20 Most Recent Lenovo ThinkPad R61i Notebook Questions & Answers
You need to get a hold of a windows xp recover boot cd/usb. You can download it on the internet (if you can with something else than the lapop)
Lenovo ThinkPad... | Answered on Aug 18, 2019
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Lenovo ThinkPad... | Answered on Feb 01, 2011
clean it and then new cpu pasta, else check for virus, defrag,
Lenovo ThinkPad... | Answered on Jun 14, 2010
how did u lock ur laptop
if by bios password then u need to replace the EPROM
if by HDD prassword simply replace a new HDD
any thing else plz let me know
good day
Lenovo ThinkPad... | Answered on Jun 01, 2010
HI,
IT IS DUE TO MEMORY
CHECK FOR THE IML LOGS TO CONFIRM THE SAME
WHICH MODULE IS FAULTY OF RUN ONLINE/OFFLINE DAIGNOSTICS ON SAME SERVER TO DIAGNOS THE SAME PROBLEM
Lenovo ThinkPad... | Answered on Feb 12, 2010
looking at the specs for your Thinkpad i believe you can connect your AT&T PC card since it has a Type II interface
Lenovo ThinkPad... | Answered on Apr 11, 2009
hi im josh in phils. may i help you?
To make the web cam work try to install the software driver. here are the sites wherein you can download a free software:
http://www.user-guides.co.uk
http://hotsearchpro.com
good luck hope i helped you.
Lenovo ThinkPad... | Answered on Mar 14, 2009
If you don't plan on using it anytime soon the easiest way is to just remove the software from the ADD / Remove Programs section in the Control Panel.
Let me know if you have any problems.
Lenovo ThinkPad... | Answered on Mar 04, 2009
http://www-307.ibm.com/pc/support/site.wss/product.do?brandind=10&familyind=382898&operatingsystemind=49979&template=/productselection/landingpages/browseByProductLandingPage.vm&validate=true
Here is what you need!!! Click on the Above Link. Select type and Operating System then Click on Continue. You can download all the drivers!!!
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Lenovo ThinkPad... | Answered on Mar 02, 2009
Vista is obsolete!
  • whatsapp laptop free download - Softonic en.softonic.com > Software utilities > Operating Systems whatsapp laptop free download - WhatsappTime 5.1.14: Whatsapp for pc straight from your desktop, and much more programs.
  • Whatsapp For Laptop - Download.com download.cnet.com/s/whatsapp-for-laptop whatsapp for laptop free download - WhatsApp Messenger, WhatsApp Messenger, WhatsApp Pocket, and many more programs
  • Whatsapp On Laptop Windows 8 - Download.com download.cnet.com/s/whatsapp-on-laptop-windows-8 whatsapp on laptop windows 8 free download - Start Menu 8, Realtek High Definition Audio Codec (Windows Vista / Windows 7 / Windows 8 32-bit), DeskScapes 8, and ...
  • Download Whatsapp Messenger on PC, Computer or Laptop ... www.techtiptricks.com/download-whatsapp-messenger-on-pc-computer... Use Whatsapp Messenger on PC, Computer or Laptop Free, Learn How to Use Whatsapp Messenger on PC, Free download for windows xp, vista, 7, 8 or mac system
  • Lenovo ThinkPad... | Answered on May 09, 2020
    Error code 36 means a ley is stuck. Only you can find out which one. Press each key in turn to feel if there is a dodgy key.
    Lenovo ThinkPad... | Answered on Oct 09, 2019
    remove the battery large.
    then run on AC pack only
    #1 top failure of all mobile PC is that battery, so unplug it
    then test with AC pack only.
    work now.? and all vents must be clean, end to end. not just fan.
    there i no fuse it uses current regulator, imagine genius magic electronics fuses that never blow out, and bingo.
    OK big battery out, an RTC coin cell fresh.
    then fan blows.
    next is BIOS, do the BIOS screens work if not the mobo is dead.
    have 2 RAM stick on the 2 slots>? try one at a time
    run the PC with all modules removed, (options)
    remove hdd?
    remove, dvd drive.
    think like this. Get bios working first
    learn that modules can short, and when they do the power regs shut down.
    so we unplug all things to the mob,
    until only 1 ram and cpu remains.
    see? (this is called power overload fault isolation tactics)
    even the screen only can be dead, you never mention text showing
    you can test the mobo with external screen via that rear (?)_ VGA jack what if that worked, did you learn something here, sure.
    this pc has tons of modules to pull, even bluetooth. wifi, sound and more. if you look at all parts inside or sold by ebay, bingo. lots
    Lenovo ThinkPad... | Answered on Aug 14, 2018
    It helps to know what device model and OS you are using though the following steps for changing from pattern lock to slide are for Android OS 4.0 (Ice Cream Sandwich):
    1. Unlock your Android device
    2. Find the Applications menu and select "Settings"
    3. Under the "PERSONAL" group, select " Security"
    4. Under "SCREEN SECURITY" group, select "Screen Lock"
    This will ask for the security pattern first.
    5. The options for screen lock will appear, select "Slide" and you are done!
    Hope this helps.
    Lenovo ThinkPad... | Answered on Mar 14, 2017
    Press Ctrl and PrntScr together. That will grab the screen then open your document programme, (Open Office, Word or whatever you use to compile letters etc) press Ctrl and V.
    Lenovo ThinkPad... | Answered on May 23, 2016
    Lenovo ThinkPad R61i Notebook Logo
    15 questions posted
    Top Lenovo Computers & Internet Experts
    Lee Hodgson
    Lee Hodgson
    Muntejaya Ginting
    Muntejaya Ginting
    Ekse
    Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
    View Most Popular
    ThinkPad Lenovo
    • ThinkPad Lenovo
    Most Popular Question
    r61 getting hot
    • Computers & Internet
