20 Most Recent
Dell Vostro 1000 Mobile AMD Sempron Processor 3500+ 60GB/1000MB PC Notebook Questions & Answers
How do I system restore my Dell Vostro 1000?
Resetting
a Dell Vostro to the factory settings allows the user to restore the
Dell Vostro to the original operating condition as if it was just
taken out of the box. Dell system includes a restore utility called 'Dell Symantec System Restore' to reset or restore your Dell system to factory setting.Step 1:
Before reset any Dell Vostro laptop, backup your all important data
and programs, otherwise you may lose it. It is recommended to use an
external storage device for your entire data backup, so that you couldn't lose it in any sudden occurring issue...Step 2: Remove any other unnecessary external drive and restart your Dell Inspiron laptop.Step 3: Press 'F8' key continue until 'Advanced Boot Options' wouldn't be appear.
Step 4: Use your keyboard arrow key to select 'Repair Your Computer' from the list and hit 'Enter'.
Step 5: Now click 'Next' and login as the administrator account.
Step 6: Click 'Dell Factory Image Recovery and Data Safe options', select your language option and click 'Next'.
Step 7: Click the check box 'Yes, reformat hard drive and restore system software to factory condition' and click 'Next' to start Dell Vostro reset process...
This
process will erase all your previous changes that have been made to the
Dell Vostro laptop and reset the configuration settings to factory
setting.Feel free to get technical assistance for all type of Dell laptops(Vostro, Latitude,Inspiron...etc..) at http://www.vtechsquad.com/dell-support/
My dell vostro 1000 keeps
If its rebooting again and again after 2-3 hrs then it would be a hardware issue..your system must be heating up..it happens when the processor of the computer is heating up and there is no sufficient cooling...you can check the system fan it should be working properly..you can try opening the laptop from the bottom..clean it up if there is any dust,
Go to this link
http://support.dell.com/support/edocs/systems/vos1000/en/sm_en/index.htm
its a manual you should try cleaning fan,,removing Hinge Cover then checking processor thermal cooling assembly...you can try reset of the steps as well
Hi to all,
How can I
There's one faster CPU in that line (3600+), but it has a smaller
cache - meaning it wouldn't be much if anything of an upgrade.
Maybe upgrade the memory, that would have a better return, if it will take anymore.
Put the funds toward a newer system.
Hope that helps you to save some cash.
Cannot download anything from the web
Hello ,
Must be your internet explorer problem or antivirus problem .
Try using different browser for downloading .
If problem persists there must be some problem with the net connection.
When I play a DVD from my laptop to my projector
If the USB is used there can be problems of connectivity but if you are using the projector as the external monitor and feeding sound the problem should not happen.
Try to use a different player and confirm
Programs are slow and non responsive. windows xp
It could be a hardware error either memory or disk. Go to control panel, admistrative tools, events and look at system for disk errors. If you find any, that is a bad sign. Your disk is going bad. Make sure you have all your data backed up as the disk probably needs replaced.
If you didn't find any errors, it could be viruses. Go to TrendMicro.com and run their free virus scan.
Other things that slow down a system is temporary files. Download Ccleaner and delete all temporary files it finds. Also, let it clean the registry.
A badly fragmented disk can also slow down your system. Download Defraggler and defrag the system.
Let us know what you find so we can be of further help.
Update Dell Vostro 1000 BIOS now wont turn on, nothing on display
You may be in for some trouble, a failed bios update isn't always an easy fix. if you can find the cmos battery try to remove that for a few seconds. you will also need a disk version of the bios, download that from dell on another computer and copy it to floppy or cd and see if you can boot to that and reinstall the bios.
when you press the power button what happens, does it light up and run the fan? Nothing appears on the screen?
