20 Most Recent
Acer Aspire4720 14.1-inch Notebook PC PC Notebook Questions & Answers
How to transfer songs from pc to ipod
Hi.
You may transfer the Songs from the Computer to the iPod Device by using the iTunes Application.
However, please feel free to contact for further information about the Application and the detailed steps to transfer the Songs.
Hi need to get bios password for aspire 9304 can
Hello thefall,
if by chance you didn't 'create a "Supervisor Password" to prevent anyone from changing the configurations in the BIOS / CMOS Setup?
Bootup / Restart the computer, and follow these steps:
When you hear the computer start-up, there will be a message that flashes very quickly at the bottom of the screen, it will read!
- Press F2 or F12 'or on other' Computers, the 'Key' Sequence may be [F11]..."
- The area of your attention, will be [F2] Key at the top of the keyboard.
- Press the [F2 Key] to open the CMOS / BIOS Setup.
Once this screen appear!
You will see a 'Listing" of different set-ups.
There will be instructions in the [right] Help ? area.
You be using the "Arrow Keys" to (Select and Choose Items).
In the first screen, there will be on the (right of the screen).
- Set Supervisor Password = This is the "Password Setting that will prevent anyone from getting into without authorization!"
- To "Change or Configure" CMOS or BIOS setting.
- Set User Password = This Password is use for "Logins / User Accounts...
- You want to "Reset or Change the Supervisor Password.
- Do so; and to finish, 'press' the [F10 Key] to 'Save the Changes.'
If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9
I cant open my computer even i press the on
- first check the charger
- then check the battery / replace the battery
- even there is problem occurs then there is fault in your power controller card change it.
thank you for give me chance to help you,
please give your ratings!
How to type the question mark character on my
The NumLK key in your keyboard was activated. Here's what you need to do to deactivate it.
Press FN and NumLK.
It should work.
I hope this helps.
CARLO
var geo_Partner = '82910b1e-9b92-42fd-b83f-fa09a0787ae7'; var geo_isCG = true;
Ctrl+c is not working
If Ctrl+c is not working, but the Control key works for other things and you can type the letter "C", then you have probably accidentally redefined what Ctrl+c does, either in the applifcation you are trying to use (check "Preferences" and "Options", particularly if it says "Keyboard Mapping") and also for the desktop.
Laptop problem
If you want to get the most out of your battery, then try not to use it very much, and if you run your laptop of a direct power source, the remove it completly, and store it somwhere dry, cool and free from dust. If your battery is really bad, then you can improve it's capacity by freezing it! This however could destroy your battery, so only do it if you have to. Details of someone doing this can be found here:
http://aphilosopher.wordpress.com/2008/02/23/freezing-laptop-batteries/
Anyway, in answer to your question, if you are using it of mains power only, then yes, take the battery out.
hope this is helpful,
06castwo
DVD OR CD not drive by CD-ROM
Option One:
To fix it, open “My Computer”, or “Windows Explorer”, find the drive icon for your CD/DVD player/burner and right-click on it. When the popup menu opens, choose, “Properties”. Click on the “Auto Play” tab. Click on “Select an Action to Perform”. Click on the “Restore Defaults” button and click on the “Apply” button. Then click on “Prompt me each time to choose an action” and click on the “Apply” button again. (Note: If you want it to open in a particular program each time you put in your music CD, instead of clicking on “Prompt me…” choose the program you want it to open each time you put in your CD. Now click on “Apply” and “OK” and restart your computer. Now put in a music CD and see if it works as it should.
We are authorised service provider for Acer Laptop
two links for Acer Motherboard for the model specified
http://laptop-for-less.com/acer-aspire-56105610z5630-motherboard-hbl50-la2922p-p-90.html?currency=USD
http://cgi.ebay.com/NEW-ACER-ASPIRE-5612WLMi-5613WLMi-MAINBOARD-MBAXY02004_W0QQitemZ260401294957QQcmdZViewItemQQssPageNameZRSS:B:SRCH:US:101
pls rate me WELL !
