You will need to replace the burner switches for the burners that are not functioning correctly.It also sounds like you have a problem with the OCU (oven control unit), this part is known to consumers as the clock. Do a Google search for the model number and find a supplier for the parts. All three of these parts will easily cost over $300 all together.Also the model number you listed in missing the last 2 letters. Locate the sticker which contains your model and serial number. This sticker will be on the oven frame when you open your bottom drawer.
As copied from the manual.
Setting a silent control panel
When choosing a function, a beep will be heard each time a pad is pressed. If desired, the control can be programmed for silent operation. Press and hold (start/time) . After 7 seconds, the control will beep once. This will block the controls from sounding when a pad is pressed. To return the sound, press and hold (start/time) again for 7 seconds until the control beeps once
NOTE!
The OVEN indicator light on the electronic display will turn ON and OFF when using the Bake feature and during preheat. This is normal and indicates that the oven is cycling to maintain the selected baking temperature. When the preheat indicator light turns OFF, your oven is ready.
Hi im an appliance tech and i had the same problem its not the EOC other words control board its actually the speed bake swith its stuck in the on position that why you get a stock keypad error code either f1 or f11 replace that switch or disconnect it and im positive that this will solve it .
Send it back and get the correct one. It can't be the same part number if the connections are different. Your old one may have features that his new one doesn't. The one less wire may just be a shared return, but the stove might be needing individual returns. If it is an updated replacement (the listing sometimes says 'compatible with' or 'replaced by', or 'alternative part'), it should come with a wiring schematic.
Please always include full 'make MODEL (what it is)'.
Fixya Expert 'Jorgie the Appliance Guy' will have the answer if it is a shared return but he will need the model number. Edit your post and add it.
No orifice for the oven jet? All work on gas appliances needs to be done by a certified gas technician. Somewhere, normally just behind the knob, there is an adjusting screw (certainly for hobs). The flame must be high enough that it can't blow out. The standard test is the slam the oven door, with your kitchen windows closed and then again with them open. Help in the link, but also the pressure from the tank _at_ the range should be checked.
https://www.google.com/search?q=oven+flame+adjustment
This is so confusing
You say
"The oven and broiler elements are not working"
Then you say
"Everything works except the burners'.
so nothing works? No oven/broiler elements and no burners? It make me wonder what the 'everything' is that works? The clock? The oven light?
Sounds like the main house breaker has flipped. On my older GE stove from the 1980s there are glass screw in fuses hidden below the controls and above the hobs. You undo the switch bezel for the oven light and the switch bezel for the rotisserie and pull the panel forward exposing 8 fuses. If all yours blew, it would be very strange!
Click comment under my answer and also under Vince's and we will get you Fix-Ya.
F29 on all Frigidaire ranges means there is a communication error between the oven user interface and the touch panel. The control can't do the initial communication. This could be related to a wiring problem or a problem with the touch panel or the oven user interface board. Turn off the power to the range for 30 seconds to clear the code. If it returns, check that the wiring harness is fully seated. Check the wires for continuity and make sure that there is no corrosion on any of the pins. If the error repeats, replace the touch panel. If the error still persists, then replace the user interface board.
Please add a comment with the model of the range for a parts list/diagram.
I hope this helps.
please make sure that there is a pot or pan on the stove top when you start it. It might be locking as a safety mechanism if it doesn't sense an object ready to be heated. Otherwise, please refer to the troubleshooting section of you manual to help turn off the locking mechanism.
Thank you.
Good Afternoon James, I appreciate your post!
Based off the information you have provided your Frigidaire range will not bake or broil but the cooktop is working properly. This could be a potential issue with your control panel or elements. Since it could be anyone of these underlying issues I would suggest having a professional technician out to perform a proper diagnosis and repair. Having a technician out will prevent any unnecessary part purchases. Best of luck! -Matt
It actually did you a favour. Week in and week out we see tales of woe where the door won't open, fans have burned out, elements have failed and even one poor gent who had a melted control board on a stove that there were no parts available. Self cleaning ovens which although seem a great idea, supply a steady parts income stream for the maker and revenue for repairers to come and fix.
Manual for the 358, yours doesn't appear to exist.
https://www.google.com/search?q=CFEF359CES+manual
