20 Most Recent Lenovo ThinkPad R61 Notebook Questions & Answers
the disk has to be in the drawer then shut down and restart should read the xp disk then
Lenovo ThinkPad... | Answered on Mar 10, 2015
Check your power management settings on the control panel and set it to default.
Lenovo ThinkPad... | Answered on Aug 10, 2014
Go into settings, you change display times on the screen also you change sleep time on the hard drive.
Please follow the steps below to reset the lenovo to factory settings
Note: All your data will be lost. So keep that in mind.
So take the backup of your data first in a separate HDD or flash drive.
1. Switch off the Computer
2. Press the power button and then immediately start tapping f11 key on the top of your keyboard.
3. You will hear a beep sound and then stop pressing it.
4. You will get the screen says windows is loading files. Wait untill it finishes.
5. Select the default language which is US and Click on next .
6. Enter your login credentials (username and password) if you use to login to the windows.
7. Then you will get the system Recovery Options screen where you need to select the last option "Lenovo Product Recovery"
8. Again preferred language will be English US and hit Next.
9. Accept the terms and conditions and hit next and then hit Yes on the warning.
10. Then it will start resetting the Lenovo Think pad to the factory default with no previous data. Same as when you purchased it.
If you have any query you can ask before restoring the Computer.
Hope this helps you. Reply if that fixes your issue.
Sukhiii
Lenovo ThinkPad... | Answered on May 07, 2014
What were you doing before it happened?
Lenovo ThinkPad... | Answered on Apr 15, 2014
Usually this means that the memory is defective or has been removed or popped loose in its sockets. Try to reseat the memory DIMMs or replace them.
Lenovo ThinkPad... | Answered on Mar 15, 2014
try open bios when password pop up appear do not type any word just press enter 5 times and restart next time enter on bios now your bios are unlock go to on bios password and change password .
Lenovo ThinkPad... | Answered on Sep 18, 2013
On the Back of All Laptops, you have a monitor hook up port, try hooking a monitor to the port, Boot it and see what happens from there.
Lenovo ThinkPad... | Answered on Aug 06, 2013
Not necessarily. Try blowing out with canned air.
Lenovo ThinkPad... | Answered on May 29, 2013
Download the audio driver here:
http://support.lenovo.com/en_US/detail.page?LegacyDocID=MIGR-67856
By selecting your windows system.
Good luck
Lenovo ThinkPad... | Answered on Feb 01, 2013
Hi. I think the problem on your machine is the RAMS if you here the beeping sound. I would suggest that you remove the memory and clean the contact points with an eraser but make sure that you remove all the receduces and also make sure that when you plug them back you should double check if they are properly seated. If you still having the same issue after doing the troubleshooting step then try a known good memory so that you could make sure that the problem is not with the memories you have.
Lenovo ThinkPad... | Answered on Nov 19, 2012
1.It can happen if any antivirus/firewall software blocking access to things . (in which disabling the the software before connecting would fix the issue)
2. Try to update driver for your Touch pad, This could also solve the problem.
Lenovo ThinkPad... | Answered on Aug 18, 2012
Lenovo ThinkPad R61 Notebook Logo
81 questions posted
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ThinkPad Lenovo
  • ThinkPad Lenovo
Most Popular Question
am hearing 4 beeps 4 times during power
  • Computers & Internet
