20 Most Recent Toshiba Qosmio F45-AV412 Notebook Questions & Answers
mash f4, f8, f12... just mash all of the f keys as soon as you turn it on and it should come up.
Toshiba Qosmio... | Answered on Sep 03, 2017
The DVD player is defective, cost wise it is best to just replace the player.
Toshiba Qosmio... | Answered on Nov 29, 2016
When you start your computer, just keep on pressing the 'del' key or F2 key which allows you to enter the BIOS setup.
In this setup you will find the boot device priority option , you just need to use these options to select the device which you want to boot.
If by boot options you mean you want to go to safe mode, then just press the f8 key while your PC starts to boot so that you have a menu asking you to go in safe mode or choose other options.
Hope this helps.
Regards,
Sajjad
Toshiba Qosmio... | Answered on Jun 07, 2012
Driver problems also create this issue.
for that uninstall old graphic driver then download and reinstall graphic driver then check.
Let me know if you need further assistance.
Thanks for using FixYa.
Toshiba Qosmio... | Answered on Aug 01, 2011
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?modelFilter=F45-AV412&rpn=PQF43U&category=&selCategory=2756709&moid=1754949&os=&ct=DL&selFamily=804517
Toshiba Qosmio... | Answered on May 27, 2011
Here are all drivers for QosmioF45-AV412.
Toshiba Qosmio... | Answered on Oct 03, 2010
You should get in touch with them as they must provide a disc or recovery parition which was bought when they bought that laptop.
If you have a Windows XP disk then you can normally install by going into BIOS and setting CD as first boot device. If it gives hard drive not found then you will need to install the SATA driver from the Toshiba website first.
Toshiba Qosmio... | Answered on Sep 05, 2010
The flashing cursor is there to tell you that the BIOS couldn't load the OS. Reinstall one more time. If even that it behaves like that then the hard disk is dead, replace it.
Toshiba Qosmio... | Answered on Jul 17, 2010
Hi, Do you see the speaker icon on the bottom right of the task bar? If you dont see it, it means you need the driver for the sound card. In that case go to toshiba's website http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp and under downloads - select the correct model and download the driver for the sound card. If you DO see the icon and it's not muted or anything, that means it could be the speakers but I highly doubt so. I hope this helps
Toshiba Qosmio... | Answered on Apr 26, 2010
I assume you mean the volume bar.....if so its the wrong driver for Win 7
Toshiba Qosmio... | Answered on Mar 26, 2010
right click deskop and choose properties, when the windows comes up go to settings and adjust slider to a smaller resolution. Click OK and maybe reboot if asked, now you should be OK.
Toshiba Qosmio... | Answered on Mar 23, 2010
you got 2 things here:
1. pc shutting down unexpectedly
2. blue screen
1. the cause could vary:
a. cpu overheating: make sure you are letting the laptop to breath, open/clean vents.
b. motherboard failure: get a new laptop.
c. battery failure: try to take the battery out and connect the laptop and test/replace the battery as needed.
2. blue screen: if it is a Blue Screen of Dead, try to note any error codes and post back or at this stage it could be virus: take the hd out, connect it to an enclusure and hook it up to another good computer and attempt to save the usuful data. then reinstalled hard drive in laptop and reinstall os.
b. hadware failure: replace laptop.
on the password:
the only three possibilities where you may be asked for a password is if you're trying to access a password protected bios (which you rarely do with f8) or if you're accessing the recovery console in which you need to enter your windows user name and password or if you're accessing the computer in safemode in which you can enter any user name and their password or the user name: Administrator and for password it could be either blank or whatever password was set when windows was installed
good luck!
Toshiba Qosmio... | Answered on Mar 19, 2010
Take the battery out & see if it works then, perhaps the battery is so flat it is holding down the PC. It will should go on just the adapter. If this works, then you will have to plug battery back in, & adapter and leave alone for at least 8 hours. If it still won't work, you may need a new battery.
Toshiba Qosmio... | Answered on Mar 11, 2010
  1. Insert a writeable CD or DVD into your computer's CD or DVD recorder.
  2. In the dialog box that appears, click Burn files to data disc.
  3. In the Burn a Disc dialog box, type a name for this disc, and then click Next.
    It might take several minutes for the disc to be formatted in the default Live File System format. When the formatting is complete, an empty disc folder opens.
  4. Open the folder that contains the files you want to burn, and then drag the files into the empty disc folder.
    cdb4d559-8825-47a1-8175-79020965d91c.pngYou can copy files to the disc folder by dragging them to the disc icon or to an open disc folder As you drag files into the disc folder, they are copied automatically to the disc.
But I recommend you to use any CD or DVD burning software like Nero, BurnAware etc. There are lots of free burning tools available on Internet too.
Why I recommend third party software is because you can select burn speed plus minimum disc burning error.
Toshiba Qosmio... | Answered on Feb 02, 2010
If it's an audio cd you need to rip it - use
http://www.softpedia.com/get/Multimedia/Audio/Audio-CD-Rippers-Encoders/Express-Rip.shtml
First of all you have to erase the CD after that you can write on this CD. For erasing the CD you have to use a software like Nero. So please install this software then you can erase and re-write on the re-writable CD.
Regards
Ashly
Toshiba Qosmio F45-AV412 Notebook Logo
Popular Tags
38 questions posted
Top Toshiba Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Qosmio Toshiba
  • Qosmio Toshiba
Most Popular Question
only get flashing cursor in left top
  • Computers & Internet
