20 Most Recent Android HD Wifi Smart IPTV Box - Watch Video on Your TV Questions & Answers
if you could watch movies before then the sources you are using have probably been blocked by your i.s.p.! Try setting up a v.p.n and trying again would be helpful if you could give a bit more detail as to which video add ons you are trying to use as there are different scenarios as to why this may be happening.
Android HD Wifi... • Answered on Jun 10, 2021
Reinstalled Netflix app for android then error 0013 went away
Android HD Wifi... • Answered on Jan 16, 2018
go to total installer add ons enable sd usb wizard plug in a flash drive back up to flash drive then reset
Android HD Wifi... • Answered on Apr 10, 2015
The phone number shown at the bottom of the Netflix home page is 1-866-579-7172.
Android HD Wifi... • Answered on Oct 26, 2014
No-HHT-041S Remote
i am purchess where and amount place
Audio Players &... • Answered 24 hours ago
To get information about the product that you want, check these websites-
As far as retail stores go, you can check an electronics store like Best Buys, Circuit City, Radio Shack, a musical instrument store, etc. For online retail stores, check Amazon.com or Ebay. You should also try doing a search on a search engine and check the "shopping link". Hope this helps.
Audio Players &... • Answered Yesterday
Hi angelo40
The amp sounds like it has a primary power supply failure and/or may be in protection mode. First, I would check for any blown fuses, replace any you fint with exactly the same type and rating. I can advise you here if you are not sure. If the unit blows a fuse after replace any failed ones, then there is a short circuit that you will have to trace out in the unit. DONT KEEP REPLACEING A BLOWING FUSE You generally are just doing more damage to the amp.
If all the fuses are OK and you are savvy with electronics and soldering, you could open it right inspect for these problems., and you have a multimeter, do some powersupply voltage checks, also check for that the main transformer is ok. Resolder any dry joints you find.
It may also (and or) have a problem in the output stages. Running it hard may have produced some dry solder joints, or blown a transistor in the output array. Happy to advise you further, just ask :)
regards
Graeme
Audio Players &... • Answered on Jun 18, 2021
I HAVE A PROBLEM IN Panasonic SA CH46 double cassette
POWER SUPPLY IS NOT WROKING PLZ TELL HOW >?
Audio Players &... • Answered on Jun 17, 2021
Well, if you're willing to install one thing, you can use the VLC media player found here: http://www.videolan.org/vlc/index.html VLC also releases applications for Android and IOS, and nativly supports almost all media file formats. This solution would enable you to use the file in its original format on your computer and not worry about conversion issues.
Android HD Wifi Smart IPTV Box - Watch Video on Your TV Logo
Popular Tags
31 questions posted
Popular Products
Top Android HD Audio Players & Recorders Experts
ADMIN Canada
ADMIN Canada
iptv iview
iptv iview
Level 1 Expert
Are you an Android HD Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Android HD Audio Players & Recorders
Most Popular Question
tickbox s905x comes up failed check
  • Audio Players & Recorders
