse
  • Car Audio & Video
