20 Most Recent Frigidaire GLWS1649A Top Load Washer Questions & Answers
hi Cinebar.
this is what i found from the internet so not sure if this will be off help to you.
There could be several reasons why your Frigidaire washer will not agitate, including problems with the power supply, the wash cycle or the way in which the appliance was loaded. It is a good idea to try to resolve the problem with your washer yourself first since unnecessary repair call-outs can potentially be expensive if your appliance is outside its warranty period. Troubleshooting your Frigidaire washing machine will take about 15 minutes.
Confirm the water shutoff valves are open. If your Frigidaire washer cannot draw water from the pipes, it will not fill or agitate. The shutoff valves are usually located behind the washing machine where the water pipes meet the wall. Allow the washing machine to cool down for 30 minutes. Frigidaire appliances automatically shut off if the motor starts to overheat. The cool-down period lasts for half an hour if the appliance has not been switched off manually.
Verify that the detergent draw is tightly closed. If the dispenser is left open, the washer will not start or agitate its load. Push the draw so it sits flush with the front of the washing machine.
Ensure that the washing machine door is closed. As with the detergent door, the appliance will not start if the door is left slightly open, to prevent water from spilling onto the floor. Push the door closed until it clicks, and try your load again.
Confirm that your Frigidaire dryer is set to a spin cycle. If your dryer is set to a soak cycle or is currently in the soak portion of a longer cycle, it will not spin or agitate the wash. Make sure the appliance is set to a spin load and try again.
Contact Frigidaire if problems continue. You may be entitled to free service if your washing machine is within its warranty period. See Resources for Frigidaire's contact information.
or read up more at this link.
Frigidaire washer won agitate Google Search
Frigidaire... | Answered on Dec 12, 2017
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Frigidaire... | Answered on Mar 01, 2011
Hi.
In this model the agitator (part 11 in diag. below) is held by one single bolt. All you have to do is removing the detergent dispenser and a cover (check diagram, it is part 66-67). After that reach the agitator, undo the bolt (nr 56 in diagram below) located on top of the agitator, and pull out the agitator.
Here the diagram, click on the picture to enlarge:
Here all parts and diagrams for your model.
Regards.
Ginko.
Frigidaire... | Answered on Nov 15, 2010
This category includes standard-size top- and front-loading clothes ... Frigidaire. GLWS1649A. 449 $45. T. 85. 1.57. Frigidaire. GLWS1749A. 543 $54. F. 75. 1.26. GE. WCXH208A.
3.2 cu.ft
Frigidaire... | Answered on Oct 21, 2010
check the drain lain
and water bumb
Frigidaire... | Answered on Aug 23, 2010
no it will not be the belt more so it will be a bad transmission.or something stuck under the agitator i have seen drill bits and keys get stuck under the agitator and cause the transmission to stop
remover the agitator first and check it is there is nothing there the transmission needs to be replaced
Frigidaire... | Answered on Oct 02, 2009
Check the allen set screw on the pulley. You will probably need a long allen key to reach it. You will also need a flash light to find it. Hopefully, the shaft has not been damaged beyond reasonalbe use.
Frigidaire... | Answered on Sep 07, 2009
Check the placement of your drain hose. This may be a simple issue of siphoning. The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Make sure you have a sufficient air gap at the top of the drain stand pipe, and that the drain hose is not placed in the standpipe too deep. This can cause the water to constantly siphon out of the wash tub and the washer will continue to fill to try to maintain the water level.
Please let me know if you have questions, or if you require additional assistance. I hope this helps you.
Frigidaire... | Answered on Jan 22, 2009
Have you verified that you do not have a siphoning condition? The following link explains:
Please double check the installation and placement of your drain hose. If the top of the standpipe is sealed off, or if the drain hose is shoved too far down into the standpipe, this can create a vacuum. This can cause the washer to constantly siphon out of the wash tub on the fill cycle and the washer will continue to fill (as needed) to maintain the water level. In other words, what may appear to be a significant problem, can be something as simple as a simple placement issue with the drain hose.
If you have further questions, please let me know. If the diagnosis is not correct, please post back and also let me know, so that I may be able to assist you further. I hope this helps you.
Frigidaire... | Answered on Jan 21, 2009
the drain pipe could be having a block. some times buttons and coins are the culprits.
Frigidaire... | Answered on Jan 06, 2020
Google (frigidaire)(MLF125BZKS)(manual) without parens OR contact Frigidaire directly to request.
Frigidaire... | Answered on Dec 28, 2019
As ­e­l­iz­A­b­et­h r­e­p­l­i­e­d ­i'­m ­A­m­Az­e­d t­h­At ­A ­m­o­m ­c­A­n ­e­Ar­n $7438 ­i­n ­f­our w­e­e­ks ­o­n t­h­e ­c­o­m­put­er. ­d­i­d y­ou s­e­e t­h­is s­it­e ­g­o t­o t­h­is s­it­e ­h­o­m­e t­A­b ­f­or ­m­or­e ­d­et­A­i­l.......www.job.pays12.com
Frigidaire... | Answered on Dec 16, 2019
Frigidaire GLWS1649A Top Load Washer Logo
Popular Tags
20 questions posted
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Washing Machines
Most Popular Question
size model many cu ft
  • Washing Machines
