20 Most Recent Dell Laptop InspironTM 1501 PC Notebook Questions & Answers
4answers
No CD for installation of printer
You can download the driver from the following website
http://tinyurl.com/ddexq7
Thanks
Proton.
Kindly rate the solution
12/6/2012 6:31:33 AM • Dell Laptop... • Answered on Dec 06, 2012
Disable sticky keys
Just click or double the keyboard icon on you lower-right of your desktop and unchecked the box. or click the arrow color white same location to see you keyboard icon.
9/25/2011 3:20:02 AM • Dell Laptop... • Answered on Sep 25, 2011
My computer sound not coming is that was software
Dear Pradeep
Welcome to Fixya.
This is problem deffinately due to a sound driver application problem. So you have to locate correct driver from dell recovery media or from their website,then reinstall the driver. It will deffinately solve your problem
Best Regards
Chandrashekhar bhat
12/25/2010 12:08:01 PM • Dell Laptop... • Answered on Dec 25, 2010
My Lexmark X5070 Printer is connected to my
The printer you want use, just given a print to that printer will tuned into online, if it not happed then use these two methods:-
1. set as default printer from control panel 2. re-install the printer after un-installation
11/7/2010 3:35:49 PM • Dell Laptop... • Answered on Nov 07, 2010
2answers
I have a dell xps m1530 the hdd stoped working i
Two beeps usually means the memory module went bad.
Replace it and you should be ok
Good Luck.
Dont forget to rate this answer if it helps
10/18/2010 3:59:11 PM • Dell Laptop... • Answered on Oct 18, 2010
Which is better processor between amd athelon ,sempron, turion 64
Hello rakeshmedita,
The Turion is more of a mobile processor meant for laptops since it uses less power while the athlon is for desktops and uses a bit more power. The Turion might edge out the Athlon on performance but will beat the pants off it in power consumption. The sempron is a low-cost processor meant for entry level desktops. So, to answer your question it goes Turion, Athlon, Sempron.
Hope this helps, if so please leave some positive feedback. Thanks.
2/16/2010 3:44:46 PM • Dell Laptop... • Answered on Feb 16, 2010
I have a dell 1501 ,the screen is blank but all
I belive you should purchase a CCFL backlight and the backlight inverter... the backlights die-off after a while and require more power to cause them to light and all... the issue is with the inverters because over time they cannot keep cool with the higher & higher power demands of the dieing backlight.
Replacing the backlight itself is a bare minimum requirement... but that will only solve the issue if the inverter hasn't burned up itself.
here's an eBay link which will provide you with a few selections, and in particular some neat combination backlight-&-inverter suited just for your dell 1501.
http://shop.ebay.com/i.html?_nkw=dell+1501+backlight+%26+inverter&_sacat=0&_trksid=p3286.m270.l1313&_odkw=dell+1501+backlight&_osacat=0
I hope that works out for you...
1/30/2010 12:41:00 AM • Dell Laptop... • Answered on Jan 30, 2010
I can burn DVD's, but can nolonger burn CD's. Using Roxio.
lynneb970, Go to www.ashampoo.com and download Burning Studio v8.
you will need to uninstall Roxio from your Dell, this should solve your problem.
5/24/2009 11:49:55 PM • Dell Laptop... • Answered on May 24, 2009
Will not process DVD -R, +R, -RW, +RW discs
You need to get a program such as Nero or Roxio that can burn them. Once you do this, you'll be able to write content on them for use in other computers.
www.nero.com for a free demo of Nero 9
5/1/2009 10:36:59 PM • Dell Laptop... • Answered on May 01, 2009
Press any key to start message at start up
click start scroll to control pannel, users, change the way windows starts, disable welcome screen.
4/7/2009 1:23:36 PM • Dell Laptop... • Answered on Apr 07, 2009
Run dell error
Since this is such an old machine I would imagine there are a lot of unnecessary programs running in the background and starting with windows. I would say the quickest solution would be to back up any data you want to keep and then reformat and reinstall. If you do not wish to do that there are some other steps you can take. First go into the control panel and then add/remove programs. Go through the list and uninstall everything you don't need/want. Secondly, click start then click run and type in "msconfig" without the quotation marks. Click on the start up tab and uncheck everything you don't need to have starting with windows. I would also run your spyware/adware scanners and run your anti-virus. Lastly, I would defrag your hard drive.
12/17/2008 4:08:18 PM • Dell Laptop... • Answered on Dec 17, 2008
Reformat PC
once you format and get to the screen where you're prompted to install xp, just make sure that you type a number that's half the size of your drive. format the first, do the installation and don't worry about the second one until needed.
when installing the second O/S, just pick the remaining space that's probably not partitioned, partition it, format and install.
It should take care of the boot.ini entries automatically for ya.
6/17/2008 1:17:53 AM • Dell Laptop... • Answered on Jun 17, 2008
2answers
Dell Latitude won't connect to internet. Windows XP.
It is too old, plus XP is a virus magnet and has been unsupported by Microsoft for nearly 15 years. Mainstream support for Windows XP ended on April 14, 2009. Windows 7 and 8 have passed you by, Windows 10 is current and Windows 11 awaits. https://www.google.com/search?q=Dell+Latitude+won%27t+connect+to+internet.+Windows+XP ..
4/25/2024 4:08:35 PM • Dell Computers &... • Answered 8 hours ago
2answers
I want to know about some adventures video games?
Check out Big Fish Games. It is a subscription service but they have all types of games including adventure and hidden object. You can also tryp Pogo since they have both a fee and subscription service. Last, but not least, you can try one of your local computer stores or the electronics section of "big box" stores like Target, Walmart, Kmart, etc.
4/19/2024 6:52:18 PM • Dell Computers &... • Answered on Apr 19, 2024
2answers
Where can I get a replacement adapter cord for my Dell 3052 - 20" all in one model reg model W158?
Amazon, or if you only want the main lead, Walmart.
AC/DC Adapter For Dell Inspiron 20 Model 3052 20- ...
Amazon.ca https://www.amazon.ca > Adapter-Inspiron-20-3052-... AC/DC Adapter For Dell Inspiron 20 Model 3052 20-3052 W15B W15B002 All-in-One Desktop PC Power Supply Cord Cable PS Battery Charger Mains PSU : Amazon.ca: ... $26.27 · ‎ In stock ..
1/11/2024 6:55:07 AM • Dell Computers &... • Answered on Jan 11, 2024
My dell laptop i5 does not recognize the external ac source
I would try another power supply and plug that in.
1/5/2024 9:01:17 PM • Dell Computers &... • Answered on Jan 05, 2024
Where is the reset button on the dell inspiron 3052 tag c99f22
Try replacing the BIOS battery for access to the computer.
10/23/2023 4:58:31 AM • Dell Computers &... • Answered on Oct 23, 2023
Dell Laptop InspironTM 1501 PC Notebook Logo
15 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
  • Dell Computers & Internet
Most Popular Question
disable sticky keys
  • Computers & Internet
