20 Most Recent Gateway M-6834 Notebook Questions & Answers
Red light on the front blinks 4 times
The 4 blinks are telling you that there is a fault. The same as Computer Bios Beeps.
I,d suggest removing the RAM/Memory, and replacing it. Press and hold the power button for more than 4 seconds, to ensure it isn,t in standby mode. failing this remove the cpu and re-seat it as it may be slightly out of position, or out of it,s socket. finally have a look at the back or underside to see if there is a reset switch/hole.
Mike @ Compurepair.
1/9/2014 7:44:01 PM • Gateway M-6834... • Answered on Jan 09, 2014
Yesterday the power went out
Hi You don't say what operating system you use. You do not say if you hear any signs of booting, the hard drive or fans spinning or if anything appears on the screen, even briefly. I assume the laptop was plugged in and running during the power cut. Try removing the battery for 30 minutes, reattaching it and then testing it again. While, waiting, try to plug the laptop directly into the mains (battety less) and try to power it up like that. If it does not power up after all these tests, then you probably have damage to the Power Management System of the Motherboard, which requires an internal repair to create new tracks on the motherboard to bypass original tracks damaged by the spikes and surges that often precede sudden power cuts and sudden power restorations. Motherboards can be expensive to repair, as several cycles of disassembly, repair, reassembly and testing may be required before a warrantiable repair is completed to the repairer's standard of expectation and the customer's satisfaction. They cannot always be repaired and, if repaired, the fault can reoccur. Often, a motherboard failure means either a new motherboard (expensive hardware and labour costs) or a new laptop. I hope this helps. If this answer does help you, please take the time to rate it. This helps answerers better understand the needs and the point of view of the asker and guides us in exploring the best ways to provide useful, high quality answers. If you need further help, please feel free to post another question or add a comment to this question.
9/2/2011 12:56:42 PM • Gateway M-6834... • Answered on Sep 02, 2011
Gateway m-6834 battery light blinking red and
Either:
A) Bad battery
Easy to check, take it out and try to boot. If yes. Get a new battery.
http://www.shopbattery.net/gam6mselirel15.html
If no.
B) Bad AC adapter
Does the power brick have an LED on it? Is it on. Even if it is it may not be putting out voltage. If the cord gets bent alot it can break inside so it looks normal. If you or some you know has a MultiMeter , have them check the voltage.If you know someone with the same laptop, try theirs. If it works get a new one.
http://www.buy.com/retail/product.asp?sku=209143953&listingid=29869055&dcaid=17902
C) Broken connector inside laptop
If a known working AC adapter doesnt work there could be a broken connector inside that needs to be resoldered or the power subsystem on the board could be fried.
4/13/2011 6:07:31 PM • Gateway M-6834... • Answered on Apr 13, 2011
The picture on laptop monitor
click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor also click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settingsalways click APPLY after making any changeshope this helpsdon
2/27/2011 9:19:12 PM • Gateway M-6834... • Answered on Feb 27, 2011
When I turn on my
Beeps usually indicate a problem with your hardware memory chips or keyboards or other items that are not functioning properly. I suggest if it is still under warranty send it back if not take it to a good shop for repair. Or try reinstalling the original software I would do this first. Most likely it is a memory module the way to test this is remove one of the chips and try starting the computer. If this continues place the one you removed back in the computer then pull the other one if it boots you have found your memory module that is bad if this is the issue, make sure that you have everything plugged in. John
1/15/2011 4:38:00 PM • Gateway M-6834... • Answered on Jan 15, 2011
What will cause vertical lines to go through the
theres a few things that have happened to laptops ive had. the monitor cable going bad and the video card going bad. maybe a loose connection too. if you move the screen back and forth does anything happen?
6/23/2010 5:54:10 PM • Gateway M-6834... • Answered on Jun 23, 2010
My display will not load.
First thing's first... The situation you describing with the mouse cursor appearing but nothing else is - it's probably a problem with the operating system, but could also be a hard drive
6/5/2010 11:31:39 PM • Gateway M-6834... • Answered on Jun 05, 2010
Gateway M-6834 laptop -- power blinks
Im having the same problem. did you find a solution?
11/10/2009 10:33:59 PM • Gateway M-6834... • Answered on Nov 10, 2009
Notebook power button is blinking red when I try
sounds like bad adapter.red blinking light means dead battery.so if charger is bad it will not power the pc or charge it.
10/17/2009 2:47:32 AM • Gateway M-6834... • Answered on Oct 17, 2009
Change geteway laptop from vista to xp
Yes you can but disable the SATA in the BIOS first and after Xp is installed you can install the SATA driver.
XP does not have a SATA driver or a SCSI driver on the CD and you need to interrupt the install process to insert this driver.
Leave the BIOS set to SATA, download the SATA driver and create a floppy with the SATA driver. Boot up the Windows XP install disk and when it asks for a a hard disk driver press F6 (I think it is this key, you have to be quick) insert the floppy with the SATA driver.
5/4/2009 1:12:56 AM • Gateway M-6834... • Answered on May 04, 2009
Display is in landscape mode, how do I get back to portrait mode?
if you are using XP its ctrl, alt and the cursor keys
kind regards and please remember to rate us
11/28/2008 12:36:12 AM • Gateway M-6834... • Answered on Nov 28, 2008
Laptop stuck at loading page were bar move left to right
it just means that you are very low on memory... i think ur OS must be vista... am i right??
Mine was taking 5 minutes to load... i did disk cleanup to remove the temp files and the error files and then i did windows update once and the system started startup faster like a champ...
11/23/2008 9:25:14 AM • Gateway M-6834... • Answered on Nov 23, 2008
How to make screen brighter
Go into Display properties, contrast and brightness.
4/29/2015 2:49:06 PM • Gateway M... • Answered on Apr 29, 2015
Want to get into the computer I just bought
the best way is to open the laptop up take out the small battery leave it out for about ten seconds then put it back in,most of the time this will do away with passwords. this is called the cmos battery.
4/4/2015 10:36:37 PM • Gateway M... • Answered on Apr 04, 2015
Canot change win 7 to xp
you need to go to bios and set boot options to boot to cd dvd insert your XP disk, then click F10 to save changes and shut down (power off) computer. It must power down (off). When you hit the power button be ready to hit the space bar, to boot from cd
3/7/2015 4:46:00 PM • Gateway M... • Answered on Mar 07, 2015
How I can unlack my computer
Good day Jose If you are stuck at the computer "Locked" screen then you will have to press the Ctrl, Alt and Delete keys simultaneously to be able to type your password to unlock your screen.
11/20/2014 4:20:23 PM • Gateway M... • Answered on Nov 20, 2014
Gateway M-6834 Notebook Logo
20 questions posted
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Michael Thomas
Michael Thomas
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
M Gateway
  • M Gateway
Most Popular Question
will cause vertical lines go
  • Computers & Internet
